Question about Canon MV800 Mini DV Digital Camcorder
Cannot insert tape into canon MV800. Always ejects
I recently charged my camcorder and message cam up on screen to remove tape. i ejected tape and reinserted it but it spins up , bleaps a few times and auto ejects. The tape does not retract into the camcorder. If I remove the tape, (I have tried several tapes) mechanism retracts normally when empty. however as so as i put tape in again, same old problem it will not retract and auto ejects. Is this a major repair or is there a simple fix?
  • 4 more comments
  • LesleyW Dec 05, 2007
    My problem is exactly the same as soon as I try to insert a tape, and I have tried several brand new and ones I've used before, it tries to spin then beeps and ejects.
  • SusanLD Jan 07, 2008
    Hi, we have the same problem. Mechanism works with no tape in but when a tape is inserted it tries to retract but makes a whirling sound and then ejects the tape. Tried differeren tapes and power sources but no success.
  • Prima667 Apr 07, 2008
    I had the same problem and sent it back under warranty. They fixed it but were unable to give me the details of the problem despite several phone calls and now it is happening again.
  • bies May 18, 2008
    The same situation with MV700, not used for about half a year, and now can't insert any tape. Like yours - strange sounds and eject.
  • dicfish
    dicfish Dec 18, 2008
    Exactly the same thing with my camcorder. You put a tape in, whirling sound, beep, and it ejects. What´s the best solution here? Fix it or buy a new one?
  • Anonymous May 13, 2009
    I had the same problem but it was also fixed by dropping from about 1/2 meter above the carpet. Thanks fo rthe advice.
    Paul
Hi Everyone,
our MV800 was doing the the same so i "accidentally" dropped it (i got a bit frustrated and it was out of warranty) and now it works fine. please note it dropped about half a meter on carpeted floor while it was off.
Hope this helps
Posted on Dec 18, 2008
Same problem, but less violent solution: bump with your hand on the tape copartment (once it is closed). That worked fine with my MV800. It may be a small problem with a sensor.
Posted on Aug 07, 2009
@lwalshaw you are a genius!! I dropped it from approx. 25cm, works like a dream now!!! :D
Posted on Jul 02, 2009
I have just tried Iwalshaws solution, and it really worked! I cant believe it! Just dropped it from 1/2 meter above a carpet and it worked!
I have had the same problem. Got it a year and a half ago and have only used it twice and now it wont work. does it cost much to fix or should i just buy a new one??
Posted on Mar 08, 2008
I have exactly the same problem with my Canon ZR200 and just now I tried out the "dropping solution" . You know what ...it worked !!!
Posted on Oct 14, 2009
I followed the "dropping it" instructions above and you guessed it - it now works. thanks for the help
Posted on Sep 19, 2012
I had exactly the same problem with my MV800 - It was a repair job (back to canon). They fixed it but it has just started happening again.
Posted on Aug 22, 2007
Optura Pi Mini DV Digital Camcorder: I connected to AC and recharged, turned on and got...
yes i think; if you can find a good tech he should be able to make the mechanism alignement and clean out debris could be in the mechanism but he can charge you more because its as been open..
and clean the mode switch all that can be done with out parts replacing beleive me i know! because i fix a lot of camera and cam corder
hope that will help you..
regards Alan...
May 18, 2010 | Canon Optura Pi Mini DV Digital Camcorder
I can't get the tape to eject. PLEASE WAIT is the message that is displayed on the screen
Please let me know more about the message, go down further below if there is a numeric code like "03" or "02" etc. Because If it is because of condensation tape can be ejected. Please wait message also appear when you inserted a high capacity SD Card and you are switching from REC to Play and every time you switch cam on, the bigger capacity the longer you will wait, i suggest remove it when not needed. Please give as more details if none of the mention above solves your problem.
Jan 25, 2010 | JVC GR-D290 Mini DV Digital Camcorder
Canon ZR900 cassette won't eject
you could hit like the method for if a canon won't let you put in a cassette but i don't know if that will work. just hit it on the non screen side a few times and in theory it should work.
if nothing it will get rid of stress
Dec 12, 2008 | Canon ZR900 Mini DV Camcorder
Samsung mini DV sc-D366 always displays eject
I believe your problem is in the drum motor assembly part No is AD97-10579A. Samsung they know that problem it require a Technician to replace this part because you must adjust electronic and sometime mechnism as well. Depend which country you are it might cover under warranty even your CAM is out of warranty just check with Samsung in your area
Dec 04, 2008 | Samsung SC-D33 Mini DV Digital Camcorder
Mv800i camcorder
well there are certain cassettes made for that camcorder. i suggest you search for what the are called and then you can buy them
May 26, 2008 | Canon MV800i Mini DV Digital Camcorder
Eject tape message
We get the eject message and then it will not eject tape.  Any suggestions
Mar 04, 2008 | Canon GL1 Mini DV Digital Camcorder
Canon ZR60 Mini DV Digital, remove the cassete message
This is a tape transport problem and is expensive to fix. Unless you know a cheap tech, it's time for a new one. Be patient loading and unloading tapes. This is usually what causes this problem. The Yellow warning sticker is REALLY important. Another important item is to always use the same brand of tape because switching tapes causes a gummy build-up the makes tapes get caught in the machine.
Videoteacher
Dec 08, 2007 | Canon ZR60 Mini DV Digital Camcorder
Canon zr300 ejects tapes
Hi Everyone,
Hope this helps
Dec 04, 2007 | JVC GR-D250 Mini DV Digital Camcorder
The tape ejects immediately after inserting tape
your m-chassis has a problem with it and when we get these we replace the chassis and adjust them you should send to canon for repair or a qualified tech. sorry
Dec 01, 2007 | Canon ES8200V Hi-8 Analog Camcorder
Canon MV800 Mini DV Digital Camcorder Logo
889 people viewed this question
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
