Question about RCA 32V550T 32" TV
Wont turn on .....no sounds, no clicks......using remote or button
TV will not turn on. Makes NO sounds. Using remote or button on top of TV. Thanks
    Scholar:
  • 168 Answers
This symptom is usually caused by a breakdown in the power-supply circuit. in most modern receivers (transistorised and/or ic), it may also be caused by a breakdown in the horizontal deflection circuits (horizontal oscillator, pre-drive or drive circuits.). this is because the supply volatages for the tuner, video intermidiate frequency(VIF), video amplifier, sound intermediate frequency(SIF) and vertical output circuit are usually supplied by the horizontal output circuit. but if you are not inclined with this kind of job, better bring it to a qualified tv technician. good luck!
Posted on Mar 10, 2007
When i press the power button on the remote to turn my 52inch tv on it doesn't start and makes a clicking sound as if its trying to come on
What is the brand name to your TV? Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
Oct 25, 2012 | Televison & Video
Screen displays empty data base and cannot be re tuned
This sounds like a software glitch, you could try a factory reset, but you do so at your own risk. Here's how:
On top of your tv there is four buttons...
1...Turn your tv off
2...Hold down TO THE LEFT the volume button and the CHANGE CHANNEL button.
At the same time hold down the AV select button (round button)
3... Now press the tv ON button KEEP ALL THE BUTTONS DEPPRESSED untill the TV turns on...
4... By now the screen should have come on with a engineers menu on.
5... Using your remote scroll up and down the menu using the ""P"" button...on the menu you will notice items saying RESET..click either ""OK"" OR using the navigation buttons on your remote (thats the 4 surrounding the ok button"" press the right arrow then press ok.
6... Scroll through all of the pages ALL 11 of them and reset them all.
At this point your tv on/off button may not work..simple turn off at the socket and everthing should have been reset.
Now turn your TV off then back on again.
Hope this helps
TV_Doctor
Jan 05, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
When turning on the t.v. makes a clicking sound (Normal sound) but the t.v. doesn't turn on, no picture?I am wondering if the t.v. has a reset button or something?
Does any indicator light in front of the TV when you turn it on?
if the answer is yes, try turning on the TV by using the remote control. press any of the programme numbers 1-9 while pointing the remote at the TV. It is advisable that you install new batteries in the remote before attempting this.
If the answer is no then you should do the following:
- check the wall socket. try plugging another device into this socket to see if there is power present
if all the above fail thentake the TV to the repairman.
Oct 02, 2009 | Televison & Video
The TV will not turn on.
I have the same problem, push button to turn on tv but it only does a click like it is going to turn on and then another click bit it wont turn on. Finally a red light is just blinking.
Any suggestions, is there a freeze button or code that I need to push.
Jul 03, 2009 | RCA HD52W140 52" Rear Projection...
Tv wont turn on, it only makes the click
well sounds like you have on h.v. or lost of b+ line also would first check for open solder connection or possible bad solder conn. first okay
May 18, 2009 | Televison & Video
Tv is on but wont play
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Give the brand name and the model number..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 25, 2008 | Televison & Video
Sony bravia tv
Solution is simple....
First, unplug power cable from the back of your TV. You will notice the flashing light is still flashing. Don't worry, go to the Second step.
Second, keep pressing on the POWER button, located on the panel at the top of your TV, to shut off your TV. This will stop the flashing light from appearing.
Third, Plug the power cable back onto your TV
Fourth, press the POWER botton ONCE, using the same button used in the Second step to turn your TV back on.
Fifth, you will see the POWER light comes on, as normal.
Sixth, using your remote control, press the green button to turn on. Your TV should work as normal.
Jun 08, 2008 | Televison & Video
Sony kv-34xbr800
I have the same problem. When using the remote, it makes the clicking sounds like it turns on, then immediately makes the clicking sound of turning off. The LED blinks repeatedly 6 times over and over.
I *did* get it to come back on by holding the power button down for about 5 seconds. Now I'm afraid to turn it off again! :(
Nov 29, 2007 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
My tv will not turn on.
First of all, forget about the remote and see if the TV functions normally using the buttons on the front of the set itself. If the TV will not power on with the power button on the set itself, then something is wrong inside the TV. If the set works fine from the front buttons but no longer responds to that remote, then the remote has either gone bad or was accidently set to a different brand. In this case, look for the original book that came with the remote (or TV if it is the original remote) and follow the instructions for setting the remote back to Zenith. Try that and post your results here.
Aug 09, 2007 | Zenith C27A24T 27" TV
RCA 32V550T 32" TV Logo
50 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
