Question about HP LaserJet 3700n Printer
NEED TO REPLACE dc CONTROLLER ON HP 3700N
WHERE IS THE DC CONTROLLER PN3 RM10506050CN LOCATED
  • 37 Answers
Remove the left cover.
2 Disconnect all cable connections (19 connectors for the HP Color LaserJet 3500 series printer and 20 connectors for the HP Color LaserJet 3700 series printer).
3 Remove four screws (1) and remove the PCB (2).
Posted on Aug 22, 2009
Where is DC controller of HP 2820 located?
DC controller located behind the farmatter...
1. Remove right side cover
2. Remove farmatter
Aug 17, 2015 | HP Office Equipment & Supplies
55.00.00 DC Controller error
Replace the DC Controller first, next the Formatter.
The 55.xxxx is a communications error between the DC Controller and the formatter.
Apr 03, 2014 | HP LaserJet M9050 MFP Printer
Hp 3600 54.17 error
54.XX ERROR An error has occurred with one of the tonerlevel
sensors.
XX Description:
15 Yellow
16 Magenta
17 Cyan
18 Black
1. Make sure that connector J1020 on
the DC controller is seated correctly.
2. Replace the DC controller.
Dec 12, 2012 | HP Office Equipment & Supplies
My HP Color LaserJet 3600n keeps flashing a 55.04.00 DC Controller error. Now, I have unplugged it, tried all sorts of outlets and still does the same thing. Im no Techy by any means.. so if you do...
There is a communication interrupt between Dc controller & formatter, remove and re connect all the flat cables which was connected to DC controller.. check if its not resolved replace DC controller.
Sep 24, 2011 | HP LaserJet 3600n Printer
MY PRINTER hp laserget 4250 dtn is displaying 57.4 error when I turned it on, what can I do? I am ofetn requested to suitch off and then to switch on but it fails to mark " Ready"
57.4 Main fan error
Hi I hope this will help
The text come from the hp manual
good luck Ian
Q2431-90912 Chapter 7 Troubleshooting 287
57.X
PRINTER ERROR
To continue turn off then on
or
57.3
EP FAN FAILURE
or
57.4
MAIN FAN FAILURE
A printer fan is not functioning.
X Description
3 EP cartridge fan, right side
(LJ 4300 only)
4 Main cooling fan, left side
Turn the printer off and then on.
57.3 Cartridge fan error (F2)
1. Reconnect the connector
between the fan and the
DC controller PCA
(location J78).
2. Replace the fan. See "Cooling
fan (right side;
HP LaserJet 4300 series
printer only)" on page 170.
3. Replace the
DC controller PCA. See
"DC controller PCA" on
page 181.
57.4 Main fan error (F1)
power supply.
2. Verify that the ribbon cables
are fully seated in the
connectors on the
DC controller PCA.
3. Replace the fan. See "Main
cooling fan (left side)" on
page 168.
4. Replace the power supply.
See "Power supply" on
page 188.
5. Replace the
page 181.
57.7
DUPLEX FAN FAILURE
The cooling fan in the optional
duplexer is not functioning.
1. Turn the printer off and then
on.
2. Replace the duplexer.
Mar 25, 2011 | HP LaserJet 4250dtn Printer
Sir, i have hp laserjet colour printer CP5225, having error 55.0601. Kindly give me online solution
this all i manage to find for hope it helps
55.x Error
Error Message
55.X Error
Turn off then on
Description
The printer has experienced an internal error. The printer may experience one of the following errors:
55.0 DC controller communication error
55.0601 DC controller NVRAM data error
55.0602 DC controller NVRAM access error
55.1 DC controller memory error
Action
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the printer to initialize.
If a surge protector is used, remove it. Plug the printer directly into the wall socket. Use the power switch to turn on the printer.
If the message persists, contact HP support.
You need to first check the connection between the dc controller and the formatter and if the connection is fine you need to replace the dc controller.
Dec 22, 2010 | Office Equipment & Supplies
Install hp4600 dc controller
This is not exactly an easy task. But here are the step by steps
The following procedures explain the removal and replacement of internal components DC controller shield 1 Remove the following assemblies: ● Print cartridges and ETB.(ETB Is the black belt) ● Rear cover. ● Top cover. ● Rear top cover. ● Left cover. 2 Remove nine screws (callout 1). A tenth screw might be located on the rear of the printer at the bottom of the DC controller shield (callout 2). If that tenth screw is present, remove it. 3 Remove the DC controller shield. c0a7a70.jpg
Behind this shield is the DC controller board; It has quite a few wires connected to it, as it's the main controller for the printer.
1089df3.jpg Be sure to reconnect every wire or the printer will not work.
The correct Part Number for the LJ4600 (only) for the Dc controller is RG5-6391.
Good luck :)
Aug 31, 2009 | HP LaserJet 4600 Printer
Hp clj 4700n 59.30 error
The error stands for:
59.XY PRINTER ERROR
X is in your case 3 : FUSER MOTOR STARTUP ERROR.
Y is in your case 0 : NO COLOR
The service manual says:
1. Reconnect the connectors for the fuser motor and on the DC controller PCB. Replace any damged parts.
2. Replace the fuser drive assembly.
3. Replace the DC controller PCB. Calibrate the printer after replacing the DC controller.
Best regards,
mannu_rakesh
Aug 22, 2009 | HP LaserJet 4700 Printer
52.00 error
Hp says you have a bad scanner unit(laser unit) or DC controller, but first reseat all your connectors on your scanner unit(laser) and DC controller. Your scanner is located under the top cover and the DC controller is located behind the right cover. If the problem still persist replace the scanner first.
Apr 23, 2009 | HP LaserJet 4350n Printer
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
HP LaserJet 3700n Printer Logo
246 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
