Question about LG 32LC5DC 32 in. LCD HDTV
Rgb input is dissabled
I am at a hotel with the 32lc5dc lg lcd tv. they have the public display turned on and the RGB port disabled so i can't connect it to my laptop. does anyone know a way around this?
thanks for any help
alex
  • Anonymous Jan 13, 2009
    Exact same problem for me today. Same LG 32lc5dc lcd TV. The 'Input' button on the side of the TV (as well as the menu button) seem to be turned off, and the remote that the hotel gives out is the simplified PayPerView remote. Don't have a universal remote with me so short of picking one up, any way to get this thing going my way so I can change to the component video and get some xbox going?
  • 3 Answers
If the TV has the lodgenet card installed, Which is what handles the pay per view stuff, there is no way to enable the inputs, if what they stream down from the hotel explicitly disabled the inputs. Only way around this would be to remove the 2 screws holding in the lodgenet card, and pulling it out of the back of the set (Don't have to pull it out all the way, just enough to disengage the data socket. Once the card is removed, you would need an actual LG remote (not the pay per view remote) and hit menu a bunch of times until it stops flashing menu on and off. Once it stops, you type in on the keypad, "98765" "ENTER". This will take you to an installer menu. Scrolling down to the highest numer there is (Should be one backwards from the "000" you start on" there is "Factory Reset" and you use the right arrow key and set it to "1" and then press enter. The TV will flicker a couple times, and then, all inputs are active. Once you are done with it all, pushing the lodgenet card back into it's socket, and installing the 2 screws will put the set back to the hotel settings. Now realize once that card is pulled, you won't be able to watch the hotel's PPV or inhouse channels, only a few Free to guest channels will show up.
Posted on Feb 06, 2011
  • Matt
    Matt Dec 16, 2014
    Worked Great, out of Hotel Mode now. When I got to the 000 the menu changed. Scanned the channels and got it working. Then I put the Lodgenet card back in and it went back to hotel mode. I then removed the lodgenet card and used a small flathead screwdriver to remove the plug circuit board and just left it hanging and pushed the card back into the TV and screwed it back in. The circuit plug is just hanging inside TV and is not plugged into TV to put it back into Hotel mode.
Same problem. If I go around the back of the set and unplug the coax cable going into the set, as well as the M.P.I silver satin, whatever that is, the Input button on the side becomes active and I can select RGB or Component, but AV1 / AV2 which are what I need are still greyed out.
Posted on Mar 25, 2009
  • Bilbo Baggins Nov 27, 2011
    Same problem, and this worked. I only needed to disconnect the M.P.I. silver cable (looks like an ethernet cable) and the menu button on the side panel worked, as well as the input button. This allowed me to pick any input, including HDMI. Thanks!
Why rgb connection o.k. NO TV signal?
Check your manual for instructions to select video source. Also , please be aware that rgb video also usually requires separate audio connections along with the rgb.
Jun 08, 2014 | LG 32LK310 LCD HDTV, 32 Display Size, 16:9...
I am at a hotel for a couple months. There is an lg 32lc5dc for a tv. There is no box to order movies but I can not use the hdmi port. There is audio but no video. The hdmi 2 port does not work at all...
probably the tv is hotel mode ,which is the management or tech have lock the sys ,to avoid complication for guest ,u have to find the manual or through on line.
Oct 05, 2013 | Televison & Video
How can I connect my laptop to my LCD TV through HDMI cable (brand:LG) (model:LF15 series) HD ready?
You'll need to make sure that your laptop & LCD TV have an HDMI port. If they both do, simply connect an HDMI cable from your laptop to your LCD TV and make sure the input on the LCD TV is set to receive A/V from the HDMI port.
Jan 11, 2013 | LG Televison & Video
Where to connect my pen drive in my sony bravia lcd klv32s400a?
Hi Radhika,
Your TV has USB port on back side. Just plug your pendrive there. Then go menu on TV ( use your remote commander) and go to this input. Your TV will read the file on pendrive accordingly.
Regards
Oct 03, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
How to turn on rgb from lap top to tv.
In order to connect your laptop to your TV using RGB, you need an RGB adapter. RGB is also known as component video; it breaks up a video signal into red, green and blue. laptops do not have RGB outputs. However, many laptops have VGA, DVI or HDMI outputs. An RGB adapter connects the single VGA, DVI, or HDMI cable to an RGB cable, which is actually three different cables tied together. INSTRUCTIONS:
1. Connect either the VGA, DVI or HDMI (in the order of increasing video quality) cable to the VGA, DVI or HDMI port on your laptop, depending on what is available. 2. Connect the other end of the cable to the side of the RGB adapter with the single input. 3. Connect the RGB cables to the red, green and blue ports on the other side of the RGB adapter. 4. Connect the other end of the RGB cables to an available component input on the back of the TV. 5. Tune the TV to the component video input you used through your television's menu. 6. Turn on your laptop. The laptop should now display on your TV screen.
May 30, 2011 | Computers & Internet
I have LG 26LCD TV. I am unable to see the display when i turn on the TV. Sound is fine. Same happens when i connect TV through HDMI/RGB port. Is LCD panel faulty? How much will be the repairing cost for...
sounds like a faulty lcd panel but you will be suprised how many we used to get back where it was something simple like the wires not being connected to the power supply for the screen. the lcd panel is very expensive to replace, nearly as much as the tv itself.
Nov 29, 2010 | LG 26LD350 26 in. TV
I hooked up a compter to rgb-pc port and selected rgb-pc input and started computer the display comes up ok then it says invalid format how can i fix this russellwidmark@aol.com
CHECK YOUR GRAPHICS CARD DISPLAY PROPERTIES IE:
REFRESH RATE FREQUENCY 55HZ 75HZ ETC. YOUR TV MAY ONLY WORK WITH THE CORRECT REFRESH RATE AND COLOUR RATE CHECK YOUR USER TV MANUAL FOR SETTINGS
Aug 25, 2010 | LG 32LG30 32 in. LCD HDTV
I bought a 32LC5DC Lg tv from an hotel auction. The side panel doesnt work. The thing I need to find is how to access the "setup menu" inside the regular menu. I can get into the regular menu just fine,...
The only thing that would cause this is a lock!
If you ever forget your password, key in ‘7’, ‘7’, ‘7’, ‘7’
on the remote control.
If unlocking does not free up the unit menu then the unit has most likely had a software upgrade at some point to disable these functions permanently. This is normal hotel based systems in order to prevent them being used if they are stolen. In this case you will have to contact LG directly with Model no and Serial No details to get them to assist you.
Oct 01, 2009 | LG 32LC5DC 32 in. LCD HDTV
LG 32LC5DC 32 in. LCD HDTV Logo
1,851 people viewed this question
Computer Repairing
Computer Repairing
