Question about Plumbing
Leaking under ground pipe what water company says..........cant find a leak . grounds not wet any where no water under the house .how can i find the leak with out a plumber? cant afford one....lol
  • 26 Answers
This sounds like a joint is leaking just but not enough for the water to surface try digging the main line from the meter to the house be careful not to damage any lines under the ground and mind any gas and electric lines. once you find the water line out of the meter trace it to the house as soon as you start digging into mud your gitting close to the leak. once found remove dirt so that repairs can be made
Posted on Dec 14, 2008
Why is their about 15 gallons of water built up under my house within a couple of days, but no visible leaks?
Drain pipes might go under the ground. You have slab leak. Plumber will figure it out, or check blue prints of Your house if You have those(will show You "What Where")
Jan 29, 2015 | Plumbing
Jeep patriot leaks water intermittenly
This could be what is referred to as a cold leak. That is a leak that only is present when the temp. drops, and the metal pipe shrinks. Also it could be the a/c leaking water. Is there coolant on the ground under the vehicle or is just water?
May 25, 2014 | 2008 Jeep Patriot
Water is leaking from the pipe on the top of the tank (Reliance 606 electric) where the hot water comes out and goes into the house. Likely causes?
If tank is rusted out, then that is caused by depleted anode rod, or tank that is not electrically grounded on hot side pipe.
If pipe nipple is rusted out, then that can be caused by improper connection between copper and galvanized pipes, and caused by non-grounded hot water pipes.
If tank is leaking, replace it.
If nipple is leaking, remove with pipe wrench, apply teflon tape or joint compound on threads, and install new nipple. Replace anode rod if possible. Correct copper-galvanized connections. Add ground wire between hot and cold pipes.
http://waterheatertimer.org/Leaking-water-heater.html
http://waterheatertimer.org/Replace-anode-rod.html
Aug 25, 2011 | RELIANCE ELECTRIC WATER HEATER
My meter has registering over 86,000 gallons of water used over a 2 month period. Plumber has checked inside and outside of house and no leaks. We did the check where you turn off the house water and...
Patti, check outside around the outside water spigots. to see in the earth around and near the spigot(s) is overly wet or moist. Someone may have been turning them ON when you weren't at home or a night, as a practical joke. If so, it was a sick one. Also, have your municipality , who provides the water to check "their meter", as something may terribly wrong with it mechanically. Do not accept "No" as an answer. Did you plumber consider a leaking under ground pipe from the meter to your home? Especially, if it is a galvanized pipe, instead of copper or plastic.
Hope this provides more info to consider. Thanks for choosing FixYa.
Aug 04, 2011 | Heating & Cooling
My well is kicking on every 3to4 min.I have shut the water of at the whole house water filter and still no change.I have shut the well off and try to empty the pressur tank but cannot get it to empty out.I...
The problem is not in your pressure tank. Its in the well pipe going to the well, or down in the well casing. You have a leak in that pipe. This lets the pressure go down even when you have the whole house shut off. If you have a submersible pump, you will have to have it pulled and the pipe replaced. If its in the pipe going from the house to the well casing, you will have to dig it up and find the leak. Usually you will see water coming from the ground or the ground sunken in if there is a leak in the pipe from the well to the house.
Jul 24, 2011 | Plumbing
Several months ago i had a drainage problem where the water was coming into my house. it was a bad pipe that was causing the problem. they had to did my front lawn up to take the old pipe out they...
hi,
they may not have fixed the leak or its leaking from somewhere else. make sure all the water is off in the house open up your water meter box and watch the water meter gauge closely to see if your leaking. use a strong torchlight to identify the leak.. if the leak is after your water meter, your paying for that leaky water seeping into the ground, if the meter is moving, I would have the company that fixed that pipe come back out and tell them your meter is moving when you have no water running in the house.if the meter is not moving then I would carefully dig it up to see exactly whats going on. if its not leaking at all then I would suggest some gravel first then the rest dirt.
good luck
jm
Oct 03, 2010 | Garden
How can i stop coolant leakage from my chrysler cirrus 2000
Depends where it is leaking. If it is leaking on top of the transmission bell housing it is probably the o ring on the back of the thermostat housing. (there is a rather large tube that carries coolant from the water pump on the other side of the engine to the t stat housing.) If the leak is passenger side it could be the water pump or the o ring on the other side of the earlier mentioned tube ( the tube runs under the intake manifold in the V of the engine). Other areas it could be the heater hoses or the upper or lower radiator hoses. Also a bad head gasket will do it also, signs of that can be water in your oil ( oil that is tan in color is a sign of moisture ) but you still can have a blown head gasket without water in the oil. A leaking heater core can also be a problem (wet area on the passenger side floor can be a sign of this) Also a worn radiator cap can leak into the overflow bottle and out on the ground. A sign of this is a over flow bottle that is completely full inspect the rubber seal an the cap or just replace it. The t stat housing problem is unique to the 2.5 v6 and the housing is tricky to remove. I described this procedure on wiki answer. Google - Thermostat housing 2.5 v6 water pipe 1996 and you will find it the instructions apply actually to a 1999 but is similar for most chrysler 2.5 v6's
Jul 25, 2010 | 2000 Chrysler Cirrus
Saeco Royal water leaks out and now blows wall plug if plugged in
Clean behind the brew group - pull out the brew group and use a pipe clean in the little water weep hole in the back. then use pipe clean down from above the weep hole - it will be full of very wet coffee grounds.
Dec 27, 2008 | Saeco Vienna De Luxe Espresso Machine
Plumbing Logo
261 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
