Question about Coby TF-DVD7377
How to make it region free
Is there any hack for coby tf-dvd7377,pls help.
  • williepenz Dec 15, 2008
    Brilliant, thanks for the help, now i can enjoy all the movies around the world.
  • Anonymous Mar 12, 2009
    Somebody can tell me how can hack this player to region free please?
    Coby TF-DVD7377
    Thanks
    hvirgili@yahoo.com
    Master:
  • 479 Answers
Dvd region free codes site
http://www.dvdhacks.co.uk/ check out this link . hope this helps
Posted on Dec 12, 2008
How can i convert my portable dvd coby tf-dvd7380 to multizone?
check the internet for either a firmware region hack via a CD-R or maybe you can use the remote with the correct sequence of codes.
I suggest that you search on http://www.dvdhacks.co.uk
May 31, 2010 | Coby TF-DVD7380 Portable DVD Player
After disc insertion it says"No disc"
bad spindle motor or bad lens ribbon
Nov 15, 2009 | Coby TF-DVD7377
Need to unlock tf-dvd7008
Step 1- open the DVD tray
Step 2- Press the "MENU" button on the remote control
Step 3- Press" 8888"
Step 4- Press the " DISPLAY" button
Step 5- Select your region. I would suggest enter " 0", this will make it a all region player.
Step 6- Press the " SETUP button to exit.
Mar 31, 2009 | Coby TF-DVD7006
Coby TF DVD7107 region free hack doesn't work
Step 1- open the DVD tray Step 2- Press the "MENU" button on the remote control Step 3- Press" 8888" Step 4- Press the " DISPLAY" button Step 5- Select your region. I would suggest enter " 0", this will make it a all region player. Step 6- Press the " SETUP button to exit.
Nov 10, 2008 | Coby TF-DVD7107 Portable DVD Player
Unlock codes
Go to www.videohelp.com What you are looking for is a region free HACK. Put in your machines numbers, hit search, scroll down,lookto the right for HACKS. If your machine is newer- it might take a month or two for the hack to get posted.
Jul 01, 2008 | Coby DVD-915 System
Unlock the coby DVD-755 to free region use
I believe this works - I've yet to try it myself! Coby DVD-755 1 user region code/hacks August 13, 2007 Post region code/hack comment Region code hack posted by Peter, August 13 2007: DVD -755 from Walmart home theatre for $79.00 1-Press ?Setup? 2-Press Vol +, Vol-, Vol +, Vol -, 3-Number shows up 4-Change the region code by using RIGHT arrow. 5=Press ?Setup? to exit. Succesfuly tested bt Peter F.
Jun 29, 2008 | Coby DVD-755 System
What is the hack to make dvd player (portable) coby tf-dvd7333 multi region?
Press SETUP
Press FF
Press FR
Press Next
Press Prev
now region code will appear on the screen on the right upper part of the screen
press -> the arrows to chancge the number to 255 to make it open region.
Jun 18, 2008 | Coby Televison & Video
Need a decrypt code?
You can use the same as that for the 7050 model. You NEED to use the remote control, press setup and then ffwd, frwd, fwd, rwd in sequence, it will appear a number. Press the right arrow key until it reaches 255 (it is fast, it jumps from 001 to 255), to get out, press set up again. You know can read all regions. In fact this is the same fix for the 7050 model.
Dec 16, 2007 | Coby TF-DVD7060 Portable DVD Player
COBY TF-DVD7060 SAYING WRONG DISC
In Remote Control:
1) Press SETUP
2) Press Fwd (»)
3) Press Rwd («)
4) Press Fast Forward (»|)
5) Press Fast Rewind (|«)
Original region number (1 to 6) will appear - uses arrow keys (Navegation) to change to 255 (ALL Regions).
A couple notes:
- The keys referred to in the above hack are on the remote control (not on the front panel). But, if you want, you can use the front panel to implement the hack – just use the key equivalents (i.e., for SETUP, press Mode twice; for », press and hold »| for 2 seconds, and so on ).
- When the Region Number appears, it is in the upper right corner of the Set Up window without any label. In other words, if your player is currently set up for Region 1, look for the number 1 to appear in the upper-right corner of the Set Up screen (once you've pressed the correct sequence of fast forward and reverse keys). Then use the arrow keys to toggle the number to 255.
If you remove the main battery, you might have to do the trick again.
Enjoy.
Sep 05, 2007 | Coby TF-DVD7060 Portable DVD Player
Coby TF-DVD7377 Logo
412 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
