Question about Maytag HAV3460AWW Top Load Washer
Maytag washer water doesnt stop
I have an older maytag washer that has four fill levels. I can only use the lower two, since the high and extra high over fills the washer - doesnt stop either. Selecting the small and medium level buttons fill the washer to the large and extra large levels.
  • 1 more comment
  • mark_plessin Dec 15, 2008
    You were exactly right!! Removed front panel, lifted top panel, and moved the top panel up and to the back. Pulled the tube that connected to the tub and the other end, the small tube, goes to the back of the panel that the level selector is (vacuum selector?). Took that entire tube out, and was filled with slimy crud. Cleaned that all out, put it back in, and it runs perfectly!! No more floods. Thanks!!!
  • Anonymous Mar 16, 2014
    maytag centennial washer. less than 2 months old. when set to super water level it starts to fill, stops and drains, then nothing. I reset and it does the same thing. any clues?
  • Anonymous Mar 30, 2014
    How to repair water level indicator
  • 1,028 Answers
Raise top or remove front panel(can't remember which) rear corner left small hose attached to connector on tub pull and clean probably plugged up with crud also ck connection on tub
Posted on Dec 13, 2008
Washer will not fill on large load
are u saying water level will not fill to high but will for lower level? If so check ur water level pressure switch with a multimeter
Dec 23, 2014 | GE WSLP1500JWW Space-Saving 3.1 IEC Cu....
Water level is too high
would check ur water pressure switch myself
Oct 01, 2014 | Maytag Centennial Series MVWC200XW
Washer won't stop filling with water
What's the model? Could be a bad water valve that's stuck. If it's an older top loading washer, it could be a bad air dome hose that senses water pressure.
Jan 12, 2014 | Maytag Washing Machines
Fws445rf1 washer didnt stop filling and flooded my apt and it doesnt aggitate when it is washing,the whole thing just spins inside instead of moving back and forth,what are the most likely reasons for...
if it's a top-loader, then the water level sensor is probably failed! if an older machine- there's a plastic tube (which you can't see from the outside) that measures the column of water in the tub of your machine, and triggers the agitate and spin, and rinse cycles of your machine.
when it's in wash cycle the water level is lower, then it spins and drains and the rinse cycle pumps in more water (makes sense!), then drains & spins, then re-rinses at the same water level. your water level sensor is defective, probably. allowing it to over-fill.
it detects the water level as 'spin' and doesn't agitate!
my theory- no guaranty! if it's old get a new washer or a good used one! this is not a problem i've encountered, just a guess. good luck!
Apr 17, 2010 | Frigidaire FWS445RF
Washer didnt fill when turned on, but filled when holding "reset"
sounds like your water level switch is bad OR the small hose that goes from the waterlevel switch to the bottom of the tank has a hole in it.Try replacing this small hose can go to an auto parts store and match it's usually about 3' long and about 1/4" inside diameter and about 99cents a foot.
Aug 26, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
Maytag Washer PAVT-1 continues filling with water to overflowing
Does it still do this with power to the machine off? If so it is your water fill valve. Because no power is getting to the valve it has to shut off unless some foreign particles are holding it open. Remove and replace the water fill valve if still runs water after power is off.
Here are some things on how the selector switches work: If it stops when you remove power look at these possibilities.
Water fill switches usually have an air tube that as the water level comes up the air pressure increases and causes the switch to go from fill to wash.
I have seen rodents chew holes in the air tubing and this could be the cause or you may have a bad switch.
Some times the switches also get out of calibration and need readjusting (especially if you have moved in altitude like up a mountain or into a valley).
If this helps you please rate me as high as possible.
If it doesnt help you please rediscribe your problem in more detail to help me understand, post back and I will follow up.
Nov 15, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag W-7 Washer water fill does not stop
Yes, I think that rubber tube measures water level. But I've never changed one. Good luck.
Aug 02, 2008 | Maytag Washing Machines
Maytag washer
Check to make sure your drain hose has a loop at least as high as washer top.  If the drain hose is not looped higher than tub water will continue to drain and it won't stop filling.  If it doesn'y reach the correct fill level it won't agitate.
Oct 29, 2007 | Maytag PAV2300 Top Load Washer
Maytag stacked washer/dryer Model LS7804
OK it may be one of 2 things. I would check the lid switch first. On some maytags the have a lid switch that if it is not working properly it will not let the washer fill. If it will not fill the washer will not wash because the pressure switch did not activate the timer to wash. If the switch checks good you might have a bad timer. If you open the control panel you will find a tech sheet with the wiring diagram. I would follow the fill cycle and check the components. You might also check the water valve to make sure its ok too. But its very rear that both the hot and cold would go at the same time. Good luck!
Jul 11, 2007 | Maytag LSE7806A Top Load Stacked...
Maytag HAV3460AWW Top Load Washer Logo
246 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
