Question about Mitsubishi WS-65611 65" Rear Projection Television
Device menu continously selecting input devices
My Mitsubishi 65" rear projection TV turns on with the device menu on the screen and it is continuously highlighting or selecting the inputs, but does not change them. The TV does not respond to any menu selections, it jsut keeps scrolling through the inputs. I fixed this once by pulling the input card from the board and powering up the unit which I assume caused it to reload the input software, but that only lasted a couple of months before it started doing the same thing and now pulling the input card does not fix the problem. Any help would be appreciated.
  • 2 more comments
  • Terrence Davis Mar 11, 2007
    Yes. I've tried both the reset button on the front of the TV and also a hard boot without any luck.
    When I got it working the last time, I pulled the ASSY-PWB-2HDW board and power the TV on without that board. Next, I replaced that board and pulled the ASSY-PWB-3DYC/MD board and again power on the unit. I replaced that board, powered on the unit and everything worked, and has been working for about 4 months and then it started the same device menu scrolling when my son tried to change imputs from DISH to PS2.
    Fixed! I found another post where someone had a simular problem. Seems as though I either have a stuck "Device" button on my remote or the "Device" button on the front panel of the TV was stuck. I pulled the batteries out of my remote and cleaned the front panel buttons with air pressure than moved the buttons on the front panel, with pretty good force, to see if they were stuck. When I forcebly pushed the "Device" button the menu quit scrolling and I was able to make device changes.
    I'm not sure how pulling the boards the first time fixed it except we were pushing the front panel buttons at the same time and probably un-stuck the button at the same time we pulled the boards.
  • Dragon1678 Apr 22, 2008
    I had the same problem, the remote was not working at all; but I can use the TV buttons to turn on, and it stayed on one mode (device mode) only, can not use the Device button to made changes.
    I fixed it by using AIR DUSTER to blow the Device button from outside to clean it. After that, everything works normally. My remote also works.
  • buckeye1010 Apr 03, 2009
    I just had the same problem after coming home to a cold house (64 degrees) after being away on vacation all week. I used compressed air on the input and the right select button, at it worked!!! Thanks for the help everyone above!! (set: MS65611 - 6.5 years old)
I tried the air trick but no success. I took the boutton PC out examined it, tryed it sitting out of the casing still no success. I put it all back together plugged it back in and Wha- la it worked good as new. I am not sure what changed but I thought it would be good info for anyone else that sees this problem. You gotta love the intrnet.
RA
Posted on Aug 30, 2008
Many thanks!
We just fixed our Mitsubishi with a clean empty plastic bottle that blew air onto the front panel buttons and fixed our same problem as you described. Hope it stays repaired!
Thanks again as we were stumped as to the repair.
Posted on May 12, 2008
    President:
  • 1,284 Answers
Did you try resetting using the RESET button on the front of the TV? Also what "input" card are you pulling?
Posted on Mar 10, 2007
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
I am trying to connect my laptop via VGA cord to my 65" Mitsubishi Medallion, but when I click on the VGA device selection in the device menu, it goes to a blue screen and says "Warning: Turn on...
Press the Windows key + P on your laptop.
Or, if that doesn't work, look on your F keys for something that looks similar to a monitor.
Press the FN key and that key.
This should bring up your laptop's display on the tv.
Mar 09, 2011 | Mitsubishi WS-65809 65" Rear Projection...
I have a Mitsubishi WS-65513 65 in. rear projection HDTV. I recently hooked up a DVD player to the Component 2 cable inputs but I cannot find the Component 2 selection on the 'Device menu' to tell the TV...
If one or more of the inputs is "missing" or not there you may need to do a hard reset of the TV with the original remote.
If you want to try this confirm the actual model number and I will tell you how to do it.
SD TECH
Dec 11, 2010 | Mitsubishi WS-65513 65" Rear Projection...
TV will not respond to/recognize remote. I have
Check On the Menu Setup for On/Off Remote utility Maybe your Remote signal is off on the TV Set...
Sep 22, 2010 | Mitsubishi WS-65611 65" Rear Projection...
Green blinking light
needs to be reinitialized press menu 8970 to reset
Oct 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Problem with device menu & remote
Remove the front trim plate below the manual switches, may have to remove the speaker covers to access this area, remove the switch mounting plate 3 screws, turn switches over and unplug the little white electrical connection for the switches. TV should work perfect with the remote now. Not sure what is wrong with the switches just yet, but suspect a resistor problem.
May 17, 2009 | Mitsubishi WS-65711 65" Rear Projection...
Don't know which input the matches which device icon on screen
if you look on the back , the inputs are labled, then go into the tv menue and go under device lable and match the input it is plugged into, to the dvd icon
Jan 07, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Cannot change my Mitsubishi WS-55615 to switch from 480 to 1080I
You cannot change the setting on the TV itself. you need to go through the settings on the equiptment you have plugged into the TV to change their settings to display a different resolution.
Sep 15, 2008 | Mitsubishi WS-65413 65" Rear Projection...
MITSUBISHI 65" RAER PROJECTION TV MODEL-WS 65511
Try to press both the menu button and the input/device button on the set both in together and hold in for 6 seconds to see if the led will blink a two digit blink code, then let me know the two didgit code, and I will try to assist you. Please respond to this same post when replying.
Aug 08, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WD 52525 & PS 3
First make sure your hdmi cable is connected from the PS3 to the TV. Then go to netcommand, review, and make sure "monlink" is checked, click next, and finish. Select "monlink" from your device manager and turn on your PS3. If the screen is blue, go to the next step. Connect the PS3 via regular a/v cables to the front panel "input-3". Create a net-command device for input-3 as well. Switch to the input-3 device you created and turn on your PS3. Choose display settings, and change the settings to HDMI. Then click change. You'll have 30 seconds to hit device manager, change the device to "monlink", and let the PS3 unit know the setting has worked. From there you can configure. Good luck!
Dec 25, 2006 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS-65611 65" Rear Projection Television Logo
287 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
