Question about Kenmore Elite HE4 Electric Dryer
My 90 series kenmore dryer won't start
There is power at the plug and I changed the thermail fuse still not working
  • Anonymous Feb 18, 2009
    Dryer won;t start. Relaced the door switch and the thermal fuse....still not working.
  • 291 Answers
Check the door switch to see if its good / if not the dryer wont start
Posted on Dec 12, 2008
Started drying load, dryer shut off. won't turn on. checked door, changed thermal fuse, checked breaker. still doesn't work. light also not on.
If this is an electric dryer, you may have lost half of the power supply to it. Unplug and remove the little cover plate above where the power cord enters the dryer. Look at the 3 screws holding on the power cord for burned/black looking or loose connections. If nothing wrong there, shut off house breaker and remove cover on house plug where you plug the dryer into and look for same type of issues.
Mar 17, 2015 | Kenmore series 70 80 90 Dryer Motor...
Where to find fuses. My dryer is not heating up.
Does your dryer have power? If yes, then check (1) the flow of air outside the house from your dryer tube and (2) your circuit breaker panel for each circuit in the house (I've not seen fuses/breakers built into dryers -- though that could change). Then check (3) your heating element, (4) thermostat, (5) high-temp thermal cutoff switch, and (6) for debris in the air flow path to / from from the centrifugal fan.
Here are 3 resources that helped me with my Kenmore Series 90 Dryer:
No Heat? -
Looking Inside My Dryer -
Exterior Exhaust Duct -
Oct 10, 2014 | Kenmore Dryers
Fuse out on kenmore electric dryer 90 series
The fuse on most Kenmore series dryers is located on the blower housing where the squirrel cage is that blows the air out of the back of the dryer.
Apr 21, 2012 | Kenmore Dryers
Kenmore 90 series dryer..motor won't turn..hear the klicking sound..kind of hums...but won't turn. changed motor..same problem
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Aug 11, 2011 | Dryers
Kenmore 90 series electric dryer qiuet pak 1 101649022200 the lights are on when you open the dryer but the dryer itself will not turn on or do anything!
There's thermal fuse on the blower that blows when the cycling thermostat malfunctions or the lint/vent duct are blocked. This thermal fuse is wired in series with the dryer motor and if it blows, power to the motor is terminated causing the dryer not to start and no dryer function works. Check to make sure that the lint filter is always clean and the vents are clear. Click on the link below for the detailed troubleshooting of the dryer, particularly the thermal fuse, when it doesn't start.
Troubleshooting Not Starting Whirlpool and Kenmore Dryers with Lint Filter on Top
Feb 09, 2011 | Dryers
Kenmore series 90 electric dryer won't start. checked thermal fuse and timer runs but drum won't turn
The motor of drum is not work . Just check the motor and power feeds to it
Jan 14, 2011 | Kenmore Dryers
Kenmore 90 series dryer, motor wont start, loud
  • Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
  • If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
  • Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Hope this will fix your problem for sure.
May 10, 2010 | Kenmore Dryers
Kenmore series 90 dryer(5 years old). Power ok
have you checked the start button?
Jan 30, 2010 | Dryers
Kenmore 90 Plus Series, no power!
yes there a fuse in the front dryer it is white thermo fuse ck it
Feb 28, 2008 | Kenmore 63942 Dryer
Kenmore Elite HE4 Electric Dryer Logo
799 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
