How do i connect and listen through the speakers on my dell intel pentium windows vista inspiron 1720 laptop
SOURCE: Windows Vista crash/hang in Dell Inspirion 1525
Disable the turbo memroy driver and see if it will let you go onlin, if so download the driver or updated driver (if any), then unistall and reinstall it. If it won't allow you to do this, then try a system repair with your recovery or operating system disc.
SOURCE: retstoring a dell inspiron B130,
Hello!
in restoring to the factory setting you need a recovery disc id the system is license to miscrosoft. if your have no recovery disk you should provide a windows XP installation bootable disk. insert the disc in cd/DVD rom and boot the system in CD/DVD rom.
Installation of windows is instructed here; http://support.microsoft.com/kb/316941
may this help you. melnavz
SOURCE: Dell Inspiron 6000 with network card Intel/Pro Wireless 2200 BG
So u can connect to the router, but you arent allowet to access the internet?
The router gave your dell a new ip-number, but it dident gave you access to the net. You ned to do the settings in your router manual, let the router give your dell full access.
Good luck
SOURCE: suddenly no sound on my dell inspiron 1720, vista, sigmatel
COPY UR IMP DATA O OTHER DRIVES AND FORMAT UR WINDOWS.
BEST SOLUTION.
AND DONT INSTALL UPDATES
SOURCE: BOOTMGR is compressed
You are best off checking to see if you can get to the system restore point from the main menu of XP, assuming you can get that far. If XP starts then you can Click Start, click Run, type %SystemRoot%\System32\Restore\Rstrui.exe, and then click OK and follow the numbered procedure below.
If not then You should also have a system restore disk suopplied witht he laptop so run this to restore your system back to original setup. If not then use the XP boot disk and trhen let it start and when prompted choose the restore option (usually R) when prompetd on the first screen. Then select the default Windows XP install (usually option 1 and press return when prompted. If you have a system admin password enter this when promted or just press {Return}. This will take to to a black and white text based screen and you sold see a C:\ prompt. Type the following:
cd C:\windows\system32\restore then hit {Enter} or {Return}
then type the following
dir rest*.* then hit {Enter} or {Return}
you should see a list of files including one called [rstrui.exe]
If you see this then you can tyope the following
rstrui then hit {Enter} or {Return}
this will then allow you to choose a date and time to restore the system to. Follw the procedure below.
