Question about Philips 32PF7321D 32 in. LCD Television
Main Board for a 32" LCD
I am getting ready to open up the TV. A repair man charged me $60 to check it out. He said it needs a 'main board' he wanted $410 to fix it. I picked it up and am trying to fix myself. Other wise it's going in the trash.
  • snelson_ga Dec 12, 2008
    Thanks, I will probably be hollering for help.....
  • 116 Answers
Its fairly easy, just be gentl, dont force anything, make sure its unplugged (duh right), try to keep the screws seperated so you know where they go, if you need help holler
Posted on Dec 12, 2008
  • Justin Washburn Dec 13, 2008
    Just let me know when you go to open it,
Does the main board for element tv control the picture
There are two board which controls the picture. The TCON board and the main board.
If you wish to get some details about LCD TV repair then check the following link.
http://electro-medical.blogspot.com/
Jul 24, 2016 | Element ELDFT501 50" LCD TV 1920x1080, 60...
How to repair a 39 inch LCD tv model RCA..39LB45RQ....I have no stand-by power light
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Mar 10, 2016 | RCA 39LB45RQ 39" LCD TV 1920x1080, 60 Hz,...
I brought Sony Bravia KLV-32U300A 32 in. HD-Ready LCD TV 4 years ago now it's screen fill with lots of tiny lines difficult to see pictures. i submitted it to service man. he told me problem is on...
This is the main fault, that most Sony LCD TVs. The actual cause is with a faulty T'Con board. For most Sony LCD sets, this part [T'Con board]; will be a built in part with its display panel, and can't be replaced. Display panel replacement is the only repair work. Nothing can be done, even for the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Mar 03, 2016 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Hello. My 32" Emerson TV has no power. Standby light doesn't come on when its plugged in.
Nov 20, 2015 | Emerson LC320EMXF 32 in. LCD TV
TV Sharp Aquos LC-32D44E/S doesn't come on Status light turns green for 10 seconds then turns red but no picture or sound.
Good day to you and welcome to fixya..
That problem is usually have 2 causes..Its either power supply board or main board..
Please take this steps on how to determine the problem:
1. Open the back cover.
2. Check the power supply output...It should have 5vdc for the main board..12vdc or 16vdc for the audio and 24vdc for the back-light inverter..
3. If those 3 voltage supplies have encountered voltage drop...The problem could be on power supply board..
4. If the power supply output is normal..The problem could be on the main board...
5. If the problem is power supply you should check if the capacitors are bulged on the top and try to replaced it..If you can't do that you can purchased new power supply board..
6. If the problem is on main board there is no D.I.Y repair on that so you need to buy a new main board that fits to your TV..
You have a better chances if you have failing capacitors on the power supply board..
Please watch this videos about capacitors..
Hope this solution will be helpful..
Thanks for using fixya...
Aug 13, 2011 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Red light blinks when tv is turned on., and tv flashes Sony and then nothing-blank screen. Red stilkl keeps flashing.
Good day!!!
That problem is usually have 2 causes..Its either power supply board or mainboard..
Hope thissolution will be helpful..
Aug 11, 2011 | Sony KDL-32EX400 32 in. HD-Ready LCD TV
Olevia LT30HV display goes black, having voice
contact the manufacturer for warranty if not go to www.shopjimmy.com and check for the main board of your product, same thing happen to my element tv manufactured by hisense called them wanted 150 for the main board tv repair man worst he just fix the same main board you have charge you arm and a leg the good thing was he told me it was the main board cause its the one incharged of your display and all your inputs ok at shop jimmy got it cheaper then the manufacturer and the tv guy god bless him well thats all i can tell you and you are welcome
Apr 14, 2010 | Syntax LT30HV 30 in. HD-Ready LCD...
Samsung LE32R41BD - no picture, only a very dark blue screen
yes go to www.shopjimmy.com get the main board of your tv and replace it lcds usually have 2 power supply and the main one thats the problem tv repair man told me it incharged of all your inputs sound and picture but he was charging too much and the manufacturer too 149.00 shop jimmy 108 with shipping glad too help you and you r welcome and it aint no science to do it your self do it on top of your bed thats how i did mines in order to get the model number have to be real careful with the screen oh and you r welcome
Apr 13, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
8 blinks from a sony bravia model klv-32s400a tv
8 blinks in KLV-32S400A shows Audio Error
Check audio voltage supply from power supply board, if OK, replace GP Board (main board)
and if audio volts are not available, check/ replace power supply board.
Feb 09, 2010 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
LCD tv main/digital board
Send it to us and we will refurbish the board.....
e-mail me....circuitworld@comcast.net
Feb 11, 2009 | Toshiba 32HL67 32 in. LCD Television
Open Questions:
Philips 32PF7321D 32 in. LCD Television Logo
108 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
