Question about Intel D101GGC Motherboard
Graphic Card Problem
The monitor stopped working one day although everything else seems to work fine.We connected the moniter to a different computer and it works,we changed graphic cards in the computer and still nothing on the monitor. The computer is still working (we can acces info on it through in internal network) but the display is dead so we cannot work with it.
The motherboard is an intel motherboard D865perl and does not have an on-board graphic card.
Would appreciate your help in finding a solution.
Thanks !
  • isiyboy Dec 13, 2008
    this is a desktop not a laptop. Thw card and the Motherboard arecompatiblesincethecomputer worked fine before. This problemoccured moving the computer. The drivers were installed.
    Any ideas ?
    Thanks
  • isiyboy Dec 16, 2008
    Thanks. Already tried installing a new graphics card (only hardware since there is no display in order to install software) this did not help.
    Any ideas / solutions.
    What else should I try before changing the motherboard.
    Sergeant:
  • 237 Answers
There could be many things besides the graphics card. To start however, make sure your laptop recognizes your card and its drivers installed. Make sure your card is compatible with your motherboard. what is the model of your graphics card?
Posted on Dec 12, 2008
  • zabrina liang Dec 13, 2008
    Okay then, if you did not install a new graphics card, this would be a good time to try
  • zabrina liang Dec 16, 2008
    The very first thing you should try when you have this problem, is to connect your computer to another monitor if your monitor is the issue. If it works, just get another monitor=)
WHY IS THE GREEEN POWER BUTTON FLASHING ON MY MONITER AND THE SCREEN THEN GOWS BLACK
When the power light is flashing the monitor is not getting a stable signal. This is hard to answer without direct troubleshooting. Check the cables first, make sure they are connected securely. If you still have problems test another monitor you know works or move monitor to a computer you know works, this will determine if the monitor is the problem or not and tell you if it is your "graphics port or adapter". If another monitor works fine, use the working cables to test the "broken" monitor. If you have an "all-in-one" computer, ignore the above steps and use a start-up repair disk. The reason this is hard to troubleshoot is there are so many things to diagnose. More than likely your "graphics card" is failing. These are some tricks to repair. You can update the driver, buy a graphic card separate from the stock port.
May 21, 2016 | Dell E172FP 17" LCD Flat Panel Monitor
Computer turns on but I get a no signal sign on the moniter
If your computer has a video card try connecting the monitor to the motherboard video.
Mar 14, 2013 | Dell OptiPlex GX620 PC Desktop
Computer starts but moniter stays in sleep mode .. moniter works on different comp .. will adding a vid card to my comp fix this problem ??
Actually, Yes. It seems like you have answered your own question... Especially considering the monitor works on another computer.
Do you have another monitor to test on this computer?
Although another consideration could be if you recently installed or downloaded a program which may have changed your video output range to a setting your video monitor wont handle. If this is the case and you can start the computer in safe mode, this will allow you to go into your properties settings and change it back. This way, a new vid card is not req.
Good Luck
Sep 14, 2012 | HP Compaq dx2300 Microtower - RT950UTABA...
I boot up my computer which has a ATi x1650 PRO AGP 512, everything turns on including my video card (the fan turns on) and I get a no video input on my moniter I am using VGA cables to connect the...
The problem can be a few things. You could have a faulty motherboard, graphics card or monitor. if your computer has an on board video, I'd remove the ATi card, and try booting with that. if you have a friend that is willing to help, use their computer to swap the video cards and monitor. your looking to see if each component is working on it's own.
I also suggest writing down every step you take, may seem like it's not needed, but it'll help you if you need to post more info.
Note: Having fans turn on is not an indication that a card is working, just that power is being applied. It can cause a lot of confusion by overlooking some thing.
Mar 03, 2011 | ATI RADEON X1650 Graphic Card
My monitor says "no input signal" every time I put it on. I have checked all the wires and connections and they seem fine. Any suggestions?
Starting from the monitor and going to the video connection to your computer, make sure everything is connected and undamaged. If your video card has more than one output, try switching the cable to the other output. If neither is working, and the monitor works fine from a different computer, then its the video card, otherwise its the monitor. But again, before dropping any money on a new monitor, try a different cable, and try switching the cable to the second output if there is one. A video card is definitely cheaper than a monitor.
Aug 22, 2010 | HP Computers & Internet
My pc moniter goes all manner of colours and wont work
I would recomend checking both ends of the connection cable to make sure they are secure and fully connected. If they are and it is still giving you trouble you can try using the monitor on another conputer. If the issue stays with the monitor then it is time to replace it. If the issue is only on your pc then it could be an issue with your video card/chipset.
If that is the case you can atempt to reinstall the video drivers by downloading updated drivers from the mfg web site for your video card. If still having issues then it may be time to replace/upgrade your video card to a new one.
Apr 01, 2010 | Computers & Internet
ONLY STREAKS OF COLORS when TURNING ON!
the problem is the update you downloaded someone mixed with your graphic chip.. causeing it to only display dots and lines. the hp logo with the back round is the start up page. here are 2 ideas you might wanna try.
1. if your graphics car is in a AGP or PCI, pull it out and try useing the default card build in the computer.. if it is the default go out and bye a cheap graphics card and see if that works.. if not return it and get your money back.
2. try useing a diffrent moniter.. your moniter might of blown out. if that still dont fix it you might need to contact HP or the moniters manufactuer.
hope this helped!
Oct 08, 2008 | HP Pavilion a420n PC Desktop
Color problems with moniter
check that the data cable is connected firmly, if it is check that there are no curved or brocken pins.
open the computer and firmly press on the graphic card into his socket, close coputer case.
May 04, 2008 | HP Pavilion M70 17" CRT Monitor
Desktop larger than screen
Is AGP enabled in the BIOS?
Apr 08, 2008 | Computers & Internet
Intel D101GGC Motherboard Logo
87 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
