Question about Panasonic PT-47WX49 47" Rear Projection Television
TV powers up for literally a second then shuts down (PT-47WX49)
The TV starts to power up, but then I hear a click and it shuts off. I have to unplug the power source and plug it again to have it repeat the issue.
  • 1 more comment
  • ronanders1 Dec 15, 2008
    On a PT-47WX51E, same exact problem, just started yesterday.
  • crownroyal19 Feb 04, 2009
    On a PT-47WX79E, Chassis DP820, I have the same problem. I checked R517 and it is still good. Would appreciate any other suggestions.
  • Ryan Yerke
    Ryan Yerke Apr 10, 2009
    after a covergence amp replace, replaced with stk-150's and replaced the 6, 2.2ohm 5 watt resistors, turned it on and had picture for like 90 seconds. Picture seemed to jump a bit horizontaly. When to do the convergene lined green up , then went to red, as i lined red up, TV powered off. no led blinks at all. I then have to unplug it then plug it back in, powers up for bout 5-7 seconds, and right as the picture would normally kick on, it kicks off completely instead. problem is repeatable , havent had picture since the first time powering it on after the repairs. no led blinks at all just stays solid till it has the shutdown.
    Problem Solver:
  • 11 Answers
Check R517 on the power supply board if burnt replace with 5% 1/4 watt 10K carbon resistor.
Posted on Dec 27, 2008
Hi, my Panasonic PT47WX49E rear projection tv suddenly shut itself off. It won't turn back on at all unless I unplug it and plug it back in. However, when I do that, the power light comes on but nothing...
Either give me a yahoo or note if light on front of set blinks--count the blinks if it does.
most common is 3 blinks, pause 3 or 5 blinks etc.
Let me know if I can assist you.
SD TECH
Sep 14, 2010 | Panasonic PT-47WX49 47" Rear Projection...
My Panasonic PT - 47WX49 rear projection wont turn on - it would go on for a second and shut down - then 3 red blinks - so i changed out the IC's now it powers on but immediately shuts down and only 1...
Thats the 140 Volt error. Usually caused by the bridge connectors that connect the two circuit boards or the red HV cable from the flyback not being connected properly
Dec 29, 2009 | Panasonic PT-47WX49 47" Rear Projection...
My picture shut off. Power lite clicks, blinks,no picture
how many times is the power light blinking as thats a error code. 3 blinks is the most famous which means convergence circuit failure.
Oct 26, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Question for Guru slinteriors: about Panasonic PT-47WX49 shut-down problem.
the stk392-110 ICs may possibly be bad. I would recomend replaceing the stok 392-110 ics with two STK392-150. You can get replacements at the following link, and they provide free installation instructions
http://servicemanuals.vstore.ca/
Sep 18, 2008 | Panasonic PT-47WX49 47" Rear Projection...
No sound, no picture, power light blinks
i have a model #pt-53wx42f when you first turn the t.v. on it gets shakey and distorted then it shuts down and the power button light starts flashing
Sep 06, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Tv powers off after 1sec being on?
does the led flash when you try to press power after it shuts down, or when it shuts down? If so how many times does it flash?
Jul 18, 2008 | Panasonic PT-47WX49 47" Rear Projection...
TV turns itself off
Sounds like you need a new power supply board
Nov 26, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Help please
called h.v. shut down call tv repair shop
Sep 18, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Power
you have a problem with the Deflection board. Those boards are running hot right out of the manufacture. You need a new Deflection. You spend money on that board, its going to go out on you because of the excess of current,or hear. spend between 100 300. for a new board. your better of.
Dec 01, 2005 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
205 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
