I need a wiring diagram for an INTERTHERM mobile home electric furnace. The original on the inside cover has been destroyed. Model: 431900
I need a wiring diagram for an intertherm/nordyne gas furnase !!!
Posted on May 26, 2009
We have a interthem 2460 a furace and we need to know where to find a wiring diagram to show us how to connect it to the electric
If there is not a wiring diagram pasted inside the furnace somewhere, request it directly from Intertherm. Be sure to specify model 2460.
Dec 09, 2016 | Heating & Cooling
Intertherm feh 015ha
either the heat strips, fusible links on elements or sequencers.
Sep 21, 2013 | Intertherm E3EB010H Electric Furnac
Hello, how do i get an intertherm mobile home heating unit diagram?
Depending on how old your unit is there should be a wiring schematic on the inside of the control panel in the upper left hand corner of burner compartment. Remove two screws to remove cover. I hope this helps you. Thanks
Dec 17, 2010 | Intertherm Heating & Cooling
My mother has a Ultra Flex Inter Therm Model # 431900 heater in her mobile home. Last night she had it set on 65' but it ran & ran until it got up to 80' It will not shut off! It will not turn off even...
If you remove the furnace doors, and find where the thermostat wires come in, leave the breaker off, and disconnect the thermostat wires at the furnace. Turn the breaker back on, if it doesn't run, then you have a short somewhere in the wall, in the thermostat wire.
If this is the case, then the best thing to do, is to re-run the thermostat wire to a closer location.
The moblie homes, older ones, use thermostat wires that are not encased in a plastic cover, and they use metal staples in the wall to secure the wire, so they can short through the wires, and making contact,,, this turns on the furnace.
If the furnace continues to run,,, it is a control issue in the furnace it's self and you will need a repairperson.
If this helps please rate the new guy :)
Thank you ,
Paul
Apr 02, 2010 | Heating & Cooling
Where can I find a wiring diagram for a interrherm
Hi; Call Your local mobile home supply house and they can tell You how to or fax You the Info. Also the equipment will have the wiring diagrams glued to the inside covers of the outdoor unit as well the indoor unit cover. Power down the indoor unit before removing the indoor electrical cover for the schematics. Do You not have a user or install manual. Call your local mobile home supply house they can often help.. Be care full You get more bees with honey so be very nize...alpharome416
Feb 19, 2010 | Intertherm P3RA-036K Air Conditioner
Need intertherm 2515 electric furnace wiring diagram the unit is for a mobile home and has been modified, trying to put back to original . blower will not run in heat mode unless on/ auto switch on front...
Here's a site with a lot of literature, wiring diagrams etc. There has to be more to your model number, which you may be able to match up at that site. If not, give me all the numbers you have, and I'll see what I can find.
http://www.nordyne.com/Literature/MHCatalg.htm#S3/MS3
Feb 13, 2010 | Heating & Cooling
Heater furnace doesn't want to turn on'
Did the fan turn on, if it did when was the last time you cleaned the filter.
Mar 14, 2009 | LG L1004R Air Conditioner
I NEED WIRING DIAGRAM FOR A INTERTHERM ELETRIC FURNACE
Web page or the unit door covers , Intertherm are mostly added to trailer homes and check out a trailer home supply house.
Sep 03, 2008 | Intertherm Heating & Cooling
Heating & Cooling Logo
967 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
