Question about Zanussi F1045W Front Load Washer
Drum will not turn.
I started a cycle. The drum filled with water as usual but the drum won't turn. It can't be turned manually either.
  • jddramoore
    jddramoore Mar 26, 2013
    bearings have seized what do i do
  • 17 Answers
Sounds like you've got something stuck in between the drum and tub the best way to check is through the heater at the rear of the machine. Could also be the motor or drum bearings have seized if its the drum bearings there's usually brown oil coming from the back of the drum. Take the belt off to see if either the drum or motor can be turned manualy. hope this helps.
Posted on Dec 22, 2008
3 Suggested Answers
SOURCE: Indesit wd125 drum wont turn
check your pump it may not be working
Posted on Dec 18, 2008
  • 236 Answers
SOURCE: Re EW1200i : drum keeps filling with water
is it overfilling? if so you have a problem with the pressure side of the system and it would need cleaning out.
Posted on Jun 02, 2007
GE Super Capacity Plus won't stop filling
Does it stop if you stop the cycle or do you need to turn the valve off?
What is the complete model number of your unit?
Feb 17, 2013 | GE 3.2 cu. ft. Washer
Miele w1113. Washer drum won't spin during wash cycle
I assume you are saying the machine is working except the drums not turning? - you need to see if the belt has come off because thats what i would check first if you hear the motor start/stop after it fills up with water.
May 30, 2011 | Miele Touchtronic W1113 Washing Machine
Kenmore washer Heavy Duty (70 Series) 1985-1989
behind the knob that you use to set the water level is the level control it should have a n adjustting screw to set the water level(you can set it where you want)
Aug 20, 2009 | Kenmore 22422 Top Load Washer
Drum will not spin
I am the new owner of a used Asko Cylinda 10504.
The last owner briefly demonstrated the washer starting a wash cycle and entering the agitation cycle of the wash before stopping and pumping the water out and spinning in a final end cycle. I bought it. I had the machine installed turned it on and cannot get it to go through the wash cycle. After starting at #1 it goes through a perpetual spin cycle of sorts--water and soap soaking the drum and laundry but not enough water to fill up half way or less. It stops at number 4 on the program knob sits on a red dot (next to the #4) and does nothing. I then manually move it to the next cycle and it repeats the spin cycle again until I have advanced the program to the end. No wash cycle no rinse cycle. Nothing. When it advances to the red dot I wait for at least 5 minutes before manually advancing the knob. The instructions say that I should get the water pumped out by turning the program knob to #7 or #9 but in both cases it just spins and does no empty or finish in the end spin cycle of several (9?) minutes. Nothing but banging and spinning. The water seems to get into the drum as well as the detergent but nothing else is happening.
No mater where I start the program it spins and sloshes soapy water, pumping almost nothing out.
Any suggestions short of putting it on the curb or paying a kings ransom to fly a tech out to look at it?
MY GUESS.
It seems that it is repeating the same brief cycle over and over. During the move to my house the electronics re set(??!?!?) and now need to be set to the normal mode after being re connected?
Can you help?
Blessings,
Douglas
May 20, 2009 | Asko Washing Machines
Kenmore top load washer will not fill on rinse cycle
Hi, It does sound like the contacts in the water level switch are sticking. This switch is activated by presure not vaccum. You can try and bow into the hose leading to the level switch and see if it has any restriction but, it is more likely the level switch is going bad.
Do you have any problem on the initial starting of you wash cycle?
Let me know if this helps at all or I can answer any more questions.
Thanks
Vic
May 11, 2009 | Kenmore 24032\24036 Top Load Washer
Dec 18, 2008 | Indesit W 123 Front Load Washer
Maytag Mav2755AWW
hi tecate.
This can be a few things, either bearing,transmission, drivebelt or motor.
Start with the drive belt. Take it off and see if the drum when rotated makes the same squeak as befor when you apply a little pressure to the drum.
If it does not do it it can be the tension in the belt. Or the belt is gone HERE are drawings and partslist. You can also obtain the parts here
Jun 30, 2008 | Fisher and Paykel GWL11 Top Load Washer
Drum not turning
My problem is the same as colins my hotpoint wm63 is starting okay i.e. water fills up but drum is not turning. I can hear it clicking through the cycle but drum doing nothing. i to have just put in new carbon brushes but still no joy please help
steve
Apr 08, 2008 | Hotpoint Aquarius WD63 Front Load...
Drum not turning (WFL 2260)
possibly the belt is off/broken? can you hear the motor turning when the drum is supposed to be revolving? If not supect the motor carbon brushes, or some other fault with the motor/and /or circiut, at best it may be a burned out wire to the motor
Oct 21, 2007 | Bosch WFL 2063 Front Load Washer
May 26, 2007 | Electrolux EW1200i Front Load Washer /...
Zanussi F1045W Front Load Washer Logo
732 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
