Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
Manual donwload I need to see on my TV owner's manual how to select the TV's video input source?
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Please let me know model and brand of your tv to check related user manual.
  • 4 Answers
Video input source is changed by the buttons:
1. Video Source
2. Input
3. TV/Video
4. Source
one of those four on the remote some where.
Also, chances are your TV itself will have one of those buttons somewhere.
Usually pressing it will either cycle through the inputs or bring up a selection of them, which is usually navigated by either arrow buttons on your remote or the channel up and down keys.
Lemme know how it goes.
Posted on Dec 13, 2008
Problem: TV Menu w Auto & Manual Scan greyed out cannot be selected
Check the input selected. if it is other than tuner, this might happen. Change the input to tuner, and check.
Jan 11, 2016 | Televison & Video
How do I get to my HDMI channel?
It isn't a 'channel' it is a connection port. Once a cable box or DVD / blue Ray player is plugged into it, you choose the port using the Input button on your remote and scroll through them.
That set has 2 HDMI connectors on the back panel, right side, more or less by themselves, to the lower left of the antenna jack.
See the link. In the cluster of 3 photos, click the center one, then zoom it. Source(s): kg7or ยท 4 years ago
All the info on the television including manuals and inputs can be found here,
58 Class 58 0 Diagonal 1080p Plasma HDTV with Anti Reflection
Jan 01, 2016 | Panasonic Televison & Video
How do I get a vhs video to show on my tv?
Not only do you have to hook up the wires correctly, once you have them attached, you must then select the proper input source to view the video. Since TVs have multiple input sources, the remote control allows the user to select which connected input to view.
Sep 18, 2014 | Televison & Video
Why are my channels fuzzy?
Hi Virginia,
I have the manual link for you for your TV, basically your issue falls into INPUT issue. Kindly check if the INPUT of your TV is correct. Steps below:
- INPUT SELECT button- Press to select
TV or the external input (VIDEO1,
VIDEO2) mode.
- AUDIO (INPUT) L/R jacks- Connect to
the left/right channel audio output jacks of
a video camera or VCR.
Note: The AUDIO (INPUT)L jack is for
mono input. The sound is heard from both
speakers. Use this jack for monaural audio
equipment to be hooked up.
These steps is in page 2 of the manual. Hope it helps.
Emerson EWF2004 Owner Manual Page 2 Table Of Contents
May 05, 2014 | Emerson EWF2004 20" TV
For some reason, my DVD player just started showing up in black and white. Also, when I select the "source" on my TV remote, instead of showing the option "AV" for the DVD player, it...
Select AV as your source and that should cure the problem as long as you have the video and audio cables connected to the right inputs. You could also use an S-Video cable instead of the video cable for better picture quality depending on your TV model (assuming it has a S-video input). Your owners manual(s) will probably have diagrams for you to follow.
Jan 30, 2011 | Panasonic DMR-ES40
How to hook up a dvd on a proscan ps32600 tv
This tv has 2 AV inputs at rear to connect dvd player or any other video source.
Plug RCA video cable in AV Input-1 at rear of tv and select Input-1 source in tv remote to get dvd player playback picture in tv.
Click HERE to download user manual free copy that has details about tv operations.
Hope these info will help you.
Nov 26, 2010 | Proscan PS32600 32" TV
Tv is showing 480p and we want it at 1080p on our new Toshiba 40XV648 40-Inch 1080p 120Hz HD LCD TV Cinema Series.
After searching the owners manual I find that there is nothing mentioned about the screen resolution i.e. 480p to 1080p.
This set is capable of your desired resolution and as far as I can tell it auto selects because it senses the input video and decides which is the best setting for that source.
It's important to understand that you need 1080p video to use it at it's full capabilities. It won't give you a 1080p resolution from a VCR or a standard DVD player. You need a DVD player that is capable of producing a 1080p encoded video. Some satellite receivers are capable of that but you need to make sure you know what resolution that you are sending to the television.
Local TV stations won't usually broadcast HD at 1080p. Your best bet is to use a DVD player that is capable of that high resolution for your best picture.
Please note that what it says in the owners manual about "Resolution" has nothing to do with the 480p, 720p or 1080p signals, your set selects that automatically it will start by selecting the 1080p then goes to 720p then 420p it's dependent on the video you send to the set.
Please note the "resolution" function is actually like a "sharpness" control.
Your video input (tuner, VCR, DVD, games and etc.) is likely your problem.
Mar 30, 2010 | Televison & Video
How to connect the laptop to tv
Depending on the Laptop and Television you have this may or may not be possible. there are usually an external Video source on the back of the laptop that you can purchase a video cable for. If you have a newer television it will have a VGA connection on the back of it as well. Just plug the cable to both units and switch the video source on the tv to VGA then on windows change the display options to use the external video source. If you need more detail please let me know.
Nov 28, 2009 | Computers & Internet
How to find pc channel
This information is from the owners manual of you television it is on page 12. Signal source selection: Press the [input ] button to select TV, AV, S-Video,Component,VGA and HDMI inputs. There are two way to select the source: One is to press the [input ] button continuously, while the other is to use the up and down arrow and enter buttons to confirm the input. If this information does not help you, call the customer support at this telephone number. 1-888-935-8880. The website is. I hope this information helps you with your problem.
Apr 27, 2009 | Element ELC-HS321 32 in. LCD TV
I'm assummiong you can't select the dvd input. go to this website and you can get a copy of the manual to tell you exactly how to select it. It will tell you to select the INPUT/TV-VCR button and select source TV ot AV1 or AV2. good luck.
Nov 28, 2008 | Sanyo DS27910 27" TV
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
105 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
