Question about HP Compaq Presario 1500US (470038-813) PC Notebook
Compact laptop keeps overheating then cutting off
I have an older compact laptop..Everything still works great except it keeps overheating then shutting down..I have replaced the power cord once and have checked the vents to make sure that there are not any obstructions... It has the older operating system windows 2000xp home edition.. I am using as a desktop and laptop...Any suggestions? Thank you....
  • 1 more comment
  • bromayo1 Dec 13, 2008
    Geekman
    Thanks for the quick response...It doesn't appear that the fan has seized up..It is spinning...just goes from low fan at bootup then about 15 minutes later kicks in at high fan stays in high fan for about another 15 minutes or so then gets hot and shuts down....cant figure it out
    angelo63
    on th clarification....vents cleaned...overheats following the routine I outlined in my response to Geekman...Other suggestions?
  • Angelo Attard
    Angelo Attard May 11, 2010
    when does it overheat and has the fan vents been cleaned
  • HP Master
  • 32,281 Answers
Check the fan, it may have stopped spinning. If the fan bearing has seized, you may be able to free it by removing the fan label covering the bearing and oiling it. If it does't work, replace it.
If the fans spins freely then remove the fan and clear dust from the heat sink fins.
Posted on Dec 12, 2008
  • Chris Hingee
    Chris Hingee Dec 13, 2008
    The heat sink is under the fan, you have to remove the fan to get at the heat sink to remove the dust.
    A clog heat sink will cause the CPU to over heat, use a small stiff brush plus vacumm to remove dust.
My bmw 316ti compact keeps cutting out when slowing down towards a junction. The engine/revs shudder and the car locks up. It starts again straight away afterwards but what is causing it and how much
Could be cam shaft sensor or crank shaft sensor first comes first diagnostics to see codes but bmw come up with loads of codes that arnt the problem.
Some cases is:
Vacuum leak
Cam shaft sensor
Crankshaft sensor
Eccentric shaft sensor is a main problem on these cars and maf
Jun 24, 2014 | 2004 BMW 316ti Compact
Have a Toshiba L300 which keeps cutting out for no apparent reason. Gives no indication that it is going cut out.
Overheating is the problem, to get rid of it you need to clean the fan and the heat sink of the laptop.
System automatically turns off in the case of overheating to save your hardware from any damage.
Click here to watch a tutorial on how to clean a laptop fan.
Hope this helps, Please feel free to ask me any further, Please rate positively.
Apr 06, 2010 | Computers & Internet
The knobs and switches keep cutting out
you can use contact cleaner formulated for electronic appliances you can find it on local electronic parts dealer
Feb 04, 2010 | Kenwood Audio Players & Recorders
Projector keeps cutting off
just in case it is overheating, blow out any dust with canned air and make sure the fans are working. also, keep anything from blocking the vents. if all that is done and it still shuts down, you have a power supply that needs replacing.
Nov 04, 2009 | Optoma MovieTime DV10 Multimedia Projector
Hello, a friend recently brought me a Presario c700 asking me to fix it. When I inspected it, it has occured to me that the entire thing looks completely fine, inside and out, I've checked this thing with...
What I recommend is you remove everything you could possibly remove from the laptop (HDD, mems, cd rom, wifi cards, etc) just to check if it will turn off even when it's not booting or posting. Try turning it on with just the charger and WITHOUT the battery and see if it stays on. If it doesn't, then most likely the mobo itself is the problem.
Oct 06, 2009 | Compaq Presario C700T Notebook
Laptop will not keep current date/time
The BIOS battery is nearly flat and this is causing the time to drift.
Replace the BIOS battery with a new one, then you will need go into the BIOS configuration to set the date and time.
Apr 30, 2009 | Sony VAIO Notebook
Neff B1721 oven
good day,
hope this link below will solve your problem.
kitchen appliances
Oct 20, 2007 | Neff B1721 Compact single Circotherm oven
Unit shuts itself off within a few minutes.
. Try taking a can of compressed air and spray in the vents in the front and the back of the heater. The heater has a sensor that gets dusty and causes it to shutoff to prevent overheating.
The heater should function properly once the dust is blown off the sensor.
Mar 06, 2007 | Lasko 5365 Ceramic Compact Heater
Computer turns off by itself
I have a toshiba laptop which was unexpectedly switching off. The laptop was 2 years old. I did lots of searching online to discover this is a VERY COMMON ISSUE. The problem is, dust blocks the heatsink. When I took my computer to pieces, I found a strip of dust half an inch (1cm) thick covering the back of the heatsink which prevented air flow. If your laptop is a couple of years old, this could be the problem. When I removed this dust, the problem disappeared. If you are computer savvy, then try the following - if not, take it down to a computer shop! 1) Remove the 5 screws holding down the heat sink cover and processor cover. These are on the bottom of the laptop, in the centre, at the back. 2) Remove the 3 screws which hold in the heat sink in place. 3) Remove the heatsink 4) Take the dust out 5) Re-assemble a note: be careful not to get dust in the thermal paste on the cpu - unless you have replacement paste. Good Luck!
Oct 30, 2006 | Toshiba Satellite 2060CDS Notebook
HP Compaq Presario 1500US (470038-813) PC Notebook Logo
205 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
