Question about Kenmore 15516 Mechanical Sewing Machine
Tons of loops on bottom
Without warning machine makes "ka-thunk" noise and 10-20 loops appear on bottom of project. Often will stop sewing completely.
    Problem Solver:
  • 4 Answers
To address my needle thread tangling (horribly) in the bobbin compartment, I rethreaded the bobbin. I cleaned the bobbin and the feeder feet, I changed the bobbin and the thread. I changed the tension on the needle thread and the bobbin thread. NO FIX! Then, I changed the needle - the problem was fixed instantly. I sewed awhile and then put the original needle back in. No problem. I think perhaps that the problem is being caused by the needle getting out of alignment somehow during sewing. If you are having the same issue, try it. It can't hurt!
Posted on Sep 15, 2008
    Problem Solver:
  • 26 Answers
Check your threading.
Berhaps your thread is not between the discs.
Posted on Jun 09, 2008
Machine making load noise after stop sewing, what is that?
We all know that proper threading makes for happy sewing machines and happy stitchers. And while we emphasize threading with your presser foot up- there are a few other things to keep in mind while threading your machine to make sure your sewing time is happy time!
Have you ever been sewing along on a project, decided to change threads, and all of a sudden you hear a THUNK CLUNK THUNK when you start sewing again?
If not, good for you. But I know that this has happened to a lot of our customers for sure!
Often, this sound comes from not getting your thread in the take-up lever while threading.
If you have a new needle that is the appropriate size/type and your machine is clean, but you start to hear a clunking sound after rethreading, this is the first thing to check. And it's such an easy fix. In fact, I think some people are so surprised when we tell them to simply rethread, because the sound is so terrible they think something is seriously wrong with their machine.
Now, there could be something really wrong with your machine, but the biggest clue that it's a missed take-up lever is that the problem starts suddenly, most of the time after rethreading. (machine was sewing just fine before that).
How do you make sure to thread your take-up lever?
On some machines, it's very easy to see the take up lever, and on others it's hidden behind the machine casing. Here's what you should do to try and ensure success.
-Raise your presser foot!(Full rant here)
-Put your needle in the highest position (use the needle up down button or line up the notch on your handwheel with the casing of your machine- more info here)
-Clear the thread path. Make sure there's no thread wrapped around a spool cap or trapped under your spool.
-Feel it! If your presser foot is up and your needle in the highest position, hold the thread near the spool with your right hand and thread with your left, you'll be able to feel the thread slide into the take-up lever.
-STOP immediately if you hear a THUNKing sound and re-thread. What's happening is that your top thread is not regulated, and it can ball up undereath the feed dogs and cause issues.
-Clean out your bobbin area and re-thread if you think you missed your take up lever.
Aug 25, 2017 | Sewing Machines
Why is my handwheel hard to turn and making a squeaky noise?
Sounds like possible thread in the gears, or the wrong oil might have been used to oil the machine. Sewing machine oil (clear oil) should be used for oiling the machine. I use an oil called Tri-Flow Lubricant which is available at your local bicycle repair shop.
May 28, 2014 | Husqvarna Huskylock Computerized 910
Hello dear
have you tried changing the needle?
have you tried adjusting the top thread tension?
it might be the needle and the thread are not compatable,, the needle may be to light for the thread.
if the suggestions don't help, sew on the sewing machine till it makes the loop and then stop the machine and take it to the repair man and let him see the loop and then ask him why it's making the loop.
Jul 25, 2013 | Janome Sewing Machines
Tension is loose underside
Loops appear on the surface (top side) of the fabric?
Reduce the tension by turning the upper tension control dial to a lower number. If the loops still appear on the surface of the fabric after you adjust the upper tension, the bobbin thread may be too loose. In this case, turn the screw clockwise, being careful not to over-tighten the screw, approximately 30-45 degrees to increase bobbin tension. After you adjust the bobbin thread, adjust the upper thread to match the bobbin thread.
Make sure you reset before your next project.
Apr 26, 2013 | Brother LS-2125 Mechanical Sewing Machine
Thread looping at the bottom of my fabric on my Elnita 120 Sewing Maching
here is a link for a manual for the machine
http://ifixmachines.com/index.php?page=shop.product_details&flypage=&product_id=1540&category_id=1575&option=com_virtuemart&Itemid=54&vmcchk=1&Itemid=54
try changing the needle--use one that is correct for the fabric being
sewed
the top tension adjustment for the bottom loops
make sure the bobbin is turned the right way in the bobbin case
make sure the top thread has not come off the thread take up lever
Feb 11, 2013 | Sewing Machines
Whta is the answer to the curvy's thread/bobbin problems. super infuriating
If by "bobbin thread is usually too loose." you mean that you are seeing loopy stuff on top of your seam... then first you need to make sure your bobbin is un-spooling in the correct direction.
Also make sure that the tension spring on your bobbin case is not missing it's screw. Don't mess with the tension there yet... loosen your top tension first... sew on scrap fabric of the same type as your project. Loosen the top tension until you stop seeing loops on top of your seam. If you have loosened it enough to see loops on the bottom... tighten it a bit.
If all else fails make sure you re-thread the top thread with the pressure foot up position so you make sure you are getting the top thread in the tension discs and try test sewing again.
Jul 26, 2012 | Singer Curvy 8770 Electronic Sewing...
LOOPS WHEN SEWING
This is a top tension issue, you need to check two things,
-make sure you thread the machine with the pressure foot up ( this allows the tension discs to open up so you can pull the fabric away from the machine with the foot up and allows the thread to get to bottom of the tension discs)
-make sure your tension settings are set to the medium setting. (Usually 4 or 5)
If this still does not help, then turn the top tension knob up (from 5 to 6,7,8,9....)
-If that still doesn't do it, your probably need the tensions reset, and your local family sewing store will be able to assist you further.
-Chris
Jun 06, 2010 | PfaFF Quilt & Craft Pro 7530
Big loops on bottom stitch
You have no top tension. Rethread the top of the machine. Make shure you raise the presserfoot before threading.
Feb 23, 2008 | Singer 6038 Mechanical Sewing Machine
Kenmore 15516 Mechanical Sewing Machine Logo
286 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
