Question about Philips VRA611AT VCR
MAGNVOX MWR20V6 VCR WON,T ACCEPT TAPE EJECTS WONT LOAD UP
HAVENT WORKED ON VCR,S FOR OVER 20 YEARS SUSPECT IDLER PROBLEM DONT SEE TIRES LIKE IN PAST MACHINES ANY HELP ? CANT FIND MAG TECH SERVICE RETIRED TECH IS THIS PART OF THE THROW AWAY ECONOMY??
  • 1 more comment
  • alhertel Dec 12, 2008
    IM sorry the solution you posted is used in cases of stuck tapes iquess i didn,t pose my question clearly my problem is that it dosen,t load tape but when you push in the tape it imediatly ejects it.... sorry can i ask for this probable fix thanks
  • Anonymous Mar 21, 2014
    Serial # u14011277 model #cmwd2206a
    How can I get my dvd working ??
    Genius:
  • 1,139 Answers
Hello alhertel,
The old idler wheel has been replaced with gears (cheaper and last longer then the old rubber wheel). What you need to do is to gain access to the loader motor and turn it until the carriage begins to move, once the carriage gets to the top and moves outward you should be able to eject the tape with no problem.
Believe it or not VCRs are throw away technology, since it costs as much to repair one as it does to buy a new one. However, there are a lot of people who still hold on to their VCRs.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Dec 12, 2008
  • Henry McKelvey
    Henry McKelvey Dec 13, 2008
    Hello alhertel,
    Try this take the cover off and look at the position of the gears, look for proper alignment, because what has happened is what is called gear slip. One of the gears are engaged incorrectly, making the system believe that the carriage is in the correct position when it is not. Also check your tape sensors. These two issues can cause this problem to occur.
    I hope this helps,
    Thank you,
    Shuttle83
    http://www.electron-age-technologies-llc...
VHS tape won't eject
Hello
Check for any borken drive belt in the mechanism.
Feb 13, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox #MWR20V6 DVD Recorder/4head HI FI Stereo VCR
It's Power supply must be inspected by an authorized tech.
Mar 25, 2008 | Philips Magnavox DVD+R/+RW Recorder/VCR
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
VCR does not play.. It keeps ejecting the tape
Does it eject right when you put a tape in? Or when you press play? Does it fast forward or rewind? if not a belt may need to be replaced or an idler tire is worn.
Jun 16, 2010 | Panasonic NV-HD680 VCR
Go-Video VCR Problem with accepting/ejecting tapes
As with any VCR, there are rubber parts inside that have become slick. This is a simple repair for any shop. The mechanisms are Samsung ones if I remember correctly. Expect a parts cost between $20-$40. Add in the local labor rate for the total cost. This is worth the repair cost as any replacement would not last anywhere near as long. This is also a normal occurrance as rubber parts harden with age. I have repaired many of these over the years.
Dan
Jan 05, 2009 | GoVideo Go Video DVD/VCR Combo
My Tv is turning off by itself
unplug and let sit for a min then plug back in
Jan 01, 2009 | Televison & Video
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Mar 11, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
What do I do when my Emerson TV keeps turning off by itself?
I had the same problem with mine turning off after 3-5 seconds. After much research I found a suggestion that on some combo units the vcr part could have a power supply cutout if it is not working correctly. I tried to insert a tape and found that the tape mechanism would not accept a tape. I used a little bit of force and managed to insert a tape. I then played the tape forwards and backwards and the power stayed on! I ejected the tape and found the TV then worked just fine. The power has now been on for over one hour. I hope this give you another avenue to try and fix your problem.
Nov 30, 2007 | Televison & Video
Toshiba M-752 Video Casette Recorder
Take the top cover off, and see if there is an obvious reason for the no-eject, as in tape spooled out and wrapped around something. Next, is the tape drawn back into the tape housing? Under normal operation this is done before eject. A defect in the tape itself, or in the VCR mechanicals can cause a no "pull in" condition. Otherwise, you could carefully try to assist an eject- push eject, lift lightly on the tape. Sometimes the entire carriage mechanism can be removed with tape in place, but often, screws holding this in place are obscured by the tape, and, if carriage is gear driven, proper gear alignment must be reestablished. This can be a tricky problem, getting tape out without damaging anything, especially since late VCRs are made rather fragile to start with.
Aug 14, 2007 | Toshiba W522 VHS VCR
if all you want to do is disable the vcr portion turn the set on , install a blank vhs tape it has to be blank or the vcr will try to read it .and the tv and dvd should work fine. this is a timing problem in the vcr deck its not hard to fix but it is a pain.
Nov 05, 2006 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Philips VRA611AT VCR Logo
437 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
