Question about Dell Inspiron 6400 Notebook
Dell inspiron 2650 wont power up
When i press the power key nothing happens if i hold the power key down the fan runs but nothing else every other press of the button flashes the three lights on the front but nothing else ?? please help
The monitor imean the in built one would have shortcircuited from inside..
so u r facing the problem.
got it>??
contact a dell expert.
Posted on Dec 13, 2008
My daughters 1525 dell laptop will not work properly.You can turn it on the dell name appears and that is it all lights are working fan is working I hope you can help with out me she has all her photo;s...
If the power LED is ON and you can sense the fan as well problem might be on the LCD or Motherboard.
Could you please try this one and give me feedback what had happened.
Remove ac adapter and battery from laptop.
Press and hold down power button on the laptop for 10 seconds.
Plug in the ac adapter.
Hold down the Fn key then press power button once, then just keep holding down the Fn key.
You might not see anything on the screen but please do take note of the error code or beep codes.
Thanks!
Apr 29, 2011 | Dell Inspiron 1525 Notebook
I have Dell Inspiron 2650 and AverMedia AverkeyPlus and Philips 100Hz tv, but I cant get the picture on tv.When pc starts well, but after only on compjute.
There is usually a software control for the VGA port. Look for something that looks like a monitor on the function keys at the top of the keyboard. You will have to hold the "Fn" key down while pressing the F7 or which ever function key has the monitor on it. These take a couple seconds to work, so toggle slowly through the modes. There is usually a mode for monitor only (which is what you have now), one for both VGA port and monitor, and one mode for VGA port only.
Dec 06, 2010 | Dell Inspiron 2650 Notebook
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Dell inspiron 2650 frozen on blue welcome page
try this...
turn on the laptop,,,
keep pressing F8
a menu screen will appear,, select SAFE MODE using the cursor keys and hit enter,,
once it boots in safe mode click no to use system restore..
follow the onscreen instructions to send it back to a date when it did work,,
it will shut it self down and restart in a propper manner..
if that fails,,
when u turn on the laptop it displays a menu,, it shows to press a certin key to enter system recovery,, press that key,,
follow the onscreen instructions to restor the laptop to factory condition..
Jun 03, 2010 | Dell Inspiron 2650 Notebook
My Dell Inspiron 530 was set up two days ago and worked fine until I tried using it this evening. The fan is running and nothing happens when I click the mouse.
For that open cpu cabinet.
Refix RAM memory.Reattch both connection to harddrive.
Then when you power up the computer press F8 key then enter in safe mode.
Then go to start menu->run or press windows key + R key so you can see run type in run "chkdsk /r" then press "y" then restart computer then it fix errors on harddrive.
Also scan your computer with updated antivirus.
Let me know if you need further assistance.
Thanks for using fixya.
Jan 19, 2010 | Dell Inspiron 530s Desktop Computer...
Where are the volumne buttons on the dell inspiron 2650 laptop. which keys on keypad work for volumne
You can adjust the volume by holding down the 'Fn' key (bottom row, second from the left) and pressing Page Up and Down keys (on the far right) to turn the volume up and down respectively.
Dec 31, 2009 | Dell Inspiron 2650 Notebook
Dell inspiron 1705 9300 17inch shuts down after 15-20 mins win xp
first thing to do is run psa test. turn off laptop. remove batt use ac adapter alone. press and hold on Fn key then press power button once. complete the quick test check if you will be getting error codes like 0142 , 0146 this is hard drive replacement.
Oct 01, 2009 | Dell Inspiron 1501 Notebook
Dell inspirion 650 keyboard remains locked in NumLK mode
you should hold down the function key and then f11
Mar 22, 2009 | Dell Inspiron 2650 Notebook
Overheats and shuts down after about 20 minutes
Usually when a CPU overheats it shuts down and after it cools down you can re-boot it again.
Continual overheating will eventually cause the CPU to fail.
The overheating is usually caused by blocked vents and or dust build up on the heatsink and/or fan. Remove this dust from the heatsink and fan and this should fix your overheating problem, unless you have a faulty fan, in this case you will need to replace the fan.
Feb 18, 2009 | Dell Inspiron 2650 Notebook
Keyboard
Try this:
Shut down, unplug the AC adaptor, removed the battery, and hold the power button for up to 1 minute to discharge.
Make sure there are no stuck keys.
Restart.
Apr 08, 2008 | Dell Inspiron 2650 Notebook
Dell Inspiron 6400 Notebook Logo
141 people viewed this question
Alun Cox
