Question about Whirlpool LAB2700ML Pedestal Drawer for Duet Washers & Dryers
LEAKING WASHER I have a "DESIGN 2000" series Whirlpool washer that I purchased in 1988. I have a problem with water leaking from the lower right-hand corner. What could this be....since, I have had no prior mechanical problems ever. How do I fix?....Is there a schematic drawing available for this model? I think it might be one of the valves or a leak in the basin itself...?
    Sergeant:
    Champion:
  • 291 Answers
Your pump is leaking ,,, take the 2 screws out thats on each end of the console in front and pull forward and up, take the 2 hold down clips off and tilt cabinet forward and remove / pump is at bottom with 2 hoses connected to it / if you need help getting a pump let me know and send me the complete model number from under the lid and i will see if i cant help you out / larry
Posted on Dec 12, 2008
Washer is leaking water on bottom of unit
If the water is gushing from the washer, check the small plastic air dome hose on the lower right hand side of the wash tub. Sometimes the hose can come loose and come off. This will cause the water to begin pouring out of the bottom of the the washer when it begins to fill. The following link lists some other items you may consider as well:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
The link explains how to remove the exterior washer case in order to accurately inspect the washer interior components for the source of your leak.
If the leak is more like a constant drip, another common source of leaks with Whirlpool manufactured top loaders is a leaking drain pump. These pumps are not serviceable and if damaged, must be replaced. The following link explains how:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
Don't forget to check all drain hose connections under the washer and the center tub seal.
Replacement parts (if required) can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope this helps you.
NOTE: Roper washers are manufactured by Whirlpool, so these instructions will apply.
Jun 22, 2010 | Roper RAX4232KQ Top Load Washer
I have a 2000 model Whirlpool washer and it is
Hello, the drain hose may have disconnected from the drain valve, these is the hose that leads up to the external drain hose and has that U shape in it.
Thanks
Jun 11, 2010 | Washing Machines
My washer is leaking
repairclinic.com
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
NOTE: Kenmore washers are manufactured by Whirlpool, so these instructions will apply.
Jun 08, 2010 | Washing Machines
My lsq9549pw2 is leaking from the tub. How can I
Another common source of leaks with Whirlpool manufactured top loaders is a leaking drain pump. These pumps are not serviceable and if damaged, must be replaced. The following link explains how:
repairclinic.com
Jun 07, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Leaking water
If the water is gushing from the washer, check the small plastic air dome hose on the lower right hand side of the wash tub. Sometimes the hose can come loose and come off. This will cause the water to begin pouring out of the bottom of the the washer when it begins to fill. The following link has some other things you may consider as well:
repairclinic.com
May 30, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer seems to be leaking during spin cycle.
Another common source of leaks with Whirlpool manufactured top loaders is a leaking drain pump. These pumps are not serviceable and if damged, must be replaced. The following link explains how:
repairclinic.com
May 07, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My washer leaks water all the time
If it is leaking all the time while running it could be the drain pump. A coin had made its way into mine and cracked the housing. Itis located towards the right rear of the machine on the bottom, while standing in front of the machine.
Mar 30, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
ULTIMATE CARE II WASHER - MODEL LSQB520JQ0 IS LEAKING
you can tip this unit back, the bottom is open and then oyull be able to see where the leak is coming from, any part wharehouse(online stores as well) will stock the pump if needed.. most common cause of leaking pump is fron center shaft youll see the water line
Mar 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water leaking on the floor while filling
Open the back of the washer. Start the fill cycle and observe where the water is leaking from. You are not going to get a full view of the entire tub by only opening the lower front access.
Feb 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
207 people viewed this question
Dan Webster
Dan Webster
Sal De
