Question about Magic Chef Ovens
Magic Chef oven won't heat up past 200 degrees
Model CER3725AAW won't heat up past 200 degrees and it takes about an hour to get it to that point!
  • Magic Chef Master
  • 3,463 Answers
You obviously have one or more elements not working, you need to test same, and replace as req'd.
Posted on Dec 12, 2008
Oven Won't Heat To Desired Temp / Burner Quits Working Sometimes
The temperature sensor in the oven needs to be replaced. Here is the part to order. As far as the top element, lift the top up and look for lose or broken wires on the element. Keep me posted.
Nov 20, 2012 | Magic Chef Ovens
We have a Magic Chef gas oven (model # CPL1100BDW) without electronic ignition. The oven isn't working. The oven pilot is out, can't get it to light, and the oven will not light - (obviously)....
Hello & Welcome to FixYa
If the pilot is clean and still won't light then the problem is with the safety valve that won't open and so needs replacement. Please get back to me if you have any other questions.
Kevin
Nov 14, 2011 | Magic Chef Ovens
MY OVEN wont heat up. its takes at least an hour
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 28, 2010 | Ovens
Magic Chef oven does not work but all burners do
25 yr old oven...........so I bought a new one with a few blemishes for $200.
Apr 04, 2010 | Magic Chef Ovens
I have a magic chef range/oven. For the last few months, it has taken longer and longer for the oven to heat up to temp. Now it won't get more than 90 degrees or so. What is the problem??
Turn off the power to the range. Remove the bake element from inside the oven. Be careful not to let the wires go back into the oven cavity. Take a volt/ohm meter set for ohms or continuity and test the bake element leads. If you get no reading replace the element. If you do get a reading,replace the temperature sensor in the oven.
Oct 08, 2009 | Magic Chef Ovens
Magic chef oven/stove top range not staying hot
Hi, It very well could be the ignitor. Sometimes they work at first and then will not open the gas valve later in cycle. You can set the oven to heat and watch the ignitor. If it glows and the gas will not ignite in 30 to 45 seconds, the igniter is getting weak. I jope this helps.
Please let me know if I can assit you further.
Vic
Jun 20, 2009 | GE JGRP17 Gas Single Oven
My magic chef oven will not heat in the oven or on the stove top after the electricity was shut off for a few hours. what could be the problem?
If it has a timer, make sure it is set to manual,and not flashing auto.
In the auto mode the oven will not work.
Plz rate this solutioin.
Thanks.
Dec 27, 2008 | Magic Chef 9512 Electric Single Oven
Wont Heat at all
sounds like you have a bad wire connection someplace in the oven.
Dec 10, 2008 | Magic Chef 9815 Electric Single Oven
Won't heat up
You have two ignitors one for bake and one for broil your bake is not working
Nov 09, 2008 | Maytag CWG3100A Gas Single Oven
Ovens Logo
306 people viewed this question
Top Magic Chef Ovens Experts
Dan Webster
Dan Webster
Sal De
Oloyede Monsuru
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
