Question about Alpine CDA-9855 CD Player
No sound from my 9855 alpine
No sound coming from my cda 9855 head unit. Everything else works fine. My older head unit works fine before and after replacing my Alpine cda 9855
    Problem Solver:
  • 11 Answers
There is an option in the unit itself to turn off the internal amplifier. If you push the 'menu' button, then go to the setup/settings menu, and then i believe it was under the 'general settings' tab. there's a option called INT IC or something. Make sure that is turned on.
Posted on Jun 01, 2009
I have a CDA-9855 Alpine head unit. It worked just fine when removed from my prior vehicle (05 VW Golf). I just installed it in an 01 Land Rover Discovery II using a wiring harness adapter so no cutting or...
it sounds like you have the blue wire (antenna remote turn on) instead of the blue/white wire (amplifier remote turn on) turning on an external amplifier in your rover. the antenna remote wire turns off when you leave tuner mode.
Jan 26, 2011 | Alpine CDA-9855 CD Player
My 9855 alpine will work when you take the face off / and put it on but the buttons don't work but you can control it with the remote,and when you hit the eject the face wont come down and it wont eject a...
had the same problem with my alpine, i was able to fix it once by, popping off the face plate and with fine grit sand paper (lightly) sand the connection points on the radio and the face plate, then put a little bit of dialectic grease on it . also doing a reset on the unit helped me from time to time...
May 02, 2010 | Alpine CD Player CDA-9855 LIMITED QUANTITY...
Alpine cda-9855r with no display
when mine does that it is down to the connection of the face to the head unit, push it firmer or remove and replace. it may be that the connection is worn.
Sep 15, 2009 | Alpine CDA-9855 CD Player
Alpine CDA 9855 plug configuration
an alpine dealer will have the ability to order a new harness for it.
there is only one made for that particular unit.
May 26, 2009 | Alpine CD Player CDA-9855 LIMITED QUANTITY...
Blown Speaker Channels
Chips fail, even for the best of us! If the preamp outputs are still fine, you can purchase a small 4 channel from Alpine for 100-150. About the same as a repair yet cleaner power. Check EBAY there's always good deals to be had!
Hope this helps
May 22, 2009 | Alpine CDA-9855 CD Player
External DC/DC Converter
Go to www.pacparts.com
If anybody has that, they will. They have everything for that radio down to the little screws that hold the stuff inside together. If they don't show it as being in stock on their site, then you should call them and they can usually tell you when they expect to get it back in stock.
Nov 01, 2008 | Alpine CDA-9855 CD Player
Alpine cda9855R
A new one will come with a new face plate, but you could try checking pawn shops for a used one. Prices will vary.
Aug 19, 2008 | Alpine CDA-9855 CD Player
Alpine CDA-9855 won't recognize SIR-ALP1
I also had this problem. I had to go through the menu into the setup and then into tuner settings. There should be an option called tuner area. If you set it to area 1 it should start working. For some reason the sirius only works on area one. Hope that solces your problem
Jun 19, 2007 | Sirius Satellite Radio Sirius SIR-ALP1...
CDA-9855
Try lens cleaner first, always the best idea. If it makes a clicking sound when trying to read the discs, you're looking at a bad optical pickup.
Oct 24, 2006 | Alpine CD Player CDA-9855 LIMITED QUANTITY...
Alpine CDA-9855 CD Player Logo
613 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
