Question about Microwave Ovens
Crystal microwave oven model WP900AP23 does not heat up.
Display exhibits all of the modes according to existing functions, plate is rotating but any heat...
  • 1 more comment
  • levtch Dec 13, 2008
    Hello.
    First of all, thanks for quick response.
    It is right: there are light inside, turntable rotating and display panel responding appropriately to demanded function, but it is not heating. Any unusual noise is not detected (the same noise as during normal operation in the past).
  • levtch Dec 18, 2008
    Hello.
    First of all thanks again for your support.
    Right now I have found out a bad high voltage fuse and disconnected in both direction high voltage diode. So, I am going to purchase these parts and replace it (I will update you about results).
    Unfortunately I have not idea how I can check the magnetron.
    Thanks and Best Regards,
    Lev.
  • William Miller
    William Miller May 11, 2010
    Your post got cut off.
    Do you mean to say that when you try to microwave, the inside light and turntable operate, but it's not heating?
    Any unusual noises? Is
    it louder or quieter than usual?
  • Microwave Ovens Master
  • 9,086 Answers
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode, a bad magnetron, or a bad high voltage diode.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can contact your manufacturer about parts by consulting the contact information in your owner's manual.
If you have no manual, I would suggest calling the dealer where you bought it to see if they have a number for the mnaufacturer.
Posted on Dec 15, 2008
  • William Miller
    William Miller Dec 19, 2008
    If the high voltage rectifier diode is not shorted, it's probably good.
    My solution above shows you how to test components if you or a friend has a multimeter, VOM, or other test / continuity meter.
    We're happy
    of our answer.
Siemens HF26066GB plate is moving when door closed and not moving when open
Have a shop look at this---there usually is a recessed safety switch inside the jam that will prevent the unit from working with door open--sounds like the problem may be with it.
Nov 03, 2012 | Siemens HF26066GB 1000 Watts Microwave...
Tip
Error Code "d" - Microwave does not heat
The microwave could be in "Demo Mode" - Check your owners manual.
In Whirlpool/Kenmore models this is indicated by a lower case "d" on the right side of the display panel.
Most/All function except the magnatron (heat) work in demo mode so you can can learn to use the oven without actually cooking food
To clear "demo mode" press the "kitchen timer" pad and hold for 5 seconds until the "d" clears from the display... you may hear 2 beeps.
on Jun 16, 2009 | Kenmore 60654 Microwave Oven
Tip
Or the microwave could be in "Demo Mode" - Check your owners manual. In...
If the microwave operates normally, but does not heath at all, then it can be the high voltage capacitor, the rectifier diode.or the magnetron.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, your model number did not return any result, contact the seller here to purchase parts. (here in UK).
on Jun 16, 2009 | General Electric Microwave Oven
Microwave will on but plate is not rotating
Hi.
If the microwave is heating up, then the problem is either the motor below the rotating plate, the control board or the wiring harness between control and motor. If for the rest the oven is functional, then the problem is almost surely the motor.
If you need parts or diagrams see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 20, 2011 | LG Microwave Ovens
Cookworks signature microwave oven model:AC821AHT suddenly stop heating .,light comes on , plate rotates but does not heat anything.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 26, 2011 | Emerson Black Microwave Oven
Model FMT148G1B2 - over range microwave will not heat food. Clock, lights, rotating plate in M/W all work, just will not heat/warm.
well that depends on the current. If the current is a fluctuating type then microwave wouldn't heat or else if high...please check..
Jul 23, 2010 | Frigidaire FMV156EM Microwave Oven
Plate does not rotate
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
lggklj
Jun 25, 2010 | Sanyo Microwave Microwave Oven
Microwave seems to work but doesn't heat up
HI, when the Magnetron becomes unstable, the microwave will not heat anything. simply replace the Magnetron. This device creates the heating action and it is damaged and not functional at this time.
Jun 01, 2009 | Sharp R-1870 Convection/Microwave Oven
Plate won/t rotate no reheating
PLease open the housing of turn table motor at bottom of the oven and check for the AC input voltages on motor terminals as specified on sticker on motor. for no heating please check fuse between high voltage transformer and high voltage capacitor. Also check high voltage Diode and Magnetron.Please please don't try to measure voltage on terminals of magnetron.
Jul 29, 2007 | Whirlpool MH6141XK Microwave Oven
Microwave Ovens Logo
932 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
