Question about Acer Aspire 3610 Notebook
Laptop LCD moniter badly distorted please help!!
My laptop's screen is distorted and garbled. ive tried the windows trouble shooter and it made no difference. what is baisicaly happening is the colours are messed up and they appear to be moving slightly, some days it works fine but then it gets distorted and completely unreadable . i have run virus checks, spyware checks and they have come back with nothing. sometimes the screen is just completely unreadable iv tried restarting it in safe mode and it didnt work.i am a novice computer user and i dont no what to do please help!
    Novelist:
  • 198 Answers
Hello. The problem as you've told us, is most probably with the connector that links the LCD pannel to the main body of the laptop (on the motherboard). Because the joints are constantly moving there is some friction happening with this connector and in some cases it may get damaged or become loose from one end. You will need to have it examined in a service center. This isn't an expensive repair, in the worst case scenario you will need to have that connector replaced at most. Good luck in solving this problem and post any other question if you need further details. PS Sorry for my bad english, I live in a non english speaking country.
Posted on Mar 10, 2007
Why are all the lights on LCD screen on?
How to troubleshoot and fix video problems
Here are some tips and tricks for troubleshooting and fixing laptop video problems. Video issues are very common within portable computers and with the following tips you should be able to detect and eliminate basic laptop video problems.
Laptop LCD screen has a faint image.
Look at the LCD screen very closely and check if you can see a faint image on the screen. It's possible that the LCD lid close switch stuck in the "closed" position and the backlight stays off even when you open the LCD screen or turn on the laptop. The switch turns off the backlight when you close the LCD display to save the laptop battery power. Check the LCD lid close switch. Usually it is a small plastic pin located close to the LCD hinges. Try to tap on the switch a few times to turn on the backlight. If after tapping on the LCD lid close switch the backlight stays on, you fixed the problem.
It is also possible that after tapping on the LCD lid close switch the backlight works fine, you see a normal video on the screen for some time and then the backlight turns itself off again. In this case I would blame the FL inverter board. Try to reseat cables on both end of the FL inverter to make a better contact between the cables and the FL inverter board. If it doesn't help I would try to replace the FL inverter board.
Laptop LCD screen is solid white color.
http://www.laptoprepair101.com/wp-images/white-screen/1-laptop-white-screen.jpg
Most likely it is just a bad connection between the LCD display and the system board. I would try reseating the video cable connector on the back of the LCD screen first and check if it fixes the problem. After that I would try reseating the video cable connector on the system board. I would also try reseating cables if there is no video on the LCD screen at all.
http://www.laptoprepair101.com/wp-images/bad-laptop-video/washed-lcd-image-1.jpg
Try to connect the LCD screen to an external monitor. If the external video is fine, you have a problem with the LCD screen or the LCD video cable. You can try to fix the problem by reseating the video cable on the back of the LCD and on the system board.
If you see the same garbled video output on the external monitor most likely it is not the LCD screen problem. In this case the system board (with onboard video) is bad or the video card is bad.
REFERENCE: http://www.laptoprepair101.com/troubleshoot-fix-laptop-video-problems/
GOOD LUCK.
Jun 30, 2015 | Computers & Internet
Toshiba Satellite Ultrabook U945-ST4N02 Windows 8,
Check with the moniter by connecting the VGA Cable. is there any display on moniter if yes then laptop;s screen faulty otherwise motherboard issue.
Oct 11, 2013 | Computers & Internet
Error "Setup didn't find HDD"
Well, first of all XP is not the latest supported operating system from Microsoft.
That being said, I have not had a garbled screen followed by an error message 'setup didn't find any hard disk drive installed' on a laptop, in my limited experience with laptops (i.e. Acer One, Acer Aspire, Sony Vaio, etc.)
If you have an unexpected garbled screen it points to the pc board or mother board or the video card, but more likely the motherboard.
And, if you couple this with the hard disk drive not being detected, it reminds me of a situation where I had a no hard disk drive detected on a SCSI drive connected to my Windows 95 computer in the 1990s when I had heat related issues with the circuitry on the hard drive getting burnt out capacitors.
If the drive is not recognized, it might mean the boot sector is wiped, and essentially it needs to be reformatted and the operating system needs to be reinstalled (which you evidently tried to do).
To my memory, I never had this problem on Windows XP with a laptop, so I am thinking it's not Windows that is at fault, but the physical hardware is giving you problems.
If you boot from the CD for Windows XP and it doesn't find the drive, it's a big problem for this laptop.
I wish you luck in finding an answer to that one, seeing that it's out of warranty and XP is no longer supported by Microsoft.com.
Jul 19, 2010 | Fujitsu Siemens AMILO Pro V2000 Notebook
Laptop only displays image on 2/3 of lcd screen.
Try installing the latest video driver. Download it from the HP WEB site and make sure the video driver matches Windows XP or Vista that is installed on your laptop.
Sep 06, 2009 | Compaq Presario Notebook
IBM A31 2652 Video garbled video at boot
This is very possibly a hardware problem, namely a crack in the motherboard. Sorry, no easy or cheap fix for it if that's the case.
Feb 18, 2009 | IBM ThinkPad T42 Notebook
Laptop screen
Have you tried hooking up an external moniter? If so do you have video on that moniter? If you do have video on the external moniter then you most likely have a bad inverter or a bad lcd panel.I would replace the inverter first because it's not very expensive.If that doesn't work then you can replace the lcd panelAnd if that doesn't work you have problems at the system board level.
Dec 15, 2008 | Compaq Presario M2000 Notebook
Moniter problem
the LCD screen is damaged.
hope this helps
Jan 08, 2008 | Toshiba Satellite A105 Notebook
Trouble with running a secondary monitor from my laptop
Hello tonyphats,
How are you trying to use the monitor? Just connecting it to the laptop? I know on most laptops you have to select to use the external monitor it won't just come up. You usually have to hold down the 'Fn' button and then press 'F5' or 'F7' to toggle between - monitor only, monitor and lcd, and lcd only.
If you are trying that, what happens? Does anything show on the screen?
-Chester
Dec 20, 2007 | HP Pavilion zd7000 zx5000 zv5000 presario...
Screen distorted
Hi its only a guess but it sounds like you might have the screen resolution turned up to high for the monitor to handle.. if you want to give it a try, try this.. Turn Machine off then turn PC on, and keep pressing F8 when u switch it on till the menu appears, Select SAFE MODE Once windows loads it will look a little different in safe mode. right click on the desktop and select properties go into display tab, and change the resolution to 800x600 and hit apply. Restart PC and see if it helps any... All the best & hope it works John
Mar 03, 2007 | Acer Aspire 3610 Notebook
Acer Aspire 3610 Notebook Logo
99 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
