Question about Mitsubishi WS-65819 TV
My tv does not turn on it has power but when I press the power button nothing happends what could be the problem?
  • 27 Answers
Picture tub may need replaced
Posted on Dec 12, 2008
My 1993 nissan pathfinder wont start i get power to everything but when i turn the key nothing happends i replaced the starter and still wont start nothing happends not a sound could you please help
wire may be loose or your ignition switch could be bad hard telling if it was me id just install push button start cheap and easy to bypass all that
Dec 05, 2012 | 1993 Nissan Pathfinder
Why doesn't it turn on?
Could be an open internal fuse or power supply failure
Jun 28, 2012 | Televison & Video
Powers on to blue screen and nothing else
press the input button until it cycles through all of the inputs.
Feb 11, 2009 | Mitsubishi VS-50607 50" Rear Projection...
UNABLE TO BOOT htc touch pro
voldown, central key and reset botom at the same time, then text appear, choose number 1 for restore manufacturer default pressing volup or 2 for restore munufacturer default and format moviMand pressing voldown and wait a few seconds.
Oct 16, 2008 | HTC Touch Pro Smartphone
Universal remote px-rc1
Hi! This worked for me! I'm Leyz/leheart from the Philippines. I'm typing in CDRKing or CD-R King or CDR King Universal Remote Control PX-RC1 so that these keywords will show up if someone's looking for it too.
Mcneileric is right!
Real TV should be on! On the remote, press and hold the SET and DEVICE TYPE (in my case TV) at the same time. (Note: SET button is not any other button but the one with the word SET on it. You might have been searching on youtube and found that they are pressing other SET buttons but do press the SET button with the SET word). Then press SET again. Press the POWER button then + CHANNEL button then POWER button then +CHANNEL button then POWER button then +CHANNEL. (This process is so the remote could look for the code while you are pressing the +CHANNEL and the POWER is to see if the tv will turn off/respond to the remote). Do this repeatedly until the time that when you press the POWER button, the real TV turns off which means the real TV now responds. You will be shocked so DON'T press the +CHANNEL button anymore as this will instruct the device to look for another code. Instead, press the DEVICE TYPE button (TV for my case) to finish the set up.
NOW YOU CAN USE the REMOTE! Press the POWER button and this will turn on the TV!
Again...
TV onPress and hold SET button (yes, the button with the word SET) and DEVICE type button (TV/VCR,etc) at the same time for about 3 secondsPress SET againPress Power to check if the TV turns off^^If nothing happens, press +CHANNEL to search for codePress Power again to check if TV turns off^^If nothing happens, repeat the step between ^^ and ^^If the TV now turns off after pressing the POWER button, press the DEVICE type button to finish the setup.
Mcneileric, THANK YOU!!!!
Aug 22, 2008 | Radio Shack 15-2142 Remote Control
Computer wont turn on after 2 months of no use
clean the switch on/off connectors
give the motherboard a good clan with brush
Aug 18, 2008 | ASUS A8N32-SLI Deluxe Motherboard
Child lock
press&hold DISPLAY button on hand set& VOLUME button on tv front cabinet. or turn on tv setpower switch while pressing & holding volume + & volume- button on front cabinat.the adjust menu is indicated with each parameter on the screen. hope this helps
Oct 07, 2007 | Televison & Video
Sony trinitron messed up
pressed a bunch of butons on the tv and the remote means first of all it is due to that buttons as they might be loose fron inside or broken contact. if remote & tv buttons ok check for sound section in tv. if you are not tech person get tech help it is a simple job.
Sep 28, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Washer Stuck
depending on model, it sounds like a control module fault. Regards Engineer
Jul 26, 2007 | Kenmore 24032\24036 Top Load Washer
Mitsubishi WS-65819 TV Logo
46 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
