Question about Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell 2001FP. black/blank verticle band on right hand side.
When the self test screen is up, there is a black bar that runs up the right side of the monitor (about 1/8 the screen). Its not a resolution issue or that I have the postition to far to the left or something simple like that. The issue is the panel is not displaying what should be on the screen on that side. Occasionally the bar will turn into multi colored lines. Does the panel need to be reseated? Is the controller partially dead? I love this monitor and it would be a shame to toss it. Please no "check the dell site for common solutions". I know what I'm doing.
  • 2 more comments
  • roman_stypul Dec 12, 2008
    Its fixed!!! I used the same tricks I learned when I was a kid with digital watches... I just took apart the panel. Removed the processor/inverter assembly from the back, took off the metal frame. I then just pressed the adhesive attached ribbon cable back onto the driver board. Then I did the same with the lcd panel. powered it back up and everything looked great!!! reassembled and its working as good as new. This probably works with more than just this monitor... saved me $200
  • Andrew221 Jan 02, 2009
    I have the same problem and would enjoy more comments about the exact nature of the solution.
  • contrarian Feb 20, 2009
    How did you do this? How does one know if the adhesive attached ribbon cable is attached securely? I have the same problem and I'm trying to get rid of the vertical multicolor lines.
    "I then just pressed the adhesive attached ribbon cable back onto the driver board"
  • magalecki Apr 27, 2009
    I have red vertical stripe about 2 inches wide running top to bottom on left side of the screen.
SOURCE: Dell 2001fp - Ramdom horz strips
Just had the same issue with the horizontal lines. In my case, too, turning off the monitor would make it go away for a while. called Dell, turned out it was still under warranty (3 years), got a replacement monitor the next day. Way to go Dell!
Posted on Jan 11, 2008
  • 55 Answers
SOURCE: Verticle blue lines, left side
Your Display cable (inside your monitor) needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
OR, Buy a new one.
Posted on Mar 14, 2008
  • 46 Answers
SOURCE: vertical lines LCD Dell 2001fp
The LCD panel itself is bad, most likely the welds between the glass and the tab board. Probably not cost effective to repair.
Posted on Jun 21, 2008
MooMadCow
  • 38 Answers
SOURCE: Dell 2407WFP Monitor losing signal and having colored line artifacts
To your problem number 1:
I would check to see what the refresh rate is on your main monitor. Especially after waking the monitor from sleep, Windows tend to forget the refresh rate settings on secondary monitor and set it to the same as your main monitor. If your main monitor is set at 75hz or something, it could cause the secondary monitor to display the "out of range" message. When you reset the "extend my desktop to this monitor" setting, it probably resets the refresh rate to 60hz again.
This can sometime be remedied by checking to see if the monitor drivers are installed correctly. A lot of times the video card driver also gets in the way. I've had a lot of experiences with ATI drivers behaving very sporadically with multi-monitor setups, where they will consistently change to "plug-n-play monitor" and thus reverting any custom setting I have.
As to your problem #2:
I've had a fair bit of experience with this as well. The fact that the line shows the same way regardless of the monitor's own tilting orientation, means the error is probably coming from the video card signal rather than the LCD panel itself. This usually is a foresight of a nVidia card that's about to break.
I've went through many, many nVidia video cards over the years. They all inevitably break over time, probably because nVidia relies strictly on third party vendors... and to stay price competitive the third party vendors cut corners wherever they can. I always get the same horizontal line error over time as you described here.
The only way to know for sure, is to get a replacement video card, borrow one from a friend if you can, and see if the same problem still comes up. It's very possible for this to show up on only one of your two monitors. Try switching the monitor output as well, to see if the line now shows up on the other monitor instead.
Posted on Nov 04, 2008
c_robertson
  • 123 Answers
SOURCE: I have a dell monitor 2001fp ''Gone Black''
http://www.lcdrepair.us/2001fp-logic.html
The board that you may need.
Posted on Apr 29, 2009
Vertical Lines Dell Ultrasharp 2001fp
Sorry to say that it is a permanent damage of your monitor screen. Usually you can do nothing. But if you want to change the monitor screen, you have to visit a monitor & television specialist.
Cost will be 1/4 of a new monitor.
Sep 22, 2017 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell 2001FP vertical band issue
I'm having the same problem... there's also going to be about 5 years of dust sitting in there, so I hoping it might just be a failure of convective cooling. My first attempt to remove the bezel was unsuccessful, so I wasn't able to go in and look for any swollen capacitors or such. I have blown canned air in the sides, and it's actually doing a little better right now. Probably won't last... having a rather warm summer.
Jan 22, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
A black line heavy in the middle at the top right corner of the monitor
check whether Line present during self test, and in Bios screen
If Line present it is Hardware failure, Monitor needs to be repalced
If Line no Present,. Perform Factory Restore
Jan 12, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Monitor gone black but shows self test not floating
Sounds as though the control unit has died. There are 3 parts to most monitors. The video processor board, power supply board and the HV/backlight board. You can replace the video processor board.
Make sure you leave the unit unplugged first and set for an hour. Usually no other fix then replace the board.
Apr 29, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
Mar 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
Dell Monitor 2001FP Blank Screen
From your description your backlight is going out. The fluorescent light when it begins to burn out tries to draw too much power. Your inverter is sensing this 'too much' power draw and shuts down power to the back light. Replacing the backlight is the most technically difficult repair of an LCD, and most repair shops don't even offer this service. I recommend that you sell your LCD 'AS IS' on eBay or a similar website. The Power board and the Control Board are both usable parts that can be easily salvaged from most Dell Ultrasharp monitors.
Oct 05, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
2001FP LCD Half Display
please refer to this link for help..
http://support.dell.com/support/edocs/monitors/2001fp/EN/trouble.htm
Sep 09, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
OR, Buy a new one.
Mar 07, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell 2001FP
Chances are the driver tabs inside from the panel to the internal controller board have failed. This is the actual controller board that the internal video card connects to (hidden under the silver cover on the back of the physical panel).
It is not a cheap repair, and it is normally best to source another panel, or just replace the monitor all together.
Oct 17, 2007 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell UltraSharp 2001FP 20.1" LCD Monitor Logo
468 people viewed this question
Alun Cox
