Question about Sony DCR-VX2000 Mini DV Digital Camcorder
How to detach the flexible board attached to the right cabinet
I have a vx2000 and want to know how to detach the flexible board conecting the right cabinet and the camera body? Is it as simple as pulling the board end that's connected to the white socket from the
port? Or is this more complicated?
Thank You.
  • soc4life2323 Jan 06, 2009
    looks like my CCD went out again.i'm trying to get it off to see if my hunch is true, but i took out every screw,. and its still attached some how. if anyone can help, thanks.
  • 10,594 Answers
Can you post picture of that flexible board and connector to help you out.
Such Image will help me to understand what flexible board and where it is located. I can provide you exploded view from service manual.
Posted on Dec 12, 2008
How to install the conection wires on a central unit
Hello, if you are refering to tne outdoor unit you will have 3 wire coming from a flexible pipe and they shoyld be red, black, and green. The green connects to a ground screw inside the cabinet and the red and black connect to the line side of the contactor coil, does not matter which one goes where because they are equall legs of power. Then you will have 2 thermostat wires and they connect to the side terminals on the contactor coil and again it does it matter what side each wire goes to. Let me know if you have any more questions
Jul 09, 2011 | Coleman Heating & Cooling
I have a Talon electric line trimmer AT2307A. When I press the start button, the bottom attachment with the nylon line does not spin even though the motor is running.
Halfway down the shaft of the line trimmer, you can detach the line trimmer attachment ( this in so you can fit a lawn edger attachment if need be). Unclip the line trimmer at that halfway point and the start the motor and see if that rod inside the shaft is spining, if so, reattach the line trimmer attachment and see if the nylon line spins, if so, it wasnt attached correctly, if not, then there a break in the flexible rod going to the trimmer head, most likely at the bend.
Dec 29, 2010 | Garden
Problem is that when we open the camera white screen display on lcd ,no pictures display but movie recording is ok.
Connecting flexible cable between lcd board and main board of camcorder seems lose, open lcd cabinet and insert flexible cable in connector of lcd board properly to get image in lcd screen.
Below image shows flexible wire and connector on lcd board of MHS-CM1 camera.
Hope these info will help you.
Thanks.
Nov 17, 2010 | Sony MHS-CM1 HD AVC Camcorder
Kenmore smart wash quiet pack 4, steam wash when washing clothes the number F35 keeps showing, what does that mean? 1/2 of the clothes are wet, other half dry
The Central Control Unit detected a fault in the analog pressure switch. "Sud" may display 4 minutes prior to F35. Run a cycle without using detergent to clear possible sud lock condition. The first thing to check is the pump filter located behind the bottom panel. Remove the screws attaching the bottom of the bottom panel then pull the panel down and off the cabinet. Once the panel is off, remove the filter by turning the knob counterclockwise and clean the filter. Reach in the pump impeller with your finger and turn it manually to check it for restrictions and damage.
The next thing to check is the analog pressure switch assembly. Remove the screws attaching the top panel to the rear of the machine then slide the panel backward and off the cabinet top. The analog pressure switch on the top right rear of the cabinet with a clear hose attached to it. Check the hose for clogs and kinks then detach and blow air forcefully down through it to clear for any obstruction. Also blow air into the pressure switch itself to release possible contact bonding.
Nov 09, 2010 | Kenmore Washing Machines
How do I remove my cd drive and replace it with a new dvd drive?
  • First remove the cover of cabinet
  • You will see the power cord attached with the cd drive detach the power cord and also from th emother board
  • Now attach the new dvd in the same place and attach the power connecters as before
thanks
May 15, 2010 | Dell Dimension 2350 PC Desktop
1995 Saab 190 convertible, the rear windshield is detached at the top and bottom. It there a way to re attach this properly. The strip the window is supposed to be attached to is torn on the outside but is...
I'm not sure if it is exactly the same problem or not. In my case the glass detached/unglued, on both sides, from the strip that is sewn to the top. I used Clear RTV Silicone Adhesive and Sealant made by ProSeal and purchased at Harbor Freight.
Be careful not use acrylics . Even though they will water proof, they become brittle with temperature changes. You want and adhesive that remains flexible.
Good luck.
Nov 09, 2009 | 1995 Saab 900
VX2000
I would say power supply or power save problem check in menu to see if there is a powersave adjustment if not I say powersupply
Jan 16, 2008 | ViewSonic VX2000 (Silver, Black) Monitor
Dryer is plugged in & light comes on, but won't work
If your control panel display isn't working, a longer cord and more flexible hose won't fix it. You either have a control panel that has failed, or the wire harness that leads from the main control board to the control panel has an open or short, or has come loose. In addition, flexible dryer hoses (like the plastic ones) are not recommended because they tear easily, crimp or crush easily, and mice love to chew right through them to find a place to nest. It is highly recommended to stay with a semi-rigid duct hose, because they resist crushing, crimping and clogging. I hope this info helps. Let me know if you need further assistance.
Aug 15, 2007 | Whirlpool GEW9250P Electric Dryer
Sony DCR-VX2000 Mini DV Digital Camcorder Logo
67 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
