Question about HP 610 Color Copier
No Color Suppy Error Code
Last week I changed the color ink cartridge and did all I needed to do. After doing this when I copy one page it will display error "No Color Supply, Insert Ink Cartridge To Prevent Damaging the Product". The only way I can get rid of this error message is to turn the machine off and reboot it and then I'm able to copy one more page. I have printed out ink cartidge information which states that the color ink level is 99% and the black ink level is 62%, the printhead information looks good, all colors are printing.
  • 2 more comments
  • PastorPL Jun 30, 2008
    Same issue.
    pastor@epbc.net
  • dharmpreet Apr 28, 2009
    no color supply massage showing on the printer screen.. please give way to fix it.
  • Anonymous Mar 18, 2014
    printed page looks faded
  • Anonymous Mar 27, 2014
    incorrect color ink cartridge error code
  • 26 Answers
Try cleaning the print connectors on the cartridge housing area with a q-tip. This should resolve your problem, or else try to run ink cartridge test on your copier. Let me know if this fix your problem.
Posted on Jun 08, 2007
My printer doesnt make any print at all.
Can you copy a document under the glass? B&W and color?
Are you using Dell Series 5 ink cartridges?
Unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Plug everything back in. This will reset any error messages the printer has.
Power on the printer. Open the printer and take out the Dell Series 5 Black cartridge. make sure all the tape is off the cartridge and put the cartridge back in. Now do the same for the Dell Series 5 color cartridge.
Close the printer. It should print an alignment page. Any error messages?
Black cartridge = black side(left side) color cartridge = color side(right side)
Photo cartridge = black side(left side) color cartridge = color side(right side)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
If these ink cartridges are new, then take them to the place of purchase for a refund or replacements. If they're old, then try purchasing a new Dell Series 5 ink cartridge.
Rick
Aug 14, 2011 | Dell 924 All-in-One InkJet Printer
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
When I print from the internet my copy prints my color comes out a different color I think it might be my black ink is off I have a dell 946 all-in-one printer.
Can you copy a document under the glass? Black & White and color? Do they look ok?
If you unplug the printer from the wall and remove the power brick for 60 seconds, this will reset any error messages the printer has. I would then plug everything back in.
Open the printer(with the power on) and take out the Dell Series 5 black cartridge and then reseat it. I would then take out the color Dell Series 5 ink cartridge and reseat it. Now close the printer and it will print an alignment page.
Any error messages?
black cartridge = black side(left side) color cartridge = color side(right side)
photo cartridge = black side(left side) color cartridge = color side(right side)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges .
It's possible to get a Dell Series 5 ink cartridge with a bad sensor. I would that these back to the place of purchase for a replacement or a refund.
Rick
Jul 27, 2011 | Dell 946 All-In-One InkJet Printer
Scanner not working, but printer does print
Can you copy a document, when you put it under the glass? B&W and color?
If so, then it is a driver issue. Try reinstalling the printer by following the instructions located at...
962 All-In-One Inkjet Printer owners thread (W7)
If not, then...
Unplug the printer from the wall. Noe remove the power brick from the printer for 60 seconds. This will reset any error message the printer is getting. Plug the printer back in.
Turn on the printer. Open up the printer and take out the black cartridge and reseat it. Do the same for the color cartridge. Now close the printer and it will print an alignment page. Any error messages?
If you still get the error message, then it's possible that the sensor in the Dell Series 5 ink cartridge is bad. If this is a new Dell Series 5 ink cartridge, then take it back to the place of purchase for a replacement or refund.
black = black side(left) color = color side(right)
photo cartridge = black side(left color = color side(right)
It's possible to pirchase a Dell Series 5 ink cartridge with a bad sensor. Please take it back to the place of purchase for a replacement.
Rick
Jun 01, 2010 | Dell 962 All-In-One InkJet Printer
Printer not recognizing the new color cartridge
turn back your old color ink -> do cleaning page few times -> replace new one if the problem persist -> change color ink if the problem persist again -> change cartridge
Oct 01, 2009 | Canon PIXMA MX310 All-In-One Printer
Cannot print true color.
How do I resolve the error message "Calibration Page Not Found"? Error code: 3610 Question : How do I resolve the error message "Calibration Page Not Found"?
Answer : To resolve this error condition, correctly position a calibration page on the scanner. See the User's Guide for more information. How do I resolve the error message "Cover open"? error code : 3501 Question : How do I resolve the error message "Cover open"? Answer : To resolve this error condition, close the access door. The printer will not operate while the door is open. How do I resolve the error message "Color ink cartridge missing or not installed correctly"? Error Codes : 3511 Question :
Answer :
To resolve this error condition, reinstall the ink cartridge:
  1. Remove the color ink cartridge:
    1. Open the printer access door by lifting from the front center of the unit.
    2. Wait until the printhead is idle and silent, then pinch the latch on the color ink cartridge with your thumb and forefinger and lift it out of the printhead.
  2. Check the two electrical contacts on the ink cartridge for small marks, which should appear if the cartridge was installed correctly.
    If the electrical contacts do not have small marks:
    1. Reinstall the ink cartridge, making sure you press down on it until it clicks into position.
    2. Remove the color ink cartridge, then check the two electrical contacts on the ink cartridge again for small marks. Repeat if necessary.
    3. Reinstall the ink cartridge.
  3. Close the printer access door.
NOTE: See the User's Guide for more information about removing and installing the ink cartridge.
If the error persists:
  1. In the KODAK All-in-One Home Center, select the Help (?) icon.
  2. Select Maintenance.
  3. Select Firmware Upgrade, then follow the prompts to download the latest version of firmware, free of charge.
From Kodak support:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=9104/7269&pq-locale=en_US
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 11, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Ink
try buying your ink from 101ink.com I buy mine from there and they last as long as the name brands without the big price
Jun 02, 2008 | Office Equipment & Supplies
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
HP 610 Color Copier Logo
226 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
