Question about Apple iPod mini M9160LL/A MP3 Player
Connector damage The connector between the front panel and the electroncs card was pulled out during battery replacement. Can I buy a used front panel?
I see this post is old, Sorry for getting to it so late, Yes! you can buy almost used EVERYTHING from ebay.
Posted on Nov 30, 2007
SOURCE:
Hi, i have a canon 500d trying to fix, thanks, when i put battery in even with power off, or power on, the blue lamp right of LCD stays on (does not blink), and no power on to the camera other than th
Check the HDMI, mini-USB, and SD card connectors for damage. The DC/DC board is part of the front board and it comes with the battery compartment. Check front and back of board for liquid damage and impact. Check SD card slot for damage to the contacts.
Nov 28, 2014 | Canon EOS 500D / Digital Rebel T1i Digital...
Diagram of xps 630i motherboard connections
xps 630i motherboard layout
1 - unused fan connector
2 - power button (POWER_BTN)
3- front LED
4 - front panel USB connector (FP_USB)
5 - floppy drive (DSKT)
6 - master I/O board USB connector (MIO_USB)
7 - front panel IEEE connector (FP_1394)
8 - reset button (RESET_BUTTON)
9 - RTC reset jumper (CLEAR_ CMOS)
10 - password jumper (CLEAR_PASSWORD)
11 - internal S/PDIF connector (internal SPDIF)
12 - front panel audio (FP_AUDIO)
13 - PCI card slot (SLOT5 and SLOT6)
14 - PCI-Express x16 card slot (SECONDARY GFX SLOT4)
15 - PCI-Express x8 card slot (SLOT3)
16 - PCI-Express x1 card slot (SLOT2)
NOTE: This slot is not available in the dual-graphics configuration
17 - PCI-Express x16 card slot (PRIMARY_GFX_SLOT1)
18 - power connector (12V_ATXP)
19 - processor (CPU)
20 - processor fan connector (FAN_CPU)
21 - black memory module connectors (DIMM2 and DIMM 3)
22 - white memory module connectors (DIMM0 and DIMM1)
23 - main power connector (POWER)
24 - IDE drive connector (IDE)
25 - North bridge fan connector
26 - SATA connectors (SATA0-3)
27 - battery socket (BATTERY)
Dec 06, 2011 | Computers & Internet
How do I replace the video card in a Sony PCG-GRT270 Laptop ?
You cannot replace the video card on a laptop, they are built-in on the motherboard.
Dec 09, 2010 | Computers & Internet
Replace starter how do i do this
REMOVAL & INSTALLATION
(see Figure 3 to 6)
  1. Disconnect the negative battery cable.
  2. Raise the front of the vehicle and install jackstands beneath the frame. Firmly apply the parking brake and place blocks in back of the rear wheels.
Fig. 3: Disconnect all wires connected to the starter, including this ground wire on the starter moutnting bolt stud
  1. Tag and disconnect the wiring at the starter.
WARNING When detaching the hardshell connector at the S-terminal, grasp the plastic shell to pull it off. Do not pull on the wire itself. Ensure to pull the connector straight off to prevent damage to the connector and S-terminal. If any part of the connector is damaged, replace the damaged component.
Fig. 4: Some starters use a self-threading bolt to hold the starter cable
Fig. 5: Remove the starter motor (arrow) mounting bolts ...
  1. Remove the starter mounting bolts and remove the starter.
Fig. 6: ... then remove the starter-be careful, the starter motor can be quite heavy
To install:
  1. Position the starter motor against the engine and install the mounting bolts. Tighten the mounting bolts to 15-19 ft. lbs. (21-27 Nm).
  2. Install the starter solenoid connector by pushing it straight on. Ensure that the connector locks in position with a notable click.
Install the starter cable nut to the starter solenoid B-terminal. Tighten the nut to 80-123 inch lbs. (9-14 Nm).
  1. Connect any remaining wiring to the starter motor.
  2. Lower the front of the vehicle and remove the wheel blocks.
  3. Connect the negative battery cable.
Hope this helps: remember rated this.
Aug 11, 2010 | 1995 Ford Explorer
How to remove front dopr panel on 1995 Lincoln Town Car
Front Door Panel - Town Car - Removal
CAUTION: To avoid breakage of door pull cover(s), insert a screwdriver diagonally between pull strap and chrome bracket. Snap out both sides then remove.
Snap out two door pull strap retaining screw covers. Remove screws.
Remove two screws on front and rear side of front door trim panel.
The following procedure must be used during removal and installation of the door armrest and trim panel. Refer to the appropriate illustrations for component and vehicle model identification.
Using the Trim Pad Removing Tool from Rotunda Windshield and Moulding/Trim Removal Kit 107-R0401 or equivalent, pry the trim panel retaining clips from the door inner panel.
NOTE: Do not use front door trim panel (23942) to remove trim clips from door inner panel. Replace any bent, damaged or missing push pins.
Remove window regulator control switch housing from back of front door trim panel . Lift up housing, remove retaining screws and disconnect all connectors.
Disconnect driver seat regulator control processor switch (driver door only) if equipped.
Twist out interior lamp wire assembly and remove the front door trim panel.
Installation
Ensure plastic watershield is secured to door panel.
Position front door trim panel to door. Connect interior lamp wiring.
Position the window regulator control switch housing and connect switch connectors. Install the retaining screws.
Connect driver seat regulator control processor (14C708) (driver door only) if equipped.
Align door lock side to its mating slide on the sheet metal (front doors only).
Snap in front door trim panel. Ensure all retainers fit properly.
Install two retaining screws on front and rear side of front door trim panel .
Install two retaining screws and pull strap covers.
Good luck Remember rated this).
May 31, 2010 | Lincoln Town Car Cars & Trucks
How do i replace left door mirior
remove trim panel, remove mirror fasteners.
Glass, Outside Mirror—Town Car
Removal and Installation
  1. Push upper edge of outside rear view mirror glass (17K707) into the outside rear view mirror to expose latch release.
  1. Using a small flat-bladed screw driver or equivalent, move latch release to released position.
  1. Remove outside rear view mirror glass mounting back and outside rear view mirror glass from outside rear view mirror.
  1. Disconnect heater wire connectors and auto dimmer connector, if equipped.
  1. To install reverse Removal procedure.
Mirror, Power—Outside Rear View
Town Car
  1. Disconnect battery ground cable (14301). Refer to Section 14-01 .
  1. Remove front door trim panel (23942). Refer to Section 01-05 .
Trim Panels, Door Front—Town Car
Removal
  1. Snap out two door pull strap retaining screw covers. Remove screws.
  1. Remove three screws on front and rear side and center of front door trim panel (23942).
  1. NOTE: The following procedure must be used during removal and installation of the door armrest and trim panel. Refer to the appropriate illustrations for component and vehicle model identification.
  1. NOTE: Do not use front door trim panel to remove trim clips from door inner panel. Replace any bent, damaged or missing push pins.
    Remove window regulator control switch housing from front door trim panel. Lift up housing in front and disconnect all connectors.
  1. Disconnect wiring harness and heated seat switch electrical connectors if equipped.
  1. Remove the door trim panel.
  1. Disconnect two electrical connectors.
  1. Remove nut from outside rear view mirror mounting base.
  1. Swing outside rear view mirror (17682) toward driver door window glass to expose screw in mount base.
  1. Remove screw from outside rear view mirror base.
  1. Remove outside rear view mirror from front door (20124). Guide wiring and connectors through hole in front door.
  1. To install, reverse Removal procedure. Tighten nuts to 8-10 Nm (71-88 lb-
Nov 05, 2009 | 1996 Lincoln Town Car
Where can I read, for free, how to remove the drivers door panel and remove and replace the window regulator. I see these questions on this site but there are NO ANSWERS. What's with that? 1998 Cadillac...
GM Cadillac Deville_Fleetwood_ELD_Seville 1990-1998
Door Panels - REMOVAL & INSTALLATION
FRONT DOOR
Fig. Front door panel-1990-91 Deville and Fleetwood
Fig. Front door panel-1992-98 Deville and Fleetwood
Fig. Carefully pry up the power window switchplate and . . .
Fig. . . . gently remove it from the door panel
Fig. Remove the door pull strap retaining screw covers by gently prying them off
Fig. Remove the door pull strap retaining screws
Fig. Gently pull the inside door handle panel down and . . .
Fig. . . . release the rod from the handle
Fig. Carefully lift up the door panel to release the . . .
Fig. . . . retaining pegs on the door panel
Fig. Do not pull the panel too far away from the door, as some components still have wiring harness connected
Fig. Detach any necessary wiring connectors and remove the door panel from the vehicle
  2. Insert a flat-bladed tool between the door panel and the rear edge of the power window switch plate to disengage the retainer from the panel.
  3. Slide the power window switch plate forward, then label and detach the wiring connectors.
  4. Remove the power door lock switch plate retaining screw. Remove the switch plate and detach the wiring connector.
  5. Remove the pull handle retaining screws.
  6. Using a thin-bladed tool, carefully pry the courtesy lamp lenses off. Remove the courtesy lamp bulb.
  7. Pinch the courtesy lamp retainers and pull out the lamp socket holder. Detach the courtesy lamp wiring connector.
  8. Remove the door panel retaining screws.
  9. Using tool J-2459B or equivalent, disengage the door panel fasteners from the holes in the door. Detach any remaining wiring connectors and remove the door panel.
To install:
  1. Position the door panel close to the door and attach the wiring connectors.
  2. Align the door panel fasteners with the holes in the door. Push in on the door panel to install it to the door.
  3. Install the door panel and pull handle retaining screws.
  4. Install the courtesy lamps and switch plates.
  5. Connect the negative battery cable.
I really hope help you with this (remember rated it) Good luck.
Oct 12, 2009 | 2001 Cadillac DeVille
Need to find a way to take off the drivers side window motor
Motor
  2. Remove the door trim panel and watershield.
  3. Detach the motor wires at the multiple connector.
  4. Remove the motor retaining screws using Torx® drive bit set D79P–2100–T or equivalent, and separate the motor from the bracket and cable drum housing.
  5. Remove the motor from inside the door.
To install:
  1. Position the motor and drive to the cable drum housing and motor mounting bracket. Install the 3 motor screws and tighten.
  2. Connect the power window motor wiring.
  4. Check window operation.
  5. Install the watershield and door trim panel.
Door Panel
  2. Snap out the two door pull strap retaining screw covers. Remove the screws.
CAUTION To avoid breakage of the door pull covers, insert a small screwdriver diagonally between the pull strap and chrome bracket. Snap out both sides then remove.
  1. Remove the two screws on the front and rear side of the front door trim panel.
  2. Using the trim pad removing tool, pry the trim panel retaining clips from the door inner panel.
NOTE Do not use the front door trim panel to remove the trim clips from the door inner panel. Replace any bent, damaged or missing push pins.
  1. Remove the window regulator switch housing from the back of the front door trim panel. Lift up the housing and disconnect all connectors from the switch housing.
  2. Disconnect the driver seat regulator control processor switch if equipped.
  3. Twist out the interior lamp wire assembly.
To install:
  1. Ensure that the plastic watershield is secured to the door .
  2. Position the front door trim panel to the door. Connect the interior lamp wiring.
  3. Align door lock side to its mating slide on the sheet metal.
  4. Snap in the front door trim panel. Ensure all retainers fit properly. Install the two retaining screws on the front and rear side of the front door trim panel.
  5. Connect the driver seat regulator control processor, if equipped.
  6. Position the window regulator control switch housing and connect the switch connectors. Install it to the front door trim panel by snapping it in, or by installing the screw at the rear.
  7. Install the two retaining screws and pull strap covers.
  8. Connect the negative battery cable.
Aug 27, 2009 | 2000 Lincoln Town Car
Remove and replace passenger door mirror on 2009 ford explorer XLT, main part , I don't know how to remove the interior door panel. Pictures might help,
  1. Remove the front door trim panel handle bezel cover.
  1. Remove the front door trim panel handle bezel screws.
  1. Remove the front door trim panel lower screws.
NOTICE: To avoid damaging the front door trim panel, do not pull the bottom of the panel outward.
  1. Remove the front door trim panel by lifting upward on the armrest to disengage the panel clips.
  1. Disconnect the electrical connectors.
  1. Disconnect the lock rod cable from the front door trim panel.
  1. Disconnect the door handle conduit and cable from the front door trim panel.
  1. To install, reverse the removal procedure.
be patient during these procedures to not damage the trim panel...they cost $150>275 ec........GL hope this helps
Jul 06, 2009 | 2009 Ford Explorer
Apple iPod mini M9160LL/A MP3 Player Logo
Top Apple Audio Players & Recorders Experts
Parshiv Luthra
Marvin
Marvin
Dapid Candra
Dapid Candra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
