Question about BenQ PB6100 Multimedia Projector
Out of range
One of our offices is getting an "out of range" message and no image on the projector connected to a pc. How can I fix this?
  • 115 Answers
Go to menu, set the input select option to Auto. If doesn't work the set it to RGB/Computer, this will work.
Posted on Dec 13, 2008
Projector Image Cut Off, Native Resolution Not Recognized by PC
after you connect the laptop and the image shifts to the right, press auto adjust on the remote and the image will get OK.
If not try resetting the projector settings to factory [not the lamp settings]
this should solve the problem
if not change the main board
Jan 15, 2013 | Panasonic PT-AE900U Multimedia Projector
"Frequency is out of range"
Most likely your PC or laptop is currently set to a display resolution that is too high for the projector or is one that it cannot handle. Try setting your computer display to 640 x 480 or 800 x 600 and see if you can get the projector to work. If it does, then you can figure out the maximum display resolution you can use. Also consult your projector documentation for supported resolution modes.
Jun 21, 2011 | Sony VPL-ES4 Projector
Hitachi CPS-220 is saying 'RGB is out of range' when connected to PC.
This would indicate that the display settings on the PC are outwith the acceptable range of the projector.
To solve this, right-click on a clear part of your PC desktop and select "Graphics Properties" (in Vista). You then need to adjust the display settings. That is a very old projector which will accept a maximum screen resolution of 1024 x768 pixels. Try changing that 1st. If it doesn't work, keep that screen resolution and also adjust the refresh rate in Hz until you get an image.
The native resolution of that projector is SVGA (800 x 600 pixels).
Feb 14, 2011 | Hitachi CP-S240 Multimedia Projector
My clearco HD9000 projector works when connected to my PC, but does not work when connected to my laptop. I get a no signal message. Any suggestions?
You must enable external video on the laptop for one. Also, verify that the resolution is within the projector's range. Most likely, you do not have the external video connector enabled. There should be an "F" key with a symbol that looks like a TV screen. Holding down the function key and pressing that "F" key should toggle between the following 3 options:
1) External screen only
2) Laptop screen and External screen
3) Laptop screen only.
Toggle through the above as well and you should get the projector to work.
Dan
Jan 04, 2010 | Office Equipment & Supplies
PC expands and shrinks text/images when connected to projector
the resolution doesn't match. go into the menu on the projector and select auto image. this should clear up the resolution prob.
Jun 24, 2009 | InFocus LP 425 Multimedia Projector
On screen resolution issues
Bought a new XGA projector.../
It appears from researching that the native res for the Benq is too low 800x600 so I will never get a good picture even though most of the images I install are at least 10meg originals. Also the new projector will work in a bright room the Benq will not.
May 07, 2009 | BenQ PB6110 Multimedia Projector
Xd70u upside down image no remote how to control with PC
Try the menu feature, then installation, image reverse until it gets to the correct position. Note, the Image Reverse rotates in quarters. You can also access the Menu feature from the projector. It just happened to me and as I was looking for answers and playing around with it, I fixed it!
Good Luck!
Nov 25, 2008 | Mitsubishi XD70U Multimedia Projector
Can't get projector and computer to connect! no image
CHECK THE VGA PORT OF THE VGA SPLITTER IT WILL BE OK IF U CONNECT A MONITER FROM THE OUTPUT END AND SEE IF THE PORT IS OK THEN LATER U CAN GO FOR CHECKING PC AND CABLES.
Apr 08, 2008 | Office Equipment & Supplies
BenQ PB6100 Multimedia Projector Logo
696 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
