Question about Brother DCP-7020 All-In-One Laser Printer
I recently bought a MacBook and while the printer works just fine, my Brother 7020 won't scan.  I can no longer find the CD that came with the printer. Any idea how to get it to scan?  It says, "Connecting to the printer" I think, but nothing happens.
  • 4 more comments
  • plcmail Dec 12, 2008
    Thank you.  The driver is there already, no problem - it will print but it won't SCAN.  It says "Connecting to the PC" and just sits there.
    Hi Carl:
    You are a godsend.  Thanks for helping me.
    1.  The driver that came with the printer was screwed and didn't work with my PC so I tossed it.
    2.  The latest version of MacBook - I think 10 or 10.5 - it's the Leopard.
    3.  I just pressed Scan, like I used to on the PC.
    4.  Copy and Print work - it's just the Scan that doesn't.
    5.  I did download the update driver but the application doesn't open.
    ayy yii yii
  • plcmail Dec 13, 2008
    Okay, i downloaded the program but there is no icon and nowhere does it show up on my computer.  No where.
    Where did my comment go?  I downloaded the Twain program twice and it has yet to show up on my computer.  I did see the BrotherTwain.pkg file in my Recent Items/documents list but nothing happens when I click on it.
    What is going on?
  • plcmail Dec 14, 2008
    Carl, thank you!  It was the information about where to save it that did it.  I downloaded it again this morning and saved it to the desktop and lo and behold, there was the icon.  Thank you so much.
    Pamela
  • cpfister Jan 06, 2009
    I have the identical problem. I just downloaded and installed the driver. I went through the installer, my computer automatically restarted, and I tried to test, as you mentioned:
    "1 - Open the Image Capture application that came with your Mac.
    2 - Set the preferences (see item under Image Capture menu) so that scanners (middle tab) use TWAIN whenever possible.
    3- At this point you should see a scanner window that will let youcontrol the scanner to set up exactly how you want it scan, etc."
    At this point I have a couple of problems. My preferences under the Image Capture menu don't give me a middle tab for scanners where I can select TWAIN. It only scans the image, but doesn't give the the text recognition.
    On my PC, pressing "scan" and selecting "scan to OCR" used to pop up a screen from Brother that allowed me to choose "text", at which point it would scan to a window on my screen from which I could cut and paste text. No such luck on my Mac.
  • 169 Answers
You can download an updated driver from Brother, here is a link to the MacOS support page.
Carl
Posted on Dec 12, 2008
  • 1 more comment
  • Carl Gehrke
    Carl Gehrke Dec 12, 2008
    I understand that you can print but can't scan. The driver is used for both operations not just printing.
    Maybe we can get to this another way. According to the Brother website you ought to have a scanner control panel application that got installed from the CD, do you have this application and can you start a scan from it. If you're just pushing the scan button on the Brother it's likely that nothing will happen at the Mac end of things. Tell me all of this and I'll try to help:
    1) What version of MacOSX are you using?
    2) How are you trying to do the scan (give me steps to follow so I can play along)
    3) Did you install software from the CD that came with the AIO and then lost the CD or did you install it some other way?
    Regards,
    Carl
  • Carl Gehrke
    Carl Gehrke Dec 13, 2008
    Cool, now we're getting somewhere. I downloaded the driver for the scanner from this link, you'll have to click on the "more information" link to turn it into a download button. When you've got the right thing you'll see a ".dmg" file where ever it is that your browser is set to download files to. This is a disk image file, double click it and you'll get an icon on the desktop that looks like a removable disk and a new open window with an icon that looks like a packing box in it. The packing box thing is a package file that the Apple Installer program uses to put software on your Mac, double click the package file and run the install. You may get prompted for your Mac administration password.
    I'm not sure what will happen after the install, I'm using an old icebook Mac with OSX 10.3.9 so I didn't do it. What I did find out from this adventure is that the reason you could print and copy was that the Mac OS came from the factory with all the software you needed to print, just no TWAIN software to let you do anything with the scanner. Cool machines these Macs :-)
    OK, so now to test the newly installed TWAIN driver for your scanner. TWAIN btw is a standard for image getting not related to a particular manufacturer.
    1 - Open the Image Capture application that came with your Mac. You don't have to use this exclusively, it's just the one I know is there and ought to behave nicely.
    3 - At this point you should see a scanner window that will let you control the scanner to set up exactly how you want it scan, etc. Some even have a nifty preview window...
    Let's see if that gets you scanning,
    Carl
  • Carl Gehrke
    Carl Gehrke Dec 14, 2008
    If the download finished successfully the .dmg file had to end up somewhere on your hard drive. For your future downloads you need to know where files are going to download. If you're using Firefox as a browser the setting will be in the Main tab in the preferences, if Safari it is under the General tab in preferences. I set mine so that all files get downloaded to the desktop where I can find them easily.
    Unless the .dmg file is still opened you wont' be able to run the .pkg file because the OS won't be able to find it. You need to know about these disk images because they are a very common way of distributing software on Macs. a disk image (.dmg file) is one that the Mac OS knows to treat like a removable disk, so when you double click on it you'll see an icon appear on the desktop and that's all that will happen. The name of the disk image file is brxtwain310_5.dmg, here is what the icon looked like on my desktop when I double clicked it.
    Note that you'll still see the .dmg file too, the icon above is the "mounted" .dmg file.
    Double clicking on this icon will open a window with the package file in it, it is named BrotherTWAIN and will be the only thing in the new window.
    Double click on the BrotherTWAIN icon and the Apple Installer will start up, you'll see a window that looks like this:
    Click the Continue button and install the software.
    The rest should go as I've explained before.
    Regards,
    Carl
How do I scan a document and send by email?
Install the scanner driver from the CD provided. Scan your document, save it and attach to your email.
Oct 13, 2014 | Brother DCP-7020 All-In-One Laser Printer
Cannot install the Brother DCP7020 on a new computer
Perhaps you could download the software necessary from Brother support: (be sure to download the correct file for your operating system)
Brother DCP-7020 Downloads
Jan 06, 2010 | Brother DCP-7020 All-In-One Laser Printer
Reinstalled printer after having desktop cleaned
Your printer must must be connected to the computer. Does the MFC say Check connection? The Brother software must be installed. It creates a folder called ...\Control Center 3\Scan inside the user's My pictures folder where the scanned pictures are stored. That is what I get when I use the Scan button on my MFC-5460CN. If you use the Control Center you can choose the target storage location as well as the picture format (.pdf, jpg, etc.)
Hope it helps
Aug 30, 2009 | Brother DCP-7020 All-In-One Laser Printer
I'm running xp pro sp3. I have a brother dcp 7020. I can't install the scanner and ocr software. the install gets as far as searching for the usb connection aqnd hangs up. What can I do? Just use the 7020...
Make sure it's plugged into a good USB port and that Windows responds to that.  If you're using the most recent driver install program, things should go fine...otherwise, perhaps something is keeping the printer authentication handshake from going on (antivirus, firewall) and you can chill that out for the time it takes for the install to succeed.
Aug 12, 2009 | Computers & Internet
Printer wont work
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 06, 2009 | Brother DCP-7020 All-In-One Laser Printer
SCANNING WITH A BROTHER DCP 7020
I cant find the machine DCP-7020 but I think this machine is the same with model MFC-7420 if you have the installer CD follow these steps:
For USB Interface Cable Users
For Mac OS® 9.1 to 9.2
& Software
1 Turn off and unplug the MFC from the AC outlet and disconnect it from your Macintosh, if you already connected an interface cable.
2 Turn on your Macintosh.
3 Insert the supplied CD-ROM for Macintosh into your CD-ROM drive.
4 Double-click the Start Here OS 9.1-9.2 icon to install the printer and scanner drivers. If
the language screen appears, select your language.
5 Click MFL-Pro Suite to install.
6 Follow the on-screen instructions, and restart your Macintosh.
7 Connect the USB interface cable to your Macintosh, and then connect it to the MFC.
DO NOT connect the MFC to a USB
port on a keyboard or a nonpowered
USB hub.
8 Plug in the power cord and turn on the MFC.
9 From the Apple menu, open the Chooser.
10 Click the Brother Laser icon.
On the right side of the Chooser, select the
MFC to which you want to print.
Close the Chooser.
The MFL-Pro Suite, Printer driver and Scanner driver have been installed.
To install Presto! PageManager, click the
11 Presto! PageManager icon and follow the on-screen instructions.
Presto! PageManager has been installed and the installation is now complete.
You can easily scan, share and organize photos and documents using Presto!PageManager.
Dec 11, 2008 | Brother DCP 7010 Multifunction Laser...
Brother dcp-7020 can't scan and get cc027 error
Ok I know how to fix this issue, this involves going into the registry editor, also only available in windows XP, so be careful!
Click START -> RUN and type in REGEDIT
Go to HKEY_LOCAL_MACHINE -> SOFTWARE -> BROTHER -> CONTROLCENTER -> (version number) -> (model number) -> DEVICEINFO
Look in the right hand window for ENABLEWIA, if the value is set to 0, set it to 1.
Reboot your computer, should be fixed!
Mar 18, 2008 | Brother DCP-7020 All-In-One Laser Printer
DCP-7020 start up confusion!!
Yes, you can get the power cord and the USB cable from any electronics store. For the USB cable, get one that is an "A-B" cable, e.g. the cable with a square head on one end and a rectangular head on the other.
The power cable should be a standard 120v cable with male pins on one end (that go into the outlet) and female on the other (that go int othe printer. A used computer store would have lots of those they'll sell you for pretty cheap.
You will need drivers and software to use the printer. This normally comes on a CD, but you can also download it online.
http://drivers.softpedia.com/progDownload/Brother-DCP-Full-DriverampSoftware-Package-Download-19399.html
Jan 31, 2008 | Brother DCP-7020 All-In-One Laser Printer
Brother DCP-7020 All-In-One Laser Printer Logo
512 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
