Question about Linksys Wireless-G WRT54GS Router (e125894)
Http://192.168.1.1 is not working anymore? i cant set up the router
I got the router yesterday, at first 192.168.1.1 , the ip was working. later on it started not working at all. so i cant set up the router and use the internet connection. I tried to change my ip,default gateway,dns but none of them solved the problem. if anyone helps me,i'll be glad. thank you 192.168.1.1 is not working
    Genius:
  • 1,124 Answers
Reset the router and try again, To do that insert a pin into the small hole located on the back of the unit and keep holding a while till the lights go off and turn on again. Then release the pin and try again.
Posted on Dec 12, 2008
I forgot my RG54SE II username and passworn and i dont have the configuration cd anymore, can you help me please?
First connect your router to computer with ethernet cable.
Then you can access it with below link
http://192.168.1.1
or
http://192.168.0.1
if above not work then check your computer's ip address gateway ip is your router ip you can access router with gateway ip.
Type user as "admin" and password as "admin" or blank or "password"
If above not work then you need to RESET router to defaults.
For that press RESET button it is in back side of router.Press hold it for 10 seconds then all settings defaults then you can access it with above direction.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 29, 2009 | MSI Wireless-G RG54G3 Router
First thing to do when your router gives you problems: Unplug the power from the router, wait 5 minuted and plug it back in. Wait about 5 minutes (allowing time for the router to restart and reconnect) and try your connection again. If this solves your problem but the problem comes back after a while, do the same thing as above to fix it, go into your router settings and turn off the turbo mode.
Thanks for using the fixya forums!
Mar 27, 2009 | Linksys Wireless-G Broadband Router
I cant access the router's web-based setup
1. go to start -> run -> type cmd
2. at the prompt type ipconfig /all
3. note down the IP address of your default gateway
4. enter this ip address in internet explorer. eg. http://192.168.1.1
5. enter in your routers default username & password. ( usually admin for the username and admin for the password.)
Mar 17, 2009 | Computers & Internet
so you can access the internet by getting connected by LAN cable. so now try to open the router by its default ip and look for the wireless securities setting and reconfigure them properly and if you are not able to access the router than there is reset button which reset the router to company default. and once you have reset the router than you have to configure it again as per your requirement.
Jan 08, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
I can not connect to my router anymore, was working fine yesterday
access your router with following link
http://192.168.0.1
then type user name:admin
password is:admin or blank
then enable DHCP.then u can get ip automatically.
Nov 15, 2008 | Linksys Wireless-G WRT54GS Router...
you can not access the internet - maybe you will not read this..
Definately reset your router - and setup as you did previously.
Omit setting passwords until you have full confidence in the router and your own settings.
Aug 17, 2008 | NetGear WGR614 Wireless Router
Try resetting the router, press the reset button at the back for 10 seconds, after that release the reset button and then unplug the power of the router, then wait for 10 seconds and then turn it back on.
After that try accessing the IP of the router 192.168.1.1 (if this did not work try 192.168.0.1,this varies on the model number of the router). Or follow the same steps you have done previously.
Aug 15, 2008 | Belkin (F5D5231-4) Router
well, since you said that 192.168.1.1 was working when you first got it, you should try to reset the router (the button is on the back, press and hold it for 5 secs). that would be the easiest way to put your router back together.
Jul 30, 2008 | NetGear WGT624 Wireless Router
Linksys Wireless-G WRT54GS Router (e125894) Logo
97 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
