Question about Sony CFD-ZW755 Radio/Cassette/CD Boombox
CD PLAYER My Cd player turntable spins(sometimes. I only know if I lift the top and it's slowing down), there is sound coming from my speakers when the radio is on, but the CD player keeps saying "no disk". The platter(assuming that the top thingie underneath the lid)does seem to to be able to be pushed up. It only drops back down. Lastly, on the LCD screen(that you read to change tracks and show the megabass option) there's the word "sound" in very small letters. How can I get this CD player to play(read) and put out sound so I can listen to my CDs. I have done a lens cleaning with the Maxwell CD-340 Lens cleaner/w advanced angle brush. Thank you for your help.
2 Suggested Answers
fairlane
  • 50 Answers
SOURCE: the platter
Hi The platter is the "thingy" that the Cd sits on, and should be firmly attached to the spin motor, which spins the Cd. If that is loose, you must have it repaired at a shop, because the platter height is a factory adjustment, and the laser cannot focus on the disk if it is too far away, or too close to the lense, and it is a delicate adjustment requiring experience & special tools. It is not difficult if you have the tools, so your local repair shop may be able to repair it for a reasonable price. Hopr this helps, good luck!
Posted on May 02, 2007
CD player plays some CD but some of the others it spins them and tosses them off the cone
The center cone on the hub could be a problem if the player was not for the right juke. Each brand has their own style. (If you still have the old player, check and make sure the the hubs are the same.) The center cone on the hubs are glued in place so if they are different you might be able to pop the old one off and replace it to the new player. One other problem could also be the magnetic pressure disk that is supposed to hold the disk on the hub. Is it centered in the hold down arm or does it rub the sides? Does the disk wobble as it spins? The magnetic disk is supposed to hold it down on the hub to prevent it from wobbling and coming off the turntable.
Oct 20, 2014 | Wurlitzer Jukebox 1015 One More Time...
How can I fix the speed myself on a Steepletone ST918 record player ? 33rpm plays LP's at 45rpm !!!!
I am not familiar with this brand, but many turn tables adjust the speed using a rubber wheel and a turntable motor with different shaft sizes. The shaft is ground smaller in steps the further from the motor. As the rubber wheel is moved up the shaft, the slower the turn table spins. Most times you can lift the turntable up (may have a clip to hold it in place) and look to see if the wheel moves up and down on the shaft as you shift speeds.
Jul 18, 2014 | Wurlitzer Jukebox 1015 One More Time...
Cd player does not turn anymore
If the CD is picked up, put down, then the turntable doesn't spin it is usually a sign the CD player is faulty.
May 07, 2011 | Wurlitzer Jukebox 1015 One More Time...
The turntable is not revolving at the correct speed slowing the record down
Sounds to me like your belt is streched. Under the felt of the turning section, there should be two rather large holes. Insert your thumb and forefinger and pull the table off. You should also see where the existing belt is running. Insert new belt around the motor first and replace the table section. Now, through the two holes, manouver the belt onto the table section until it spins freely
May 16, 2010 | Crosley CR49-TW Tweed Traveler Turntable...
Truck Radio/CD Player, no sound coming out of speakers
Have you check the mute mode, maybe it is in mute mode.
Jun 01, 2009 | 2003 Chevrolet Avalanche
Rca record player is playing slowed down or sped up
Hi there
this sounds like the belt that drives the turntable itself is slipping you can normally access it by removing the securing clip by the centre spindle and then lift the turntable up and you should be able to see the belt give the belt a good clean with isopropyl alcohol refit and hey presto (if you still get slippage order a replacement belt )
Rgards Al "Alstech "
May 26, 2009 | RCA 200-Watt 5-CD Compact System Model...
The Radio,Cassette Player/Recorder. and CD Player all work. The Phonograph Does Not!
if it arrived by mail then the sender might have screwed the transit screws down to avoid damaging the phono , i am not familiar with memorex but if like most turntables there should be some big screw heads visible on the top of the phono or possibly even under the platter all you have to do is unwind the screws until the platter unit moves freely [you should be able to push it up and down a little bit ]
May 23, 2009 | Audio Players & Recorders
Sony MHC-RG222 cd player broken
It is not clear from your post that whether this is functioning perfectly other than the sound problem, if it doesn't, change the laser pick up.
Feb 14, 2008 | Sony MHC-RG222 CD Shelf System
Cd motor not spinning
The motors spin constantly if you play a disk on it all day think how many hours its runnign the motor. The lazers also move in and out and up and down during play and thats just one more mechanical part that can fail. Once we get all mechanical parts out of the devices we will have less trouble with them.
Apr 08, 2006 | Denon D-M3 Shelf System
Sony CFD-ZW755 Radio/Cassette/CD Boombox Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
