Question about Euro-Pro Shark 60 - 384
EUROVOX MAXV CODES
INEED THE NEW CODES FOR EUROVOX MAXV AND HOW TO PUT THEM IN MIDLANDS AREA PLEASE
  • Anonymous Dec 14, 2008
    hi need new code
  • 22 Answers
All new software, updates manuals and everything else to do with eurovox is here http://allsportsforus.OurToolbar.com/
Download my toolbar for free and there is eurovox tab on it that will give u access to everthing.
Posted on Sep 01, 2009
I have a singer 7466 and the bobbin won't load error code 88. please help!
An 88 error code is a generic one. It could mean that the needle isn't moving properly when the machine is turned on, there could be a problem at the bobbin or the computer for the machine is compromised. When did the error occur (regular sewing or bobbin winding)?
First, make sure that the needle is at the highest point with the hand wheel. Turn the machine off and then back on. Does the needle move to the side and back to the center? If so, then the problem is elsewhere. If the needle didn't move, I'd still recommend that you clean the area under the bobbin case.
If you were winding a bobbin, try a different bobbin. Check for any burs that might block smooth rotation of the bobbin. If you were doing regular sewing, also try a new bobbin. Check the bobbin case and hook areas for lint and clean them out.
If the error still persists, the machine needs to be serviced.
I hope this helps.
Jan 18, 2017 | Singer 7466 Mechanical Sewing Machine
Husqvarna Viking Designer Diamond I get the following error code: Remove any thread under the stitich plate and in bobbin area.
Can you get any other codes in the window or is this the only one that keeps showing up? You may need to put a new needle and bobbin in as they may have been damaged even slightly when things got tangled. Kate
Feb 04, 2014 | Husqvarna Designer I
Bobbin thread catches under plate and gets tangled when I try to sew. I cleaned out entire bottom area and changed thread, no help. Please, this is urgent. I am working on a customer quilt.
Check for burrs or scratches on hook. You can smooth with emery cloth. And put one drop of oil on the oscillating hook.I would insert new needle too and make sure foot up when rethreading so thread locates smoothly into the tension discs. I could feel your frustration and hope this helps. Jimmy
Apr 09, 2012 | Sewing Machines
Kenmore model 12312 needle jammed and unable to get needle out
unplug the machine first
unscrew the needle clamp holder screw enough to get the needle out
you might have to use some wire pliers, you may have to break the needle to get it out, please be carefull
then put a new needle in
clean under needle plate where feed dogs are for lint
clean in bobbin area for fragments of the needle & for lint & loose threads
Nov 18, 2010 | Kenmore Sewing Machines
Codes for eurvox
all new software, updates manuals and everything else to do with eurovox is here http://allsportsforus.OurToolbar.com/
Dec 05, 2008 | Euro-Pro 534DX Mechanical Sewing Machine
Eurovox codes 54 01 needed for 2/11/2008
Make sure u get the rite NTL codes
These codes are from the 4th of December. nt the 2nd as u reuested. have changed sinc :)
LATEST KEYS ALL AREAS
EX C&W KEYS -- KEYROLL 04/12/2008
PROVIDER CODE: 5C 01
KEY 00 = D4 A3 5D EB 7B F3 69 59
KEY 01 = 27 77 A1 FC 8F 9D 34 76
TELEWEST KEYS -- KEYROLL 04/12/2008
PROVIDER CODE: 5A 01
KEY 00 = C0 F6 61 87 91 F9 67 57
KEY 01 = F0 83 35 E5 28 40 49 B2
PURE NTL KEYS (UK) -- KEYROLL 04/12/2008
PROVIDER CODE: 54 01
KEY 00 = 3F B8 36 62 72 E5 E2 76
KEY 01 = 35 5E D6 40 6E AA 99 41
IRELAND CHORUS KEYS -- KEYROLL 29/06/2008
PROVIDER CODE: 5E 01
KEY 00 = 51 0F 32 A7 D9 34 BE 3E
KEY 01 = 8D A3 88 1B 4E 32 C5 8F
IRELAND NTL KEYS -- KEYROLL 18/06/2008
KEY 00 = 75 92 B1 CC 6F 23 20 F1
KEY 01 = F2 46 B1 59 04 61 77 71
Dec 02, 2008 | Euro-Pro 534DX Mechanical Sewing Machine
Bobbin issues
I bet you have put the needle in the wrong round, most common fault, check it and see, don't put too much oil in the bobbin case area, Ken drivewithken@blueyonder.co.uk
Jan 04, 2007 | White Sewing 1418 Mechanical Sewing...
Euro-Pro Shark 60 - 384 Logo
199 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
