Question about Cnet CWR-854 Router
CNet CAR 854 wireless modem setup on Imac G5
I have had no trouble setting up a Dynalink Modem supplied by my ISP slingshot.co.nz but I haven't been able to connect the CNet modem. The ISP only help with their supplied modem.
The comprehensive manual supplied by CNet only describes setup on the Windows OS.
Any suggestions appreciated.
John Whittaker  Wairoa New Zealand
Root
Posted on Mar 14, 2009
I want to connect my wireless to my lap top thank you
It seems the Dynalink Analog Modem doen't support wi-fi. You'll need both a wireless router/modem and a wireless network card in order to be able to connect using a wireless signal.
Mar 08, 2011 | Dynalink (1456VQE-C) Analog Modem
How can I install my linksys 2.4 ghz adapter without its disc?
Router setup is not a rocket science !
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Oct 23, 2010 | Linksys 2.4 GHz 802.11b Wireless - B PCI...
Ip for cnet car-854 modem
If you're looking for the IP address of this router , By default the IP address should be set to 192.168.62. , and you can access the router setup page by typing that IP address on your address bar.
But if you really want to make sure about your router's IP address do these using a computer connected to that router.
Click Start > Programs > Accessories > Command prompt it will open the black window and from there type IPCONFIG and hit enter just look for Default gateway that is your router's IP address.
Oct 02, 2010 | Cnet Wireless-G CAR-854 Router (CAR854)
My laptop keeps telling me that it has limited connectivity to my telstra wireless modem and will not go on to the internet, please help. its very frustrating!!
this is because your internet link from the router to your ISP is failing to connect.
Thus yo are limited to the router connection.
Mar 07, 2010 | Dynalink (V1456VQH) Modem
Good Morning , I am new 8) but wise. I have a Cnet adsl2/2+Router with firmware RouterTech_3.6.0D_20090922_2.91.1 (psbl; 20090922153753) .. I am looking for the easy set up tab after logging into the...
If the easy setup option is not available, you will have to configure your router manually. General instructions for setting up a home router are available here:
http://compnetworking.about.com/od/homenetworking/ht/routerconfigure.htm
Nov 26, 2009 | Cnet Wireless-G CAR-854 Router (CAR854)
Reccomend an effective wireless modem router combo for 50m transmission
Since you're having this connection problem with the router that you're using, I will advise you to get a wireless N router from this manufacturer Dlink,Linksys,Netgear the wireless N router from them will definitely solve your connection problem...
Jan 19, 2009 | D-Link AirPlus DI-524 Wireless Router
CNET CWR-854 Wireless G problem.
hello!
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear
stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
if this still didnot work, maybe you need to upgrade the firmware of your router
Apr 24, 2008 | Cnet (CWR-854) Wireless Router (cwr854)
Setup asistant will not work with Belkin wireless router & computer
Try the manual method.connect router to pc with ethernet cable
1.logon to 192.168.0.1
2.Connection type ; PPPOE
3.type in your username@ISp and pass
4.Save settings
5.Configure wireless setting(SSID,Wep)
Configure pc with the same SSID and WEP
uplug the ethernet cable and check if your are able t connect wireless
if you still have issue use this guide
Cheers !!!
Feb 23, 2008 | Belkin (F5D7230-4) Router (587009)
BT Voyager 2091 Wireless ADSL Router - DROP OUT
If you face frequent drop outs confirm with your isp that it's not a problem with line...and also check the physical setup of broadband check if your router is connected to main socket of your house where telephone line enters in your house......
now when you face drop outs check on your hard wired comp whether you remain connected or not if no its a problem with line..
if no reconfig your bt router for wireless network change the channel of your wireless network either to 1 or 11...
or either there is one other way reset your router to default settings by pressing the pin at the back of your router..
and after that your router will start its default wireless network i.e a unsecure network..
try connecting to that network if still the same there are drop outs it's a problem with router....contact bt to config the router...
Oct 01, 2007 | Computers & Internet
Cnet CWR-854 Router Logo
533 people viewed this question
Top Cnet Computers & Internet Experts
Prashant M
Prashant M
Marcin
Are you a Cnet Computer and Internet Expert? Answer questions, earn points and help others
