Question about Dell XPS M1530 Notebook
Hello, I have a dell m1530xps. The pc one day turned on but the battery was no chargeing, so it turned off. I have replaced the ac adapter with a new one from dell. Now with the new adapter it still does not turn on, what could be the problem? thank you
  • Dell Master
  • 32,281 Answers
The fault most likely is the power connector on the laptop, it should be repairable, it may only needs resoldering or at worst replaced.
When the laptop is on charge there is a LED (light) that is illuminated, try wrggling the power connector plug to see if this light comes on or flickers. If this is the case then the connector needs repairing.
If the light doesn't turn on or flicker then the problem is more serious. Repair costs may be expensive and it may be better to buy a new laptop.
Posted on Dec 13, 2008
New battery not charging
the old power supply must not be putting out enough power to charge
Jan 31, 2013 | Dell Latitude E6410 Laptop Computer (Intel...
Dell PC losing battery very fast
turn off the computer , then remove the battery . reboot system and try rebooting the notebook with the AC adapter only.
this is to ensure the Ac adapter is working fine, and if it is, it should be charging the battery properly when its installed.
now, turn off the system again. re install the battery and try booting it up with the battery only
if the battery hasn't enough charge, then attach the AC adapter. If you have allowed the computer to charge the battery (while the computer is powered off) and it is not charging the battery, then you need to replace the battery definitely.
you can get a new battery (if you are in North America) from
please send me 4 thumbs up
Jun 06, 2011 | Dell Vostro 1500 Notebook
Hello, I have a Dell Inspiron 1501. It has shut down on me in the middle of my session and now will not come back on. I plugged in the adapter for it to charge a few mins then the charging light shows but...
Don't think as a battery error, if you can use without the battery ,pls check with ac adapter without battery.because there may be a short circuit with charging unit or power side, you have to test before blow up the unit. if blow up chip or mos fet, it will be hard to repair.
May 05, 2017 | Dell InspironTM 1501 Notebook
I have dell c840. Suddenly only the left most light of the three lights gets orange when power is switched on and then there is no activity and screen remains blank. Bty light when plugged in also remain...
shut down computer - unplug power cord from laptop - remove the battery from laptop - plug Ac adapter into computer and Ac outlet (wall)
turn on computer
if computer does not turn on, replace the AC adapter and cord - then place battery back into computer
plug in new Ac adapter and cord - recharge battery - if orange light stays on after 4-6 hours of charging battery, you need new battery as well - replace battery, charge it up and it should be fine
if you have attempted these steps before and no change occurs, then you may have issue with power connection in computer - locate a service centre to replace power connection on computer
Nov 07, 2010 | Dell Computers & Internet
Dell 6000 power problem?
Troubleshooting a power problem is fairly simple:
1 Try a different AC adapter, see if there is any change 2 If system will not power on with a known good or new AC adapter, then the power connection on the motherboard is likely damaged and the motherboard will need to be replaced.
Mar 24, 2010 | Dell Inspiron 6000 Notebook
My dell inspiron 1501 won't charge when it's plugged in it works for awhile then it seem to loose contact and the battery runs down fast.
It would appear that there is a motherboard issue with this model laptop from Dell. Below is a link to the discussion thread for the problem you described. Unfortunately, there is no current solution for this issue - short of replacing the laptop.
Dec 03, 2009 | Dell Inspiron 1501 Notebook
Hello, if your battery isn't charging it might be the AC adapter that is defective, although it might be the battery as well, I can only provide you with english or spanish support, but if it works for you, please try to swap your AC adapter with a known good one from a friend or another computer, please check if the battery will charge, if it does, the AC adapter will need to be replaces, the best way to do so will be to contact Dell Support.
Jan 21, 2009 | Dell Inspiron 1501 Notebook
Battery will not charge
It's your ac adapter that is causing this issue. The ac adapter doesn't supply enough power or doesn't supply any power at all to the battery. Try to borrow another ac adapter from any inspiron system and if that works, then you need to replace the ac adapter, else, it's the motherboard.
Hope you find it helpful.
Karlox™ :)
Jul 28, 2008 | Dell Inspiron 1501 Notebook
Dell latitude D 610 battery dead
dell latitude batteries have a built-in battery life indicator on it. Press the button to see how much charge is left or if there's no charge at all. It sounds like your power adapter isn't charging
your battery. visit: and choose the model of your latitude laptop.
u can get it cheaper on ebay or any 3rd party vendor. hope this helps.
Jun 16, 2008 | Dell Computers & Internet
Dell XPS M1530 Notebook Logo
101 people viewed this question
Alun Cox
