I have a brand new 02 Xda II mini out of the box and am unable to send files to it usiing bluetooth. I have anoher one as well and the bluetooth function works fine. I have checked all the settings of the new one and coompared them to the second unit and they are identical, what next? I have tried several phones and a mac to send files and the same problem occurs with all. Regards Pippa
Make sure the names of the phones are different if they are the same make, as the bluetooth may see only one phone and see if there is a 'find me' or 'show phone' or similair on your phone. See if your new phone can scan for new devices and see your old phone or pc. The other thing to check is see if the bluetooth works int when you insert your sim card from your previous phone, as the function may not be activated.
Thank you kind sir, I had failed to tick the "Receive all incoming beams" in the settings folder.
Works fine now.
Thanks
Pippa
my razor phone is sending files through bluetooth, but every time i try to get one it says file corrupt!! how do i fix it?
Please help My O2 XDA II mini can not add my bluetooth. Previously this bluetooth works properly due to freqently reset of my phone, this bluetooth can not be discovered in my phone.
I've done the following set-up process:
Switch on my XDA phone and bluetooth > Press START > SETTING>CONNECTION>BLUETOOTH>CLICK "TURN ON BLUETOOTH>CLICK MAKE THIS DEVISE DISCOVERABLE TO OTHER DEVICES> CLICK "DEVICES">TAP "NEW" TO ADD NEW DEVICE.
RESULT: O DEVICE WERE FOUND
