Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Timer light won't stop flashing, no powers since setting timer
The TV was working fine until I made the mistake of trying to have the set come on automatically in the morning. The set is conected to a dish reciever. The set came on at the prescribed time but unfortunately it did not run through the dish reciever. I turned off the set and the reciever. When trying to turn on the set again, the timer light started to flash and the power light would not come on. I diconnected the power from the TV and left it off for 2 days. Plugged it back in and the green timer light started to blink again. Still no power, TV would not turn on. Can anbody help? Did setting the timer to come on mess something up?
  • Anonymous Dec 14, 2008
    I also have a blinking green timer light. The TV will not turn on. Is it time to send it to the repair doctor or does someone know how a non-technical person can get out of this mess.
DM BOARD replace entire board (New $707.25 Used: $325-561.25
Replacing few capacitor will be temporary fix, at best.
Advise: Please get 3-4 yeras of warranty on such a big-ticket item
Posted on Feb 11, 2009
    Problem Solver:
  • 6 Answers
Check ur power board ans dm board u my have bad caps
Posted on Dec 13, 2008
ML600 won't turn off
The clock module for power pack is not sold separately.
Set timer to auto using override knob so lights are on, then plug power pack into cheap timer.
Check outlet with circuit analyzer.
Try connecting power pack to another outlet.
Copy following link for warranty information, tips to help power pack last longer, links to trippers, troubleshoot, etc.
Jul 15, 2012 | Malibu ML600TW - Low Voltage Power Pack -...
My Dryer won't stop drying until I open the door.
If it does this in a Timed Dry setting the timer is bad. If it does this in an Auto dry setting it could be a bad moisture sensor or a bad timer.
Aug 21, 2011 | Crosley Dryers
I returned from vacation last night and noticed all four of my coach lights were off. I thought...the timer needs to be reprogrammed due to a power outage while I was away. The red indicator light was...
1) You performed correct troubleshoot steps down the line.
Last thing would be to install defect timer on another light circuit in house, and see if problem is the timer or wire going to coach lights.
2) EJ351C has 1 year limited warranty.
Buy new EJ351c and install single pole light switch until timer replacement is available.
Timer has easy 2-wire installation. Turn off power. Connect new timer just like old one was connected. Either timer black wire connects to either wire in switch box.
Aug 08, 2011 | Intermatic Hardware & Accessories
I have a Sharp 32"
try checking the system for timer or sleep mode operation try to setting it off
Jul 16, 2011 | Sharp 25R-S100 25" TV
I have a Woods Outdoor Lighting timer - model no. 961012, with a 3 outlet powerblock that I have connected 2 lighted Christmas decorations. I had it set for dusk to dawn, and everything was fine until I...
If this is not your timer, add a comment.
A number of folks are writing in about dusk-dawn-timers flashing.
The manufacturer suggests turning photo-eye away from all lighting when installing timer.
Always aim photoeye toward dark region of yard.
I would unplug the timer and let it reset.
Try timer again, turned away from lights so there is no feedback.
Put black tape over photeye and see what happens.
If timer still doesn't work, then timer is defective.
Maybe photoeye circuit was overwhelmed by intense light converted to electrical input.
I test timers, and 4-6% arrive defective, and most last just a season or two, and then you buy another, but the price is affordable.
Local Home Depot sells the GE 15107 outdoor yard stake or wall mount.
I bought one tonight for testing.
It has no photo eye
It has a dial timer where you set exact on-off times by moving plastic segments on dial perimeter.
For example set timer for ON at 5:30 and OFF at 6:00 am depending on your latitude north or south.
geno_3245_189.jpgphoto eye on yard stake timer
Dec 16, 2010 | Woods Outdoor 3 Outlet Yard Stake With...
How do I set the Woods N1506 timer?
N1505 timer manual:
N1506 is heavy duty outdoor timer with display screen.
Plug timer in and display flashes C.
Set current time: press Time button once and display shows 1 am
Keep pressing time button until current time with am pm displays.
Dot in lower right corner corresponds to pm hours.
To set timer program:
Press Mode button, display flashes P
Press Time button until desired ON time displays.
Press Mode button again and display flashes E
Press Time button until desired OFF time displays
When programming is finished, press Mode button and display shows current time.
To reset timer, unplug timer for 10 seconds and re-program timer.
Timer must be reset after power outage. Display will warn by flashing C.
Plug lights into timer.
If lights have a switch, switch must be on.
For manual override, press Mode button, and display shows O and lights will be ON until next program change.
To use timer function, press Mode button until current hour displays.
Dec 01, 2010 | Woods Outdoor Lighting Timer
Timer light continues flashing; won't turn on/off
Could be an open internal fuse or power supply failure
Jun 25, 2017 | Mitsubishi WD-65731 65" HDTV
I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Jan 23, 2010 | Mitsubishi WD-52628 52" Projection HDTV
Av-32d302 tv
The set is shutting down because a problem has been detected. Replacing the remote will not help. Count the flashes and call a JVC servicer to get an idea about what the specific problem may be.
Jul 29, 2008 | JVC AV-32D302 TV
Standby/timer light
check your menu settings to see if your off timer is activated or set.
Mar 19, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
304 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
