Question about Hitachi 53UDX10B 53" Rear Projection Television
Hitachi 53FDX01BA with no picture, sound is fine.
I'm not sure exactly when or how this problem came about, as I just acquired it (got it for free since I lugged it off). It turns on, and the sound works perfectly, but I get no image whatsoever. I removed the back to make sure there was a mirror and it was aligned, and it was. I am getting nothing out of the projectors'
  • 25 Answers
Sounds like it could be a problem with the DLP Lamp. There aren't any noises coming from the TV to suggest heat failure or the colorwheel going out is there?
You've got sound but no image, I'd say it's the lamp.
I get my lamps from DLP Lamps.com, they come with instructions for self installation, and even come with gloves!
Posted on Dec 12, 2008
Why does my hitachi projection screen television power up but the screen does not come on?
One of 3 problems
Cables not connected properly from source
Bulb out
Source selection needs changing
Sep 28, 2014 | Hitachi Televison & Video
Power surge
replace the power surge, you must understand this kind of device, you must select according with voltage+amp for protect your equipment. There are cheap +higher use the most convenient in order to protect you inversion equipment
God bless you
Jul 21, 2013 | Hitachi New Original 53FDX01BA Remote...
Hitachi 53FDX01BA Ultrascan HD 53 inch TV dark screen can see the pictures but very dark and audio is still there. Do I need to replace a bulb? Do these tvs have a bulb??
There are three general reasons for this problem.
I am available via the Market Place here if you want detailed information.
SD TECH
Oct 27, 2011 | Televison & Video
HITACHI 53FDX01BA THE PICTURE IS GETTING DIM. ALL THE COLORS LOOK GOOD EVERYTHING IS JUST GETTING DIM
This is a common problem on this Hitachi model. You can get the parts and repair instructions from www.TvRepairKits.com. In most cases the TV will look real dim or have no video...but audio will work,
Jul 18, 2011 | Hitachi 53FDX01B 53" Rear Projection...
How can I adjust the convergance on my hitachi 53fdx01ba if I have lost the remote contol that belongs to the tv
You have to have the Hitachi remote to do this:
CLU-5713TS1 is the updated part number. With a working remote there are two ways---one in the customer menu and another in the Tech menu.
If you get a remote and want to know how to get into the convergence mode in the TECH part--let me know and I will tell you how to adjust there and SAVE the adjustments.
If this has helped you, rate this solution as I do this here for free.
SD TECH
Nov 09, 2009 | Televison & Video
Have a 53FDX01BA that has No picture great sound. Cable tech says it's the tv. Why would it be doing this
It sounds as if you have lost your heater circuit for the picture tubes. This circuit actually allows the tubes to light. RP41 which is a 1.5 ohm resistor goes out of value causing the circuit to lose its voltage from the power supply. If this is not the problem there is probably a loss of high voltage. High voltage can be dangerous so you probably want to leave it for a pro. Thanks
Oct 28, 2009 | Hitachi 53FDX01B 53" Rear Projection...
Sound but no picture. can not find listing for a bulb
probably is a light. you can easily replace it yourself, but prepare to spend 2 to 3 hundred for thr bulb.
Apr 25, 2009 | Televison & Video
53 INCH HITACHI RED CONVERGENCE
This is a defect most likely on the convergence board.
You should have the manufacture authorized service people repair the set. You can end up buying a convergence board, and the service manuals, and still have some other faults.
For information and parts, look up the Hitachi home page on the net and go to their support area.
Jerry G.
May 18, 2008 | Hitachi 43FDX01B TV
Hitachi 53UDX10B 53" Rear Projection Television Logo
363 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
