Two computers have same IP address...what to do?
I have two laptops which share the internet connection through a wireless router.The router is dlink WBR 1310. But i can use internet on only one of them....I keep getting the error message...two computers have same IP address...please contact network administrator....what do i need to do for this? I cannot access the internet on both the laptops simultaneously,,,,
  • kunalkanani Dec 12, 2008
    hi,
    thanks a lot for the reply......but still didnt find the solution....
    In internet protocol TCP/Ip....my IP address and DNS details are set to detect automatically.....and my router settings are as follows too:
    Router Settings : Use this section to configure the internal network settings of your router. The IP Address that is configured here is the IP Address that you use to access the Web-based management interface. If you change the IP Address here, you may need to adjust your PC's network settings to access the network again.
    Router IP Address :
    Default Subnet Mask :
    Local Domain Name :
    Enable DNS Relay :
    DHCP Server Settings : Use this section to configure the built-in DHCP Server to assign IP addresses to the computers on your network.
    Enable DHCP Server :
    DHCP IP Address Range :
    to (addresses within the LAN subnet)
    DHCP Lease Time :
    (minutes)
    my DCHP server is enabled but still i am facing a problem.....with the internet while browsing simultaneously......So if you do have an alternate solution do let me know
    Problem Solver:
  • 15 Answers
Hi, at first you have to get into both PC's network cards settings > properties of network adapters, select Internet protocol TCP/IP and click on properties - make sure the adapter is set to get the IP address and DNS details automatically.Then get into the routers admin website in web browser (I think 192.168.0.1) while connected to router. Find the option DHCP and select it to enable. Save the settings and try to reconnect with both laptops again and it should work.
Posted on Dec 12, 2008
Reset the TCP/IP stack in Windows to possible repair the Internet connection if it is corrupted.
Go to Start, Run and type in CMD.
Go to C:/ (probably by typing in "cd C:/" at the prompt - deleting the quote marks)
Type the following commands:
netsh int ip reset reset.log
netsh winsock reset catalog
Reboot your pc.
repeat on the other machine.
Posted on Apr 11, 2010
  • 4 Answers
Http://www.hi-tech-it.com i have a dir 628 and two laptops are connected wirelessly they both have net access but show the same ip?
Posted on May 21, 2012
  • Donnie Binkley
    Donnie Binkley Jan 08, 2014
    have two laptops wth same isp, I won't to change the adress on one so I don't lose my contacts
I cant connect my dell laptop nor detect D-Link dlink Wireless N 150 Router through wifi but my mobile devices can and my desktops can also. please help me able to connect in the internet using wireless...
Try assigning your laptop a static IP. To do this in Windows:
  • Open Windows Start menu.
  • Open Control Panel.
  • Classic view: Open Network Connections
    Category view: Select Network and Internet Connections, and thenNetwork Connections.
  • Double-click on your active LAN or Internet connection.
  • Click Properties
  • In the General tab, highlight the Internet Protocol (TCP/IP) item, and clickProperties.
  • In the General tab, click Use the following IP address, and enter: - IP address. The static IP address you want to assign to this computer (try 192.168.1.110 to start). - Subnet mask. Subnet mask used by your router (try 255.255.255.0 to start). - Default gateway. IP address of your router's default gateway (try 192.168.1.1 to start).
  • In Use the following DNS server addresses, enter all the IP addressses for the DNS servers your router uses (or you can try your router's address, probably 192.168.1.1).
  • Click OK.
Source: http://www.hotcomm.com/faq/faq_staticipxp.asp
Please leave feedback for this answer, thanks.
Mar 10, 2011 | D-Link dlinkgo Wireless N 150 Router...
May laptop won't connect to internet, my laptop is in good condition. i already reset my dlink wireless router but still don't connect to internet. The connectivity is ok. my laptop detects the router but...
Is the laptop detecting any wireless networks in the area? if yes then it means that the wireless card is ok if not make sure that the wireless is turned on on your laptop.
I the laptop detects wireless networks in the are then we should check the settings on your system or something that could be interfering with the wireless connection on your system,
what are the error/s when trying to connect wirelessly?
Tis can be multiple things regarding wireless, if the error is windows was unable to conenct to wireless evice then try recreating the wireless network on your laptop in network and sharing center if you have win7 on the laptop, network conenctions if you have XP.
I the laptop connects to the router but does not get internet acces then better check you routers network key if it is correct in your laptops settings, also check your IP address if it is correct if you IP starts with 169... then have a bad IP address on your laptop, go to the command prompt type ipconfig /release, then press enter, then type ipconfig /renew then enter to renew your ip address, hoping that the IP address changes it should begin with 192...
Feb 21, 2011 | D-Link DIR-655 Wireless Router
Can 3 computers (1 desktop and 2 laptops) share the same IP address?
No. Each device connected to a network must have a unique address so that data can be properly routed. If you want to share an Internet connection among several computers, you need a router. The router provides a single IP address connection to your service provider on one side. Then each computer connected to the router, wired or wireless, gets its own internal IP address from the router. As data comes over the Internet, the router takes care of getting it to the proper computer.
Dec 06, 2010 | D-Link DIR-615 Wireless Router
I have a trendnet wireless router tew 432brp, a new hp windows 7 laptop, and old xp laptop and i want to share the connection with my verizon um175 aircard. this has worked for several years with the old...
The router connects computers together . You are using a windows 7 p.c and connecting it to an internet connection via a usb verizon um175 aircard.
I think you need to share the internet connection with the rest of the network and may need to feed the ethernet cable into the feed port of the router. I have not done this before but logically the windows 7 computer would have to act as a gateway to the internet.
http://www.dummies.com/computers/operating-systems/windows-7/how-to-share-an-internet-connection-in-windows-7/
https://www.ibvpn.com/billing/knowledgebase/53/Internet-Connection-Sharing-on-Windows-7.html
Note the default gateway is going to have to be the windows 7 ip address on the other computers
You may need to set the ip address on windows 7 to a static address and then change the dhcp server settings default gateway and also increase the first address to not include the windows 7 ip address or the routers ip address in the lease range for shcp.
Mar 17, 2017 | Trendware TEW-432BRP 54Mbps Wireless...
Can not connect to internet
My first guess is that your Dlink ADSL modem is really a modem router, so you are getting double routing. Sometimes this works just fine, though, so I'm not confident that's the whole explanation.
You'll need to setup your IP plan carefully
set the D-Link modem(router?) to bridging mode & the DLink wireless router does the login to Exetel.
DLink wireless router WAN side: DHCP + login to Exetel
DLink wireless router LAN side: 192.168.0.1
Subnet 255.255.255.0
DHCP on: range 192.168.0.10 to .20
DNS Servers: 220.233.0.3, 220.233.0.4
with PC's wireless adaptor set to DHCP
so picks up eg:
IP address: 192.168.0.10
Gateway address: 192.168.0.1
Aug 03, 2009 | Computers & Internet
Cannot connect to DLink DIR-655
The part below is all you need to look at, the rest is Ethernet which is your wired connection, ethernet card.
Here is what are causing your problems from what you gave me and basically your computer is not communicating with the router:
1)I don't see any IP address for your laptop so you can't get on the internet if you don't have an IP address, also, I don't see any gateway address. The gateway address is your router address, and that address is given to the router automatically from your Internet Service Provider.
So if your computer cannot see the gateway address then the gateway address (router) cannot give you an IP address to get on the Internet.
Your Wireless card looks ok, that is the physical address and if you were able to do the loopback then its working.
So on your laptop I would begin from the beginning. Go into network connections and delete the DLink connection if it is there. Then Start>control panel>Network connections>click wireless network connection>click change settings of the connection on the left window>click wireless network tab>make sure checkmark"use windows to configure my wireless network settings>click add a new network>TYPE IN THE SSID FOR THE NETWORK>ENTER WEP/WPA KEY>CLICK OK, then close and you should be connected.
You said other computers are able to access the internet thru the DLINK so it all points to your laptop not being configured correctly.
HOWEVER :)...I see alot of "Media disconnected in your list. Make sure all of the lights are working on the front of the router, if not check the cabling or call the ISP sometimes the problem is on their end. Hope this helps, keep me updated.
C:>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : HPdv7
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Atheros AR5009 802.11a/g/n WiFi Adapter
Physical Address. . . . . . . . . : 00-24-2B-12-FD-63
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
May 01, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Dlink WBR 2310 cannot connec to internet
Try to bypass the router and connect to your modem. Make sure you have Internet connection.
>If you have Internet connection. connect back your modem to the router.
>access the configuration page of your router.
>If you are given a specific IP by your Internet Service Provider, use that one.
>Login to your Dlink (type in on the address bar 192.168.0.1)
>Click Setup and Internet > Click on Manual Configure
>My Internet connection would be Static IP
>Type in your IP address, Subnet Mask, Default Gateway, Primary and Alternate DNS
>Click on Save Setting on top.
but if your Internet Service Provider did not provide you those informations
> Under My Internet connection Type choose DYNAMIC IP
>Click on Clone Your PC MAC address
>Click on Save Settings
>If it ask you to reboot, click on Reboot.
>At the very top click on Status
>Under Status look for WAN
>Under WAN look for IP address
>If you have values beside from zero it means you have Internet connection otherwise, call your dlink manufacturer for manual configuring your router for Internet connection.
Jan 30, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Dlink di-524 connect to RV042
Hi.
You need to cascade the Dlink wireless router to your RV042.
Suppose your RV042 has a default IP Address of 192.168.1.1, and the DLINK IP uses 192.168.0.1. Your Physical connection is from the regular port of the RV042 going to the WAN/Internet Port of the DLink wireless router.
Once you do that, your Dlink router should automatically obtain an IP from the main router. If it did, configure your wireless settings and you should be able to connect via wireless.
This is just one way to cascade your router to another router.
For more information, click here.
Jul 21, 2008 | D-Link AirPlus DI-524 Wireless Router
Wireless router
Yes, you can use wireless router with the modem. I guess the actiontech DSl router that you have is also Wireless one. If so, you can use just the DSL router for wireless connection. If you really want to use Dlink router with it, Connect the ( WAN port ) of the Dlink router to the ( LAN Port ) of the Action tech modem [ modem(LAN)-->Dlink(WAN) ]. Once you do this connection, better to do power cycle ( unplug the pwr to the dlink first, then, disconnect the pwr to action tech - wait 1min and plug the pwr to modem, wait for DSL light to be solid , then put the pwr back to dlink ). Make sure DSL light on the modem solid, internet light & WLAN light on the link glowing.
- Make Hardwire connection between the computer to Dlink and check the ip address on the computer whether it acquires the ip address from Dlink and then check the internet connection on the computer, it has to work. if computer not getting ip from dlink, try restarting computer.
- If hardwire connection on the dlink works fine and check the wireless connection.
For wireless configuration or assistance you may check this link:
http://www.portforward.com/help/wirelessxp.htm
please feel free to ask, if you have any more assistance.
- Laxman
Nov 22, 2007 | Actiontec (GS204AD9-02) Router...
Computers & Internet Logo
15,803 people viewed this question
David Payne
David Payne
