Question about HP PSC 1315 All-In-One InkJet Printer
Need to change my ink cartridges....don't understand how to get the old cartridge out and put the new cartridge in.....help....
    Sergeant:
  • 236 Answers
Most cartridges lift forward and up. There is a slight catch that you will have to get past, but that isn't very hard to do.
To get to the cartridges, open the lid and teh ink should move into position for you.
Make sure you put the same color in the right spot.
Posted on Dec 12, 2008
Need to change the ink cartridge
  • Step 1
    Purchase an ink cartridge made specifically for your printer.
  • Step 2 Turn on your printer and raise the lid or press the cartridge changing button.
  • Step 3 Wait for the cartridge carrier to slide out.
  • Step 4 Put your finger behind the ridge on the top front of the old cartridge and pull it toward you to remove.
  • Step 5 Carefully remove the tape from the ink opening on the bottom of new cartridge.
  • Step 6 Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been.
  • Step 7 Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned.
  • Step 8 Close the cartridge holder lid and press the cleaning button to charge the cartridge.
  • Step 9 Close printer cover.
  • Feb 06, 2010 | HP OfficeJet 6110 All-In-One InkJet...
    How do you change the black cartridge in the printer epson stylus nx115
    Here is the Link showing instructions below. If you find this helpful, pls rate me.
    http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
    Replace Ink Cartridges
    Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
    If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
    If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
    Warning:
    Keep ink cartridges out of the reach of children and do not drink the ink.
    Note:
    If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
    You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
    Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to
    replace them to prevent the print head nozzles from drying out.
    When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
    Follow the instructions in these sections to check and replace your ink cartridges:
    Check Cartridge Status
    Purchase Epson Cartridges
    Replace Cartridges Using a Printer Software Utility
    Remove and Install Cartridges
    pls rate me. Thanks and Good Luck...
    Jan 23, 2010 | Epson Stylus NX115 All-In-One InkJet...
    My new lexmark 33 color ink cartridge will not register in my printer, nor will a replacement one. The old one does register when put back in.
    Sorry but I need to ask this.
    Are you using a factory new ink cartridge?
    Please consider the following:
    If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
    They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
    If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
    Don
    Nov 18, 2009 | Lexmark P4350 All-In-One InkJet Printer
    Orange cartridge keeps flashing after cartridge
    Are you using a factory new HP ink cartridge?
    Also take a moment and make sure that all of the protective tape coverings have been removed from the cartridge.
    Don
    Oct 22, 2009 | HP Deskjet 6980 InkJet Photo Printer
    Rechargeable cartridge problem
    marmotzelu_f,
    The cartridges used in these products have unique hardware identification numbers assigned to them. The printer records the ID of the print cartridge when it is installed. When the number changes, the unit knows that a new cartridge has been installed and resets the ink counters. Because of this, a low-ink message should not appear with a new cartridge. When you refill the same cartridge, the printer still only recognizes the old ID number on the cartridge, so it 'thinks' the cartridge is still low. There's really no way to reset the ID number, so you're kind of stuck watching to see when the ink starts to run out. I use remaufactured cartridges in my HP 2210 and they work fine (except for the 'low' reading). Just watch for your ink to start running out. I know this is inconvient sometimes, especially when printing pictures. Hope this helps.
    Jul 10, 2009 | HP Deskjet 6940 InkJet Printer
    Can't change ink on dell 810. what do I do first? I don't know how to change ink in dell 810,I couldn't see how to take old one out as well and how to put new one please
    Lift the priner unit lid on the printer llift he print cartridge lid,
    The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
    Press down on the ink cartridge lever to raise the ink cartridge lid.
    Remove the old ink cartridge.
    Dispose of the old cartridge properly.
    If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
    Insert the new ink cartridge.
    Snap the lid closed.
    Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed. Let me know if you have any questions.
    Apr 14, 2009 | Dell 810 All-In-One InkJet Printer
    Dell 725 printer no manual need to change ink cartridge
    Here is the manual
    http://support.dell.com/support/edocs/systems/725/en/index.htm
    Replacing an Ink Cartridge
    1. Turn on your printer.
    2. Lift the front cover.
    1. Press down on the ink cartridge lever to raise the ink cartridge lid.
    1. Remove the old ink cartridge.
    1. Dispose of the old cartridge properly.
    2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
    1. Insert the new ink cartridge.
    1. Snap the lid closed.
    1. Close the front cover.
    Feb 09, 2008 | Dell 725 InkJet Printer
    HP PSC 1315 All-In-One InkJet Printer Logo
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
