Question about Campbell Hausfeld 26 - Gallon Air Compressor
Start up problem
When I start my air compressor up cold and with air in the tank. The motor buzzes(acts as if it is bound up) and in 10-20 seconds trips my 20amp breaker. When I let the air out of the tank the motor starts up and builds pressure to 130psi. Seems to run fine with no air in the tank at start up. Please help
  • Anonymous Feb 09, 2009
    Mine does the exact same thing. I've changed the breaker etc no luck at all.
    President:
  • Campbell Hau... Master
  • 1,388 Answers
The problem that you describe is caused by the in-tank check valve and/ or the unloader at the pressure switch. When the compressor cycles off the pressure switch releases the air that remains in the air line thru a small valve. There is a 1/4 " plastic tube extending from the check valve to the switch. Listen for the release of air as soon as the compressor stops. There is a small metal tab that pushes on the unloader valve that may need to be adjusted. The motor does not have enough power to start pumping if there is air/backpressure in the air line. If these parts are working correctly then check the value of the start capacitor and use meter to measure. The cap should test within 95 % of stated value. Parts are available at www.chpower.com. Enjoy
Posted on Dec 13, 2008
Your compressor's un loader valve is damaged , thus cause a air buildup in line .
When start up occurs the pressure buildup causes the piston of the compressor to stick .
Solution is to renew the un loader valve . If the pressure reaches 8bar of whatever its set to it should cutout with a " hiss sound " indicating the air is unloaded from the system and release the pressure from the compressor pistons to start new with no pressure strain on the motor .
Posted on Jun 16, 2009
    Scholar:
  • 89 Answers
YOUR IN TANK CHECK VALVES ARE BAD. THERE IS AIR TRAPPED ON TOP OF YOUR PISTON WHEN IT IS TRYING TO START UP. DRAIN TANK AND REMOVE THE BRASS VALVE WHERE THE AIR GOES INTO THE TANK FROM THE HEAD (FOLLOW COPPER LINE). THERE IS A PEICE OF TRASH OR THE SEAT THE DISC SEALS ON IS DAMAGED. PART SHOULD COST $10.00 - 20.00. TAKE THE OLD VALVE WITH YOU TO MATCH SIZES. WHEN THE COMPRESSOR CUTS OFF AT FULL PRESSURE YOU SHOULD HEAR IT UNLOAD THE TRAPPED AIR.
Posted on Mar 20, 2009
Tip
Air Compressor Burn-Out
Small, easy to transport air compressors have become very popular over the last 25 years. However they do have their drawbacks.
The motors on these small compressors generate alot of heat as they cycle, especially under higher tank pressures (PSI's) and air volume usage (CFM's). They work very hard and run more frequently. In time, this heat creates increased resistance in the rotating armature windings (which act as quickly reversing magnets against magnets in the outer case of the motor for thrust to rotate). The magnetic force weakens, the motor gets weaker and hotter and has to work harder to do the same job.
When an air compressor motor seizes in it's cycle and hums or buzzes, it is over heating to a point where a thermostactic relay will break electrical contact (to prevent Fire) and the motor will have to cool before it will run again. each time this happens you are reducing the life of the motor by several hours.
To maximize the life of your compressor, use the following guidelines:
1.Always use the shortest possible cord and plug directly into a 20 amp cicuit when possible,no extension cords! SHORT WIRE+LONG AIRHOSE- electrical current is lost through longer wire and requires a larger gauge (diameter) to carry the current.
2.Make sure the plug contacts are clean- as with automobile batteries:CORROSION=RESISTANCE=HEAT=WEAR.
3. Should your compressor begin to stall during its cycle, attempt to turn it off or quickly or reduce the pressure in the air tank to reduce the load on the motor- while the motor is moving a fan blows air through it to cool it.
4.Should the motor overheat, let it cool untill you can touch it with your hand and bleed most of the air from the tank to minimize the start-up work load.
5.Remember to try to drain the tank after each use to minimize corrosion due to moisture and minimize load the next time you start it up.
Following these guidelines will increase the life of your compressor motor several months if not years.
-Remember-
BROKEN TOOLS CAN'T HELP YOU BUILD OR FIX ANYTHING
on Oct 04, 2010 | Air Tools & Compressors
Both the freezer and refrigerator are warm (Superba model). This happened all of the sudden. I felt the tank and lines at the back and the tank was hot and the lines were not cold. The fan motor is blowing...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 01, 2010 | KitchenAid Superba Architect KSCS25INSS...
I have a chicago pnumatic home air compressor 3 hp.21 gallon tank worked great moved from one house to another compressor tipped over and now acts like first stage of ele. motor is not working have to have...
sounds like the unloader/check valve is stuck or damaged. This is the part that holds the pressure in the tank and allows the compressor to start up without being under pressure
Mar 26, 2010 | Air Tools & Compressors
OIL FILLED COMPRESSOR SEEMS TO FREEZE UP ???
Cold weather will freeze the water the compressor normally makes and this can prevent the motor from driving the compressor. Drain the tank and warm it up as needed......
Jan 10, 2010 | Craftsman Air Tools & Compressors
My air conditioner is on but not blowing cold air and buzzes
The compressor is not starting. The buzzing noise you hear is the compressor trying to start and then the thermal overload trips. When it cools it will try to start again. Could be a bad capacitor or the compressor is bad. These two units need to be tested to see which one is bad. A capacitor is inexpensive. If it's the compressor it will be cheaper to buy a new AC.
Aug 21, 2009 | Heating & Cooling
Motor startup trouble while pressure in tank
My first thought was that the check valve is allowing pressure back into the compressor and preventing the motor from turning. That's still my best guess right now.
I think the cold weather start symptom is what you would see with any engine/motor -- it requires more torque to get it going. In this scenario, if the check valve weren't leaking, it would start okay when cold.
May 06, 2009 | Clarke Power Products Inc AC2001 2HP 4...
Compressor will not start
It is a good sign that the motor turns freely with and without air. That indicates that you have good bearings and that the intank check valve is in good condition. Next you should check the capacitors and the condition of the windings. Some motors have start and run capacitors and others only have run cap. Remove from the circuit and test with meter having cap. test setting. Most shops will test them for free. The cap should test within 95% of stated ( uf ) value. Replace as needed. Finally check that the flyball switch at rear inside of motor is functioning correctly. At rest, switch is at start winding, then a split second after start, it shifts to run winding. Check contacts are not stuck and that switch is working and lastly that the winding are the color of new penny. Good luck.
Jan 06, 2009 | Campbell Hausfeld 26 - Gallon Air...
Buzzing and then no cold air
You need a service tech to check out your system. Your compressor may not be starting which could be the reason for the humming noise and no cold air. Dead snake may not be related to your problem.
May 14, 2008 | Weather King 10AJA2501AH Air Conditioner
No cold in fridge or freezer: buzzing compressor
There is no start motor. If the brand of the compressor is a tecumpseh then it is most likely the problem and has a 5 yr warranty from the date of purchase. If it is an Embraco compressor I would try and overload and relay. They are all in one part sometimes called a start device.
Sep 24, 2007 | Amana ARB2217C Bottom Freezer Refrigerator
Campbell Hausfeld 26 - Gallon  Air Compressor Logo
453 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
