Question about Lexmark Office Equipment & Supplies
I am trying to load on D;/setupexe but it will not install.
  • Dan
    Dan May 11, 2010
    I can try to help you.
    I am assuming you have the install cd in the drive.
    Are you trying to run the program from the cd or are you typing in that install command from Start/Run?
    Sergeant:
    Novelist:
  • 183 Answers
I'm presuming this is an optical disk (CD or DVD) containing (printer?) software you wish to install ... right?
If so, are you trying to launch the "setup.exe" file from a cmd/Command Prompt shell by typing it in, then "enter"? If so, the most glaring problem is typographical error ... "D;/setupexe" > should be "D:setup.exe"
If not the above, does any installer dialog (i.e., window) display soon after inserting the disk into the drive? If the disk does indeed contain a software installation package with a "setup.exe" file, then this likely indicates "autoplay" is deactivated for that particular drive. If this is the case, it can be corrected by right-clicking the subject drive icon and modifying the settings on the "Autoplay" tab. Or alternatively accomplshed using "TweakUI". It's available at http://www.softpedia.com/get/Tweak/System-Tweak/TweakUI.shtml. However, get this handy and dandy Microsft utility regardless of this situation if you don't already have it.
This leaves the last scenario: Are you maually trying to launch the file by clicking on it? If so, what error dialog(s) are you encountering and what EXACTLY does it say?
TIP: A very rudimentary way to test the readability of a CD/DVD disk is to insert it into a drive, then launch "Command Prompt" and type in "DIR /S DRIVE_LETTER:" (without quotes), then hit enter. EXAMPLE: DIR /S D:
If it successfully displays every file on the disk (implies it's read), it's a fair indication of A-OK readable status.
That's the best shot in the dark I can make with the limited amount of info provided in the question. Please respond with additional info/feedback in order to help zero in on defining the problem.
"Today's the best day of my life...and NOW you're part of it!"
Posted on Dec 12, 2008
  • Craig The Geekinator
    Craig The Geekinator Dec 12, 2008
    Oops! ... I commited a typo myself.
    Correction:
    "D;/setupexe" > should be "D:\setup.exe"
Why i cannot install any of OS ?
Have you tried loading the bios and changing the AHCi to IDE or vice versa!
Jun 01, 2014 | Acer Aspire One D257 Netbook
Mother board not recognised
Hello
If the CD is ment to your motherboard, it should recogonize it. If it dow not autorun, open the file and click setupexe.
Feb 07, 2012 | Intel D945GCCR Motherboard
I have V1.O version easyspeak spanish. I also have window 7.Nothing is happening when i'm inserting my cd. I tried the setupexe., there's a green page opening and it looks like there is something is going...
windows vista and 7 need for some older applications to run in compatibility mode in order to be supported in windows 7 or vista. just follow my screen shot steeps.
Mar 05, 2011 | Kutoka Interactive Eazyspeak Spanish...
Old alchemy game will not install
Try this:
Right click on the D:/Poppack-setup.exe -> Properties = Compatability Tab.
There should be a box that says "Compatibility Mode" that you need to chek, and then select Win95 and hit OK.
Try installing again.
If it still gives the same error, go back to the tab and go lower than the Compatibility Mode box, to Display settings, and chek "Run in 256 colors" and "Disable Visual Themes"
Try again.
If it still wont work, please respond. If it gives a different error at any time or a different problem, please respond.
If it works, please rate. :)
Dec 12, 2008 | TalonSoft Video Game Consoles & Games
DVD/Cd Burner won't run programs.
All you need to do is that put the CD in the CD/DVD drive that you have access and not properly closed. For example here is the situation. I put a cd installer with a file named in the cd setup.exe and it is located in drive D: i access the file setup.exe and I run it or install.. then I decided not to install the programs.. what I did is that is did not cancel the installation but rather I immediately open my cd/dvd drive and get the cd..
What are going to happen? the installation is in the process and I did not cancel the installation properly. In the installation logs of the windows it still have to install the programs but it cannot find the file setup.exe that is located in the Drive D:.
Try to put a cd in your cd/dvd drive with file named setupexe on the cd.. that will solve your problems. TY
HOPE I CAN HELP
Dec 05, 2008 | Acer Aspire™ T180 PC Desktop
I have bought the all in one driving test dvd but it will not run. i have tried going to start/run and typed in D:\setupexe, it asks me to insert a dvd into the drive but it is already in there and will...
First of all, the requirements to run this dvd are:
1.55 GB with HP clips on DVD-rom or 3.66 Giga Bytes full hard-drive install
Memory: 128 MB
Make sure you have at LEAST this much space and memory before an install. A little more is needed to run the dvd.
PS Have you tried another dvd in the player?
Nov 18, 2008 | Computers & Internet
Actived webcam
I just bought a new web cam, i was having a hard time installing it. The pc can detect the web cam but it cannot install the drivers.
MAKE SURE THAT THE DISC THAT CAME WITH THE WEBCAM HAS DRIVERS IN IT.
1.Insert disc, right click your cdrom drive(example D:) then click explore. There must be a folder for drivers. Sometimes the setupexe file is not enough to make the webcam work
Mar 12, 2008 | Computers & Internet
Is my web cam bust?
If you are using XP SP2, the drivers of the webcam should be installed automatically after connecting the webcam to the usb port.
Try this, connect the webcam to the usb port. Go to DEVICE MANAGER(how to go to device manager--------go to control panel, at classic view Click System, click Hardware, Click Device Manager. In the Device manager page you should see a YELLOW QUESTION MARK if the webcam is detected by your computer. If this is the case your webcam is ok, you just need drivers for the device.
To check for drivers:
1:insert webcam cd to pc, open my computer
2:right click your cdrom drive, click explore. You should see the setupexe folder and another folder for drivers. You need the drivers to make your webcam work. Download drivers from the website of your webcam then try to install it.
51 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
