Question about Ionic Pro CA500 Air Purifier
I have C A 500 used just got how do i clean it its filthy
Pre soaked blades scrubed with non abrasive pad
then put in dishwasher wash and dry perfect works great
joneser57
Posted on Dec 13, 2008
  •  Bob Oppenheimer
    Bob Oppenheimer Jun 02, 2012
    I clean the collection panels with dish soap. Wet the collector down first to remove dust. What's left is oily. Put a few drops of dish detergent (Dawn or equivalent) on your fingers and smear over the metal panels. Rinse with warm water and thoroughly dry before putting back into service. For the body of the cleaner, I blow out with compressed air. A short bristle brush can be used on the vents but you have to be careful not to snage and break the electrode wires! There is also a small metal electrode front center at the bottom that should be cleaned if possible.
Dust caked up on wires and fan,how do you take it apart to clean it?
This question seems similar to another post from a while ago. http://www.fixya.com/support/t5074178-like_clean I just finished my Blue Air 500 for the same problem with loads of collected hair and dust around the fan. The manufacturer manual does not cover this type of cleaning and they do not want people to open the unit as it might void the warranty. It's actually simple you've done it but not obvious. There are 4 screws which you may not have seen on the top until you pop off the top grill. Remove those as they fasten the side curved panels, once the top screws are removed tug on the white curved pieces upwards and they should come off. Once these are off you should have full access to the interior to clean. Ours was utterly filthy and way past the warranty.
Feb 28, 2011 | Blueair 501 Air Purifier
I just purchased a used XL15s. The unit when in manual mode emits an oder, but the air feels oxygenated. When you breath close to the machine the air seems to irritate or kinda burn my eyes. When in auto...
This is what the machine is designed to do! The machine emits a low amount of ozone, which is the purifier/sanitizer created by sunlight. Close to the machine, it's concentrated. When it spreads throughout the room, it kills odors and bacteria, and creates the fresh smell of clean air. The air truly is "oxygenated," because ozone is simply O3, instead of O2, and breaks down quickly.
If the numbered dial is set too high (try it at 300 to 500) it will smell "bleachy." Your "rule of thumb" is that when you've been away, and enter the home, you should experience the same fresh, clean smell that you get when you step outdoors on a bright spring or winter day.
When you're doing something that creates odors, like frying fish or cooking sauerkraut, turn the dial up to take care of that odor quickly, then turn it down for normal operation.
Leave it on the manual setting for continual purification. Often, the auto setting has been disabled, which might be the case in your older machine. (These machines can be 12-15 years old!) For an owners manual, go to www.vollara.com (new name of Ecoquest/Alpine). They may be able to help you.
Jan 17, 2011 | Alpine Air XL-15 Air Purifier
Ionic breeze smells like a serious electrical short when I turn it on.
THEY RUN WITH A DIFFERENT KIND OF SMELL PEOPLE ARE NOT USED TO. ITS A HIGH VOLTAGE SCARY SMELL .IF IT SEEMS TO WORK OK THAN IT MIGHT BE OK
Apr 23, 2010 | Sharper Image Ionic Breeze® Quadra® 4.0...
MOdel CA-500 is making a type of hissing sound. Almost like a zapping sound.
you need to turn it off and remove plates,put in kitchen sink and spray with windex and dry with paper towels, now clean the bottom of the three plates too.
before you reinstall the plates look down inside you will see three thin lines of metal,make sure there is no lint or dust on them,reinstall and let set for five min. to allow any windex that might still be wet then turn on low for a couple of min.then go to medium
Dec 15, 2009 | Ionic Pro CA500 Air Purifier
Have a ta-500 unit no matter how much you clean it
probably the power supply, no real fix, you can try to remountt it or loosen the screws and that MAY fix it
Jul 06, 2009 | Air Purifiers
Can't clean Ionic Pro CA-500 inside?
This unit is a pain in the @$$ to disassemble but it CAN be done. The way I always look at it: Someone ASSEMBLED it.
Remove the four screws on the bottom stand followed by two screws on the bottom side of the unit. Then remove the tiny little screws up each side that hold the grill together (you will need a precision screwdriver).
Carefully pull apart- don't force it.
One half comes off (clean that half) in bathtub. The other half does not come off-vacuum that half out and use q-tips.
When re-assembling, watch for two things: First the wire cleaner (that slides) runs on a track on each half- pull it out a little to best allow for fitting. Second, there are little tabs at the top that fit under the control panel-watch for those.
email me at originalpairadice@yahoo.com if any problems.
Oct 19, 2007 | Ionic Pro 901P2RIP04 Air Purifier
What does a blinking blue light indicate?
"A blinking light indicates when the blades should be wiped clean with a damp cloth." I actually had a "handyman" contract last year to visit an elderly gentleman once a month and clean all 9 of his Ionic Breeze GP air purifiers. Before I did that for him, they would make hissing noises and he really didn't like that. Here's how to clean the operative compnents of these machines: First, unplug the machine and place on a work surface, such as a table or kitchen counter. Second, remove the metal blade insert from the top by gripping the release tab and lifting it up and out. Also remove the front and back grilles by pressing on the plastic tab at the bottom and lifting up on them. Third, use a damp rag or paper towel to wipe the three metal blades clean. Do not immerse this assembly in water, because it has to be completely dry when re-installing it in the machine. Fourth, use a small piece of damp paper towel to VERY GENTLY wipe clean the two thin wires inside the unit. These are located behind the two rubbery flat blades just inside the unit and can be accessed from the front side. You won't damage these rubbery flat blades by pushing your hand gently between them, but be VERY CAREFUL when wiping the wires clean. (This step is important, as the wires must be clean.) Fifth, using another bit of damp paper towel, carefully clean the wire attached to the inside of the front grille. Dry this off with a dry bit of paper towel, then clean any accumulated dirt off the front & back grilles. Check the metal contact near the bottom of the front grille (attached to the wire) to verify that it's clean and will make good electrical contact. Sixth, pick the unit up and turn it upside-down & right-side up about 6 to 8 times. The two wires inside have plastic beads on them that slide up and down the wires. This brushes any bits of leftover dust or lint off of the wires. (Again, these wires must be VERY clean.) Seventh, replace the front and back plastic grilles by placing them in their slots and sliding them down to snap into place. Verify that the assembly with the three metal blades is COMPLETELY dry, using a hair dryer if necessary to dry off damp areas, then slide it back into place from the top of the machine. Now the cleaning process is done, so plug the unit in and turn it on to test operation. If it makes ANY noise, then some component is not completely cleaned off, or still has a presence of moisture, which must be completely dried off before the machine is ready for operation. Hope this helps! ;)
Jul 07, 2007 | Sharper Image Ionic Breeze GP SI720 Air...
Ionic Pro CA500 Air Purifier Logo
167 people viewed this question
Top Ionic Pro Air Purifiers Experts
Paul Cox
Level 1 Expert
Thomas Perkins
Thomas Perkins
Are you an Ionic Pro Air Purifier Expert? Answer questions, earn points and help others
