Question about Samsung DVDR120 DVD Recorder
I cannot finalize it keeps on saying no title list.
I keep on getting no title list when I want to finalize the dvd.
    Champion:
  • 236 Answers
Are you absolutely sure there are recordings on that disc?The message means the recorder can´t find any. If you have a chance and it´s a VR-disc, try playing it on another player that is known to be able to play unfinalized VRs. If it was recorded in video mode there´s nothing you can do. If the material is of great importance turn to data retrieval professionals.
Posted on Feb 11, 2009
I have dubbed vcr tape to a Sony DVD-RW disc and tried playing it back through a toshiba player and it keeps coming up Bad Disk. My PC won't even recognise it. When started dubbing the screen displayed 1hr...
Did you say you used a DVD-RW disc to transfer a videotape onto? The reason your PC won't recognise that disc is because the data format on it is a different language to what PCs understand - plus an unfinalised DVD-RW won't play in other DVD players - it is usually an incompatible format.
(DVD+RW discs with titles/top menus created in video mode CAN be played on a PC DVD drive or a normal DVD player as can finalised DVD-R discs (DVD-R discs MUST be recorded and finalised in the same recorder for compatible playback). DVD-RW discs can only be viewed on the unit they were written/recorded on.
The other reason for the 'remaining space' on the disc you describe showing less than 120 minutes is due to a title recently being recorded or erased - unless you format it - the 120 minute / 4.7GB DVD-RW will not show full available space. Erasing titles on re-writable DVDs does not increase space. The same rule applies to unfinalised +R / -R discs (you cannot re-format these to get the space back once recorded - they are 'once only' writables)
I recommend you invest in some DVD-R discs and re-copy your VHS tape to that - then if you are satisfied with the result, title etc., finalise the DVD-R - it will play on any DVD player or PC with DVD support (or it should). These discs are relatively inexpensive to buy just about anywhere.
Final note: do NOT finalise the DVD-RW you recorded (I hope you haven't already done this) - simply format/erase it - re-use it for something else or keep it until you need it.
You can use any brand of DVD, just take note of the format before recording/playing.
Mar 21, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
How do I finalized a DVD?
after the program(s) recorded go to menu (if you wish to keep) using the remote...you will be able to edit give title to the disc and finalizing
Jun 23, 2010 | Panasonic DMR-E85H DVD Recorder
I burn dvd -r and dvd+r and it will not play on it
It is possible that the disks are not finalized. You may need to configure it to auto finalize, which is off by default. It would be impossible to have more than one title on a disk if you always auto finalized. Check your manual, and finalize your disks. Many times marginal disks will play OK in the unit they were recorded on, but not so well in other players. The media (disks) could be the problem as well. On a side note, the DR410 will NOT burn DL (dual layer) disks. I hope this helps and good luck.
Oct 28, 2009 | Toshiba DR410 DVD Recorder
Sony RDR-GX315 DVD 3 problem
sounds like your laser is getting weak. repair is usually not economical. laser is about 90% the cost of the unit. hope this helps if it still plays but not record. keep it as strictly playback unit.
Jun 04, 2009 | Sony RDR-VX530 DVD Recorder/VCR
I am recording fron VHS to DVD. When I am finished and push the stop button, How can I tell how much space is on the DVD to record something else and how do I finish the dik so it can't be recordered over
JVC DVD Recorder – Finalizing and disc space
First, you will need to know if the program was recorded in XP mode, SP mode, LP mode, or EP mode. To find out how much room there is left, put the dvd in the tray and press the Disc Menu/List button on the JVC remote. This will display the title and how long it is - write that number down. It will also say either "XP,SP, LP, or EP" - write down that mode. In XP mode, a DVD will hold 1 hr and 20 mins worth of prgramming - MAXIMUM. SP mode = 2 hours. LP mode = 4 hours. EP = 6 hours. So, if your program is one hour, and you recorded in LP mode, you have 4 - 1 = 3 hours of space left for recording on that disc.
If you finalize a disc, you will no longer be able to add more programs to that disc, unless the disc is a + or - RW disc. Also note that finalization requires some disc space, so if you recorded a program that is exactly 1hr and 20 mins long, and you recorded it in XP mode, then the disc will probably not finalize correctly.
That being said, the finalization directions are on p. 23 of your manaul: Title --> Finalize --> => --> find finalize --> Enter --> OK --> Enter
Now it will play on other players.
Here is a link to the user manual:
http://resources.jvc.com/Resources/00/00/93/LPT1133-001A.pdf
-Tha Mp3 Doctor
Dec 31, 2008 | JVC DR-MV7 DVD Recorder/VCR
DVD will not finalize
I had this problem and moved to "Ashampoo Burning Studio" it was free on a computer magazine had no more problems
Aug 08, 2008 | Samsung DVD-VR357
The magnavox zc320mw8 will not finalize a dvd for playback on anther dvd player
Try this. Insert DVD. Press SETUP button. Once DVD has loaded the DISK FINALIZE option will be available. You can then FINALIZE.
Jun 24, 2008 | Philips Magnavox DVD/VCR Dual Player
Recording problem
I have had two of these recorders, Using only Sony + discs or rewriteables is my solution, I will not use any thing else. It may work 1-3 times on others brands then start throwing coasters.
As to renaming, on my model I pull up the tiltle menu then select Try using rewriteables for the other problem as well My model is a little older and lets me take disc out without finalizing then when inserting select title, hit edit on remote and select rename. Maybe if you can skip the finalizing (as with rewritables it will help
Apr 01, 2008 | iLO DVDR05 DVD Recorder
Finalizing dvd
VHS tape to a DVD-R
Jan 13, 2008 | Zenith XBR413 DVD Recorder
Samsung DVDR120 DVD Recorder Logo
179 people viewed this question
Henry  Thomas
Henry Thomas
