Question about Acer Aspire 4315 Notebook
Screen flicker (only when ac power is removed)
Hi, I am suffering because when I remove the ac power cord on my laptop the screen starts to flicker. If I plug the ac back in it stops!
If i boot from battery power it's fine- unless I play a dvd and stop it!!! weird. fresh xp home install 2 weeks ago, new screen fitted to laptop. new driver needed maybe?!?!
  • Acer Master
  • 4,806 Answers
Hi there
yes its the graphic drivers that needs installing, i must also tell you that when you remove AC power from the laptop it will go into power saving mode and you will notice that the screen dims a little, this is normal and nothing to worry about
Kind regards and please don't forget to rate us
Posted on Dec 12, 2008
Emachine e730 won't turn on. Havit on power supply and the light is orange. Worked on it for a bit without charge and shut it down, went out, Came back tried to switch it on but nothing.
Remove the battery but leave the ac adapter power cord in if it still doesn't start
you have to eliminate the ac adapter power cord
try a different adapter power cord
25717659-m35oz4jvdfvvmght4a51n0jl-2-0.jpg if it still dosnt start but you have the orange light on
it could be the laptop power jack is faulty and has to be replaced
25717659-m35oz4jvdfvvmght4a51n0jl-2-1.jpg laptop power jack
i hope this helps
May 28, 2015 | Computers & Internet
I have an acer aspire 5100 and here recently the
Could be a bad battery and/or charger/AC Adaptor/DC Connector. Try to isolate the problem by removing the battery and then plugging the laptop charger in and starting the pc up. It should boot on the AC adapter alone. If it won't boot on the AC adaptor or it flickers and flashes while on the AC adaptor, I would first suspect the AC adaptor or the DC connector on the laptop (try wiggling the power plug at the PC to try and check the connector). If it behaves while on the AC adaptor without the battery present, I would suspect the battery. Either way, you may have to replace something.
Sep 04, 2014 | Computers & Internet
I have a lenovo thinkpad T420 and three days ago I lost my power cord now that I got a new one my laptop screen doesn't seem to turn on I tried a lot of solutions and nothing seems to work. When I turn...
Hi, try removing the battery pack then use the AC adapter or power cord alone. If still the same. Eject the battery and also remove from outlet hang on for 10 minutes. Then try to turn it on again with AC adapter alone
Oct 06, 2012 | Computers & Internet
My lifebook s7010 won't startup. After put the on button the screen still remains black. The fujitsu logo will not appear on the screen.
Unplug the AC adapter from power cord, then remove the battery.Wait 30 min and put the battery back.Plug the AC in power cord and try again.If not start you need check AC adapter with voltmeter.If the AC working your computer need service.
Nov 10, 2009 | Fujitsu Siemens LifeBook S7010 Notebook
My inspiron 6000's power flickers on and off intermittently, switching between A/C & battery power. I've replaced the power cord. Any other ideas?
Try removing batt and use ac adapter alone. Check if laptop works fine also check if LED flickers still.
Try removing ac adapter and use battery alone and check if batt flickers as well.
If flickering only happens when both are connected or vice versa try this first. Update the BIOS for your laptop. Download the BIOS update from http;//
Oct 22, 2009 | Dell Inspiron 6000 Notebook
Flickering screen - Acer (laptop) 1690 series
You have two problems and they are separate issues.
First your battery is nearly worn out. Rechargeable batteries have a finite number of charge and discharge cycles and as the battery ages the charge capacity will drop. When the battery is worn out, it may not charge at all or show it is 100% charged but when you remove the AC power the laptop will shut off because the battery is dead. A new battery is required to fix this problem.
Second when you connect the AC adapter into the laptop's power socket, and the screen flickers and the charge LED also flicks, it means the power socket is faulty or the power socket has a dry solder joint connection to the motherboard. If you hold the power plug in a particular position you should notice the charge LED will stay on without flickering as well as the LCD screen.
This fault can be repaired, but it requires the laptop to be dismantled completely to access the power socket. I suggest you get a quote first.
Sep 06, 2009 | Acer Aspire One A150-1006 Notebook
My HP Pavilion dv6000 won't turn on
if no one led blink and it show no power then remove battery then refix it.
Jan 20, 2009 | HP Pavilion dv9000z Notebook
Sleep State Resume Trouble
Yes, unplug, remove battery, replace, then start. It's just glitched slightly, no biggie.
Aug 09, 2008 | Dell Latitude D600 Notebook
Acer aspire 5580 laptop unable to power up fully
remove battery and use the ac try it then, if that doesn't work remove everything possible cdrom,memory,battery,pc1.gif cards and try it again, if still fails try wiggling the ac cord at the input
Jan 24, 2008 | Acer Aspire 5580 Notebook
Failed on restart, had all lights, now no lights and won't do anything!
sounds like your ac plug to the laptop might be loose you can try ans see if you can resolder it back. the other problem is your ac cord might be broken wiggle it around see if the light flickers.
Jan 03, 2008 | IBM ThinkPad R50e Notebook
Acer Aspire 4315 Notebook Logo
199 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
