Question about Kenmore 24 in. 16482 / 16484 / 16489 Built-in Dishwasher
Dishwaser water run out of dishwasher when its not on. had to shut off water
    Novelist:
  • 116 Answers
Your machine possibly has a stuck water inlet valve. Water pressure is meant to shut the valve and electricity is used to open it.
Posted on Mar 11, 2007
I have a KitchenAid model KUDI01ILBT2. It was working fine until recently...The lights work fine, but when I push the start button it's delayed before it actually kicks on, and then it will...
sounds like you have a bad or clogged fill vavle,,you have water running to unit but not in unit,,,its still trying to dry dishes as if they wash...most dishwasher are hard wired to breaker and or not grounded,,,but only if you can shut of power pull dishwasher out remove water connection,,see if any **** is blocking vavle use flash lite if present...if so replace it..good luck you can not clean a dishwaser vavle..
Sep 03, 2011 | KitchenAid 24 in. KUDI01IL - Multiple...
When I run the Garbage Disposal the grounded up food and water back up into the dishwasher and does not drain untill I run the the dishwaser
you have two problems. 1. No air gap or one that is not working right. Here is a good description of what air gaps do with a good picture. There is also a short video 2. your drain is blocked. When you run the disposal it pushes a bunch of water down the drain, it can't go, so it backs up through the dishwasher drain into the dishwasher. unclog the drain, fix or add an air gap, and you will be 100%
Jun 11, 2011 | Dishwashers
Ge dishwaser will run but wont spray any water
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Sep 05, 2010 | GE Dishwashers
My dishwaser dosent finish its cycle it just keeps bleeping
if you are talking about the clean light blinking 7 times it is a water temperature problem either the heater element does not work or you need to run hot water at the sink by the dishwasher until hot to the touch or till at least 110 degrees before starting the dishwasher this should fix ya problem
Apr 03, 2010 | Whirlpool Dishwashers
The water does not go into the dishwaser
I would check the water inlet solenoid first to see if it's getting 110v. If it isn't it could be a bad timer/control switch. If it's getting 110v then the solenoid is probably bad and not opening to allow water through.
Dec 07, 2009 | KitchenAid 24 in. KUDM01TJ - Multiple...
The dishwaser takes a very long time to run thruogh is cycles.
on many models, the timer will not move if the water is not up to temp. be sure that you run hot water in the sink until it gets hot before you start the dishwasher.
are your dishes coming out clean and hot? if not, your heating element may be faulty. this is used for drying, but also to maintain water temp. during the cycle. a bad heating element will certainly make the cycle take forever, if it ever gets done. good luck
Nov 02, 2009 | Asko D1716 Built-in Dishwasher
Water not draining in the bottom of the dishwaser,no power at all
if you have a row of buttons on the left side for heat cycles check them a shorted switch will cause a loss of current situation so that the drain solnoid wont activate
Oct 12, 2009 | Whirlpool 24 in. DU1148XTP Built-in...
Disherwasher fills with water but will not spray
Mine did the same thing; cycled through without any actual washing by the spray arms. pulled the sump and found a piece of broken glass was jamming the impeller. Might have been able to remove this glass by removing the volute cover and exposing the impeller while the sump was still in the machine, but that's hindsight.
Jul 25, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Shu43 built in dishwasher
Running the hot water in the sink until you get the water hot then, make shore you are using jet dry. Bosh dishwasher dry with condensation. Let me know
Aug 02, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
No water coming into dishwaser.
  1. Valve shut off to dishwasher
  2. Float stuck (bottom right front corner inside - check for obstructions)
  3. Kinked water supply line
Greg
Jan 02, 2008 | KitchenAid 24 in. KUDI01TJ - Multiple...
Kenmore 24 in. 16482 / 16484 / 16489 Built-in Dishwasher Logo
96 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
