Question about RCA D52W19 52" Rear Projection Television
RCA tv how do you disapate stored energy in flyback set by step
  • ladywinn
    ladywinn May 11, 2010
    Are you wanting to know how to remove and replace part or what?
  • 585 Answers
The high voltage system has internal bleeder resistors in the form of the high voltage divider that is used to derive the focus and screen voltages. The majority of the voltage will usually bleed off in 30 minutes time. If you would like to feel safer, allow the set to rest unplugged for a day for all but just a very small charge to dissipate. (a discharge then will make only a small "tic" instead of the crack like a rifle) Then disconnect the leads with one hand behind your back and with you not in contact with any metal. Old hands like myself will use a good cliplead and a thin tool to discharge the system while there is a good amount of snap left., slipping the tool under an insulating cap. DO NOT pierce any insulation on the wire or rubber caps, as this will cause arcing in the system later. If you attempt this BE EXTREMELY CAREFUL!!!!!!! Again one hand behind you back. If you were to get discharged on you don't want to have a path across the heart! And it's not for the skittish, the sound tends to make even the experienced like me still jump.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Posted on Dec 19, 2008
W to replace the flyback transformer on an RCA rear projection tv
Go to you need the 270125 flyback kit listed under the RCA repair kits. The flybackk comes with the CD with step by step instructions.
Apr 06, 2010 | Televison & Video
Im fixing a rca hd52w59 itc 222a and i found the flyback making an arc of purple energy and the tv still runs and has good picture but this arc after a few minutes causes a big shock and the tv shuts down,...
The flyback should be replaced your model uses the 270125 flyback. Its a easy repair. You can get the replacement 270125 flyback from and they send a Cd with detailed instructions on how to do the replacement.
Jan 23, 2010 | RCA HD52W59 HDTV Projection Television
RCA tv will not stay on
Sounds like the flyback very famous for that model. You need Flyback 270125 you can get the new RCA flyback at the following link and they provide step by step detailed indtructions on how to do the repair. Heres the link to your flyback.
Jun 18, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Locating the ''flyback transformer '' on a rca mod #R52WH74
It is usually large and black. Its the one with the rather thick red wire coming out of it. The other end of that wire either connects directly to the picture tube or into a distribution block which distributes the high voltage to the 3 picture tubes (guns) in projection TV's. Be aware that this transformer produces high voltage and can store voltage even when the set is unplugged. I hope this helps.
Mar 10, 2009 | RCA Televison & Video
Have a 52 inch rca d52w20 rear projection tv, the tv was on then it just turned off..attempted to turn it back on and heard a sqeaking noise and tv will not turn back on.. please help..
replace the flyback, very easy repair. You need flyback 259296 you can getone at the following link with free step by step instructions with pictures. heres the link read their reviews.
Jan 22, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Replacing the flyback
If your model is a HD52W59 the wires are part of the new transformer and have to be changed at the tripler and screen control block
Jan 21, 2009 | RCA HD52W59 HDTV Projection Television
My RCA 52 Inch has a Problem
Your TV uses the 259296 Flyback. You can get one at the following link and they provide step by step instructions with detailed pictures so you can easially do the repair yourself. Heres the link.
Oct 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
52" rca projection screen tv
If the light blinks 3 times its most likely the flyback. Your model uses flyback 259296 and you can get a replacement at the following link and they have free online instant messageing with a tech when you replace the flyback so they can take you step by step while you change it. Hers the link its flyback 259296.
Aug 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Where can i find Flyback for this Tv
If that is part number 2622341 it is still avaialablr from ther
Jun 15, 2008 | RCA 27V530T 27" TV
Tv will turn on
i believe the problem is the flyback transformer. try cleaning by using a small aerosal can. this will either correct the problem or you might have to replace it.
flyback transformer stores energy so i would suggest hiring a professional technician.
Nov 20, 2007 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
79 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
