Question about Sony DCR-TRV285E Digital-8 Digital Camcorder
Transfer Video to PC
Have connected USB cable (both ends!) but get message 'Cant Find Video Camera' WHat shall I do?
  • Anonymous Jul 01, 2008
    i have a same problem
    President:
  • 2,961 Answers
Assuming the camera is switched on or in transfer mode if required, you may need to reinstall the camera software, and preferably try using adifferent a different usb port.
Posted on Mar 09, 2007
I'm looking for the driver of sony handycam CDR-TRV22E so that i can transfer the video to my pc. thanx.
You can download drivers and manual for this camera from this page.
Advice on how to do the transfer is on this page. (You need to select Mini DV)
Sony recommend using Firewire instead of USB to transfer video from this type of camera.
This camera has both USB and Firewire (DV) connections. Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. The USB cable is less standard at the camera end, so search for one that is compatible with your camera.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card.
Nov 01, 2010 | Sony Handycam DCR-TRV22E Mini DV Digital...
I got a GR-DVL820u digital video camera. I wanted to transfer the videos to the PC and burn the CDs. I was supplied with only A/V cable but not the firewire cable which will connect the camera with my PC....
Firewire DV and USB are two different type of cable. This camera offers both, but the USB connection is only used to transfer still photos, not video. Most PCs don't have a socket for a Firewire DV connection, but you can install a Firewire add-on board in one of the PC bus slots. Then you need a Firewire cable with a small connector on the camera end and a bigger connector on the PC end.
You can download a manual from
this link
and also order cables, but they should be available in any camera shop.
Oct 21, 2010 | JVC GR-D370 Mini DV Digital Camcorder
How do I transfer the pics into my PC
Here are the steps to transfer your digital files from the Optimus DV-3040 Camcorder to your computer:
  1. Connect the small end of the USB cable to the USB connector on the digital video camera.
  2. Connect the larger end of the USB cable to an available USB port on your computer.
  3. Turn on the camera and the computer. The [USB MODE] screen appears on the camera’s LCD monitor.
  4. Select [MASS STORAGE] with the zoom lever, and press the O button.
  5. From the Windows desktop, double click on "My Computer".
  6. Look for a new "Removable disk" icon. This "Removable disk" is actually the memory or memory card in your digital video camera.
  7. Double click on the removable disk and locate the DCIM, MP3 and AUDIO folders. Select the files that you want, and then choose “Copy” from the “Edit” menu. Open the destination location (folder) and choose “Paste” from the “Edit” menu. You may also drag and drop image files from the digital video camera to a desired location.
Nov 18, 2009 | Optimus DV-3040 Flash Media Camcorder
Cant transfer videos to pc
Option 1:
If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this Link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Option 2:
(Applicable for Windows XP Operating System only):
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Option 3:
If you are using an i.LINK cable then:
The Camcorder will flash the DV IN message as soon as the i.LINK/Firewire cable is connected to the Camcorder.
If you are getting the DV IN message then it indicates that the Camcorder recognize the connection.
If you are not getting the DV IN message as soon as the i.LINK cable is connected with the Camcorder then the issue may be with either the Camcorder or with the i.LINK cable.
Try resetting the Camcorder or try with different i.LINK cable. Locate the RESET button behind the LCD screen of the Camcorder. (You will be able to locate the RESET button by opening the LCD Screen. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object).
NOTE: Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.
If the issue still persists after resetting the Camcorder and with different i.LINK cable then your Camcorder requires service to resolve the issue.
Good Luck!!!!!!!!!!!!!!!
Sep 17, 2009 | Sony DCR-TRV285E Digital-8 Digital...
Panasonic PVDV953D Transfer to PC
well if you buy a DV camera wich are Cassettes you shall need a Fire wire cord and if you have a SD memory or Hardrive then you can use a USB cord so Its DV=firewire and Hardrive=USB
Feb 16, 2009 | Panasonic PV-DV953 Mini DV Digital...
JVC GR-D870 digital camera, how to transfer Min Div tape to PC
Hi, You need to use 4 pin firewire cable to connect to the PC. Switch on the cam. Open Windows Movie Maker and import the video from device.
Dec 28, 2008 | JVC Cybercam GR-D200US Mini DV Digital...
Ricoh Caplio R5. Have used cable transfer of pictures to my PC twice , but now the plug will not enter the camera socket.
hi!!!
try to replaced your usb plug
or removed the memory card and plug in
memory card reader!!!
if you want to move the pic to the computer
Sep 23, 2008 | Cameras
JVC Everio GZ-MG37u Cant Connect to Pc
I want driver sony handycam 700x digital 8
Sep 17, 2008 | Video Cameras
Connectivity - usb cable
im not a genius or anything but i have nokia pc suite and i cant drag files to my phone either. i usually just plug the memory card into the computer and it comes up as a memory card with the images and video clips folders etc. im pretty sure its faster than the usb cable. you could also buy a usb infrared thing but they are very slow to transfer files. so if you really want to use your usb cable then this question wouldnt've helpd. thanks. Louis
Dec 24, 2007 | Nokia 6288 Cellular Phone
Sony DCR-TRV285E Digital-8 Digital Camcorder Logo
91 people viewed this question
Top Sony Video Cameras Experts
Parshiv Luthra
Jose Ma DM.
Jose Ma DM.
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
